Intel® MPI Library
2285 Discussions
What is the equivalent of --map-by-node
AThar2
To briefly explain what I want to achieve:
I am running two codes coupled with mpi like the following:
   mpirun -np X ./exe1 : -np Y ./exe2
However, I have to control  how this is distributed across each nodes - so say we got three nodes I would create such hostfile
comp00
comp00
comp01
comp01
comp02
comp02
comp00
comp00
comp01
comp01
comp02
comp02
I would then run the following:
mpirun --hostfile myhost -np 6 ./exe1  : -np 6 ./exe2
So basically the first 6 instances in the "myhost" will be reserved for exe1 and the last 6 for exe2.
This works all fine.
However, the rank numbering is not what I want. With Intel MPI I get the following for say the first 6 ranks on exe1
0 rank: comp00
1 rank:comp01
2 rank: comp02
3 rank:comp00
4 rank: comp01
5 rank: comp02
I want to make sure that rank 0 and 1 belong to comp00 and 2-3 to comp01 etc etc
With OpenMPI I achieve this by doing the following
mpirun --hostfile myhost -np 6 ./exe1  : --map-by node -np 6 ./exe2
Notice the map-by node has to be on the second code 'exe2' - but this ensures that both exe1 and exe2 have their associated ranks clustered to the same node.
How can I do the same with intelMPI -
GouthamK_Intel
Hi Ali Thari,
Thanks for briefly explaining the issue which you are facing, from the explanation provided by you I assume that you wanted to run the consecutive ranks on a single node in a round-robin fashion instead of the default one which assigns a single rank on a single node and then assigns other ranks on round-robin manner.
If this is the information you wanted to seek, then please use -ppn (# of processes per node) option to set the number of processes to launch on each node.
Example:
for more details of ppn please refer to the below link:
https://software.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/running-applications/running-an-mpi-program.html
If your issue still persists/if your issue is something else, please let us know.
Have a Good day!
Thanks & Regards
Goutham
GouthamK_Intel
Hi Ali Thari,
Example:
Have a Good day!
Thanks & Regards
Goutham
GouthamK_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Thanks & Regards
Goutham
