Intel® MPI Library
2293 Discussions
Which file replaces ipsxe-comp-vars.bat from Composer XE ?
Jaqueline123
I have a very old user-written program in which the file
C:\Program Files (x86)\Intel\ComposerXE-2011\bin\ipsxe-comp-vars.bat
is called. Since Intel Composer XE is no longer available, I downloaded the oneAPI Base Toolkit and the oneAPI HPC Toolkit and I am now trying to get the program from 2008 to run.
(unfortunately I do not have the ipsxe-comp-vars file nor do I know what it contains or what it does)
Which file replaces the ipsxe-comp-vars.bat? I have already tried the following two possibilities:
  • Intel\oneAPI\setvars-vcvarsall.bat
  • Intel\oneAPI\setvars.bat
The original call had two parameters appended to it:
CALL "C:\Program Files (x86)\Intel\ComposerXE-2011\bin\ipsxe-comp-vars.bat" intel64 vs2005
Many thanks in advance!
ShanmukhS_Intel
Thanks for posting on Intel Communities. Could you please try using oneAPI command prompt, as all the dependencies will get sourced using this.
Shanmukh.SS
ShanmukhS_Intel
Thank you. As per your request internally, we assume that your issue is resolved. We are closing the case at our end. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shanmukh.SS
