Intel® MPI Library
about MPI benchmark 4.0 tests
dingjun_chencmgl_ca
Hi, Dear Sir or Madam,
I am testing your MPI benchmark 4.0 on my computer. but the following error occurred when building IMB-IO.EXE,
1 IntelliSense: expected an identifier d:\dingjun\openmp_mpi_hybrid\imb-4.0-beta\imb\4.0.0\src\imb_benchmark.h 127 2 IMB-IO
 2 IntelliSense: expected an identifier d:\dingjun\openmp_mpi_hybrid\imb-4.0-beta\imb\4.0.0\src\imb_benchmark.h 128 2 IMB-IO
the corresponding source codes are follows:
#ifdef MPIIO
       MPI_Offset Offset;
       switch(fpos)
           case indv_block:
              Offset = (MPI_Offset)(j_sample*totlen);
              break;
           case explicit:
              Offset = c_info->split.Offset+(MPI_Offset)(j_sample*totlen);
              break;
           case private:
              Offset = (MPI_Offset)(j_sample*loclen);
              break;
           case shared:
              Offset = (MPI_Offset)(-1);
              break;
#ifdef MPIIO
typedef enum
    nothing=-1,
       private,
       explicit,
    indv_block,
    indv_cyclic,
    shared
} POSITIONING
the C++ keywords "private" and " explicit" used as variables so that the MS visual studio failed to build the executable file. Please tell me how to handle this situation. Thanks and I look forward to hearing from you.
dingjun_chencmgl_ca
Please tell me how to eliminate such an error. Thanks.
James_T_Intel
It sounds like Visual Studio* isn't properly compiling this as C code.  The names private and explicit are not keywords in C, but they are in C++.
Are you using one of the Visual Studio* projects/solutions included with the Intel® MPI Benchmarks, or did you make your own?  If you are using one of the included projects/solutions, which one?  Which version of Visual Studio* are you using?
I have Visual Studio 2012* here, and the three IMB-IO solutions all compiled correctly for me (with the non-2012 solutions automatically converted).  There is an option in Visual Studio* to specify whether to compile a code as C, C++, or automatically detect which one.  In my version, this is under Project Properties->Configuration Properties->C/C++->Advanced->Compile As.  Make certain this is set to Default or Compile as C Code.
If you're still having problems after this, please let me know and I'll investigate further.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
dingjun_chencmgl_ca
the IMB-IO problem from IMB 4.0 beta
MS visual Studio 2010.
Information on my computer is as follows:
D:\Dingjun\OpenMP_MPI_hybrid\imb-4.0-beta\imb\4.0.0\WINDOWS\IMB-IO_VS_2010
dingjun_chencmgl_ca
I have chosen such an option:  Compile as C Code (/TC)
but the same errors still occurred. Please see the following:
 3 IntelliSense: expected an expression d:\dingjun\openmp_mpi_hybrid\imb-4.0-beta\imb\4.0.0\src\imb_chk_diff.c 281 11 IMB-IO
 4 IntelliSense: expected an expression d:\dingjun\openmp_mpi_hybrid\imb-4.0-beta\imb\4.0.0\src\imb_chk_diff.c 285 11 IMB-IO
 5 IntelliSense: expected an identifier d:\dingjun\openmp_mpi_hybrid\imb-4.0-beta\imb\4.0.0\src\imb_benchmark.h 127 2 IMB-IO
 6 IntelliSense: expected an identifier d:\dingjun\openmp_mpi_hybrid\imb-4.0-beta\imb\4.0.0\src\imb_benchmark.h 128 2 IMB-IO
James_T_Intel
Thank you for the information.  I tested it in Visual Studio 2010*, and I am seeing the same problem.  Let me get this to our developers.
Sincerely,
James Tullos
dingjun_chencmgl_ca
Please tell my how to correct above errors in compilation. I look forward to hearing from you.  Thanks.
James_T_Intel
We will not be fixing this, as this error is not found in supported versions of Visual Studio.  VS2010 is not a supported version.
