Intel® MPI Library
2300 Discussions
assertion failed intel_transport_init.h
RHRK_TUKL
OneAPI in version 2021.3
SLURM
mpiexec.hydra *like mpiexec, mpirun produces
Assertion failed in file ../../src/mpid/ch4/shm/posix/eager/include/intel_transport_init.h at line 1
057: llc_id >= 0
ShivaniK_Intel
Could you please provide the sample reproducer code and the steps to reproduce the issue at our end?
Also, Could you please provide us your system environment details(OS version)?
Thanks & Regards
Shivani
RHRK_TUKL
#SBATCH --nodes=2
#SBATCH --ntasks=4
#SBATCH --cpus-per-task=2
#SBATCH --ntasks-per-node=2
mpiicc -o oneA test_affinity.c
export I_MPI_DEBUG=100
mpiexec.hydra ./oneA
OS: Linux 3.10.0-1160.42.2.el7.x86_64
ShivaniK_Intel
Thanks for providing the details.
We can see that you have not attached the sample reproducer code. Could you please provide the sample reproducer code to investigate more on the issue?
Thanks & Regards
Shivani
RHRK_TUKL
Ok, it's that simple. To my opinion, MPI_Init() is already not passed.
ShivaniK_Intel
Thanks for providing the requested details. We have tried on Linux CentOS version 8 and were unable to reproduce the issue at our end.
Could you please provide a complete error log to investigate more on your issue?
Thanks & Regards
Shivani
RHRK_TUKL
installed the new release 2021.4.
No everything seems to work like it should.
Case may be closed.
 Josef Schüle
RHRK_TUKL
here is the slurm-Error file with I_MPI_DEBUG=100 after calling
mpiexec.hydra ./exe
ShivaniK_Intel
Thanks for providing the slurm-error file .Could you also please provide output file too which has the details about I_MPI_DEBUG log?
Also, let us know the libfabric provider you have been using?
Thanks & Regards
Shivani
ShivaniK_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
