Intel® MPI Library
coarray problems
latomicien
i execute since many days a fortran coarray soft (for teach use) which is a simple matrix computation. I have make it myself.
1) Today when i execute it, without debugging, i have in a console windows (it's a console project) : unknown option : -localonly and the program ask for a touch to stop the program. It's on visual studio 2010 on windows 7. On unix i have not this problem.
I try to modify a lot of option of the compiler (i don't understand all) but this errors alway arrive !
2) my program (when it's run) which make a product of two matrix (n,n) take a lot of time only for some dimension (n is power of 2 : 1024, 2048, 4096 ..) ! This error arrive on linux and windows.
Some one has an experiment about theses errors ?
Thanks you very much
James_T_Intel
Hi latomicien,
Could you post the source code you are using, along with the compiler options you are using? Also, what is the output from
[plain]ifort -V[/plain]
Sincerely,
James Tullos
Technical Consulting Engineer
Intel Cluster Tools
