Intel® MPI Library
2301 Discussions
command not recognized when setting up Intel MPI Library
zhzhu1218
I used to work with MPI codes using Intel Parallel Studio + VS 2019 + Fortran, and just updated to openAPI + VS 2022 + Fortran. When following the guide here (https://www.intel.com/content/www/us/en/docs/mpi-library/get-started-guide-windows/2021-6/overview.html) to set up the updated Intel MPI Library, I get through the first two steps (hydra_service -install; hydra_service -start). But when I key in mpiexec -register, the command prompt pops out '-register' is not recognized as an internal or external command, operable program, or batch file.
Am I making a silly mistake here?
Thanks!
ShivaniK_Intel
Password-based authentication, as well as all the related options (-register in particular), are removed in the Intel MPI 2021.9 release.
The user authentication process has changed, hydra_service is only necessary for domain-based authentication, refer to the manual for details.
https://www.intel.com/content/www/us/en/developer/articles/release-notes/mpi-library-release-notes-windows.html
Also, you may find in our prerequisite steps that there is no need to install the service unless domain-based authentication is used
https://www.intel.com/content/www/us/en/docs/mpi-library/developer-guide-windows/2021-6/prerequisite-steps.html
Basically, we may recommend just installing and running IMPI without any extra prerequisite steps.
Thanks & Regards
Shivani
zhzhu1218
ArpanB_Intel
Hi Zhengren, please share the below information with us:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Screenshots of the error screen
- Installation Log files.
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
We would like to know.
zhzhu1218
Thanks for the response Arpan! Here are the info:
- Microsoft Windows 10
- Online installer
- VS 2022, 17.6.2
- oneAPI base toolkit and oneAPI HPC. Both the latest version (installed this week). I used to use the MPI library from Intel Parallel Studio XE, but have uninstalled it before installing oneAPI
- The error is as shown in the second half of this image when I try to register mpiexec here:
- Attached the log files here
ArpanB_Intel
Zhengren, thank you for the information.
We will move the thread to the relevant forum for further support.
ShivaniK_Intel
We are working on this issue and will back to you soon.
Thanks & Regards
Shivani
ShivaniK_Intel
Thanks & Regards
Shivani
ShivaniK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
