Intel® MPI Library
2275 Discussions
compile / configuree HDF5 v. 1.12.2 with Intel Fortran; compiles etc., but uses GNU compiler
hjm_els
General Problem:
When trying to compile / configure HDF5 v. 1.12.2 with the Intel compiler it does so, however, with the GNU compiler
Operating System: Linux Mint 20.2
script run for compile etc.:
sudo su
source /opt/intel/oneapi/setvars.sh > /dev/null 2>&1
FC=mpiifort
FCFLAGS="-I/opt/intel/oneapi/mpi/2021.7.0/include -L/opt/intel/oneapi/mpi/2021.7.0/lib/release -L/opt/intel/oneapi/mpi/2021.7.0/lib -g -fPIC -O3 -xsse4.2 -lgfortran -nofor-main" ./configure --prefix=/usr/local/hdf5/1.12.2 --enable-parallel --enable-fortran --enable-build-mode=production
make
export I_MPI_FABRICS=ofi
make check
make install
Some output:
file config.log
checking for config linux-gnu... found
compiler 'mpicc' is GNU gcc-9.4.0
compiler 'mpif90' is GNU gfortran-9.4.0
compiler 'g++' is GNU g++-9.4.0
However from the command line:
mpif90 -v
mpif90 for the Intel(R) MPI Library 2021.7 for Linux*
Copyright Intel Corporation.
Using built-in specs.
COLLECT_GCC=gfortran
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/9/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:hsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
My suspicion:
Possibly something is bad with the Intel installation (worried about COLLECT_GCC=gfortran), but may well be something else.
So I ask:
Can anybody help?
JohnNichols
Valued Contributor III
The HDF Group offers several levels of support services, including documentation and the HDF Forum, the HDF Help Desk's Service Desk and email support, and support packages and consulting
Best bet as they have an email service. The chances someone here used such an obscure pacakage is limited.  Go to the experts.
Barbara_P_Intel
I'm moving this to the HPC Toolkit Forum. That's the best place for MPI questions.
