Intel® MPI Library
cross-compilation
kazue_m_
I would like to buy Parallel Studio XE if cross-compilation is possible.
I generate execution modules of 2 GB or more.
I actually compiled on Linux. And I confirmed that it is possible.
However, I need to do the execution on windous. Is this possible? I tried various options. However, good results were not obtained.
Please tell me whether it is possible or impossible. If you can, please let me know the procedure.
Thank you.
TimP
No, Intel compiler products don't support compiling on linux for Windows target, although that is a frequent usage of gnu compilers, and was also an intended usage of Wine.  I believe there no longer is compilation on 32-bit Windows for 64-bit Windows target.
Depending on your needs, it is possible to run Intel compilers with cygwin or similar framework so as to have a posix scripted build setup.
