Intel® MPI Library
2285 Discussions
file not present or wrong filename - when using >=4 procs
Wee_Beng_T_
I have an intel i7-4770 cpu.
Running my CFD simulation code using 1 - 3procs works well. However, when using >=4 procs, I almost always get 2 lines of the error:
file not present or wrong filename.
Occasionally, I can get the code working, but it's like 1 out of 20 tries, although it can be quite random.
I guess it has to do with some file opening:
do ijk=0,num_procs-1
    call MPI_Barrier(MPI_COMM_WORLD,ierr)
    if (ijk==myid) then
        open (unit = 44 , FILE = "ibm3d_input.txt" , status = "old", iostat = openstatus(4))
        if (openstatus(4) > 0) then
            print *, "file not present or wrong filename."
            stop
        end if
        read (44,nml = solver_input)
It happens also when I simply use:
on all procs.
Do I have to use mpi commands like MPI_FILE_OPEN for file opening?
Or how do I avoid this problem?
Thanks!
Artem_R_Intel1
Hello Wee Beng,
As far as I see you use relative path to ibm3d_input.txt - is the problem reproducible with the absolute path?
Wee_Beng_T_
Hi Artem,
Do you mean this:
open (unit = 44 , FILE = "C:\obj_tmp\ibm3d_IIB_mpi\ibm3d_input.txt" , status = "old", iostat = openstatus(4))
I still get:
Press any key to continue . . .
Steve_H_Intel1
Wee Beng:
1) What does the data type declaration of the "openstatus" variable look like?
2) What is the value of "openstatus(4)"  when you are getting the "file not present or wrong filename." diagnostic message in your program fragment:
Thank you,
-Steve
Wee_Beng_T_
Hi Steve,
openstatus is defined as:
integer :: openstatus(6)
The error actually occured here:
open (unit = 55 , FILE = "output.txt" , status = "replace", iostat = openstatus(4))
    print *, "output file not present or wrong filename."
    print *, myid,openstatus(4)
    stop
end if
close (55)
I got :
          1          38
Enter new start
Sometimes myid = 2 or 0 also appears giving:
           0          38
           1          38
The error number is 38, which is related to REWIND error.
What does this means?
Steve_H_Intel1
Wee Beng:
You may want to visit the URL:
     https://software.intel.com/en-us/node/526160
and insert, where appropriate, calls to "ERRSNS" to see if there is an OS error code that is provided.
-Steve
