Intel® MPI Library
2300 Discussions
forrtl: error (78): process killed (SIGTERM)
aernst
Hi:
I get the following runtime error on our Beowulf cluster with an parallel MPI Code compiled with ifort:
PSIlogger: Child with rank 0 exited with status 1.
PSIlogger: done
How can I find out more about this error, where and why it occurs? Debugging works not for the parallel code for some reason.
Thanks in advance,
Andreas
Andrey_D_Intel
Hi Andreas,
What MPI implementation do you use? Does this code work correctly when compiled with other compiler?
Andrey
