Intel® MPI Library
mpd error
ashruakkodegmail_com
Dear Sir,
Whne I try to run the below the command I have been receiving the following error
mpdboot -n 3 -f /root/mpd.hosts -r ssh
mpdboot_hpcmas02.kfupm.edu.sa (handle_mpd_output 883): Failed to establish a socket connection with hpc073:55160 : (111, 'Connection refused')
mpdboot_hpcmas02.kfupm.edu.sa (handle_mpd_output 900): failed to connect to mpd on hpc073
here mpd is running
passwordless ssh is ok with all clients
/tmp has write permission to the user
Could you please give a help for me.What is the reason for this error.
When I run the program I have been getting this error.
mpirun -r ssh ./naba.exe
mpdboot_hpcmas02.kfupm.edu.sa (handle_mpd_output 892): failed to ping mpd on hpc073; received output={}.
Kindly help us... Please
Iam looking froward from you.
HPC Linux
KFUPM
Dmitry_K_Intel2
Could you please provide the following information:
1) mpiexec -V
2) cat /root/mpd.hosts
3) ssh hpc073 (and ps ux on this node)
4) ssh to another node (and ps ux)
5) mpirun -r ssh -f /root/mpd.hosts -n 3 -d
Do you have a firewall?
Regards!
Dmitry
