Intel® MPI Library
mpdboot is not working
Vijay_Amirtharaj_A
We are installing new cluster.i installed composer_xe_2011_sp1.6.233.
While checking mpdboot.It's failing to lainch mpdboot.
I am usint this command to launch mpdboot. mpdboot -n 2 -r ssh -f ~/mpd.hosts
Error message coming like this.
mpdboot_taavare.tuecms.com (handle_mpd_output 958): failed to ping mpd on n0.tuecms.com; received output={}
mpdboot_taavare.tuecms.com (handle_mpd_output 960): Please examine the /tmp/mpd2.logfile_bala log file on each node of the ring
[bala@taavare ~]$ cat /tmp/mpd2.logfile_bala
logfile for mpd with pid 12206
taavare.tuecms.com_40561 (handle_rhs_input 2864): connection with the right neighboring mpd daemon was lost; attempting to re-enter the mpd ring
taavare.tuecms.com_40561 (reenter_ring 1072): reenter_ring returned 0 after 1 tries
taavare.tuecms.com_40561 (handle_rhs_input 2871): the daemon successfully reentered the mpd ring
what is the problem.please guide us
Vijay Amirtharaj A
James_T_Intel
Hi Vijay,
Check your /etc/hosts file and make certain that the IP addresses of the hosts in mpd.hosts are correct.
Also, I would suggest using Hydra instead of MPD.  There are several ways to use Hydra.  As of Version 4.0 Update 3 of the Intel® MPI Library, using mpirun will default to Hydra rather than MPD.  You can set I_MPI_PROCESS_MANAGER=hydra to specify Hydra for versions after Version 4.0 Update 1.  Or you can explicitly call mpiexec.hydra instead of mpiexec.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
Mostafa_N_
I have a corrupted MPD on my machine. Whenever I call any of the commands "mpdtrace" or "mpdallexit" I get the following message:
mpdroot: cannot connect to local mpd at: /tmp/mpd2.console_root
probable cause: no mpd daemon on this machine
possible cause: unix socket /tmp/mpd2.console_root has been removed
mpdtrace (__init__ 1524): forked process failed; status=255
I have my mpd running:
mpd&
ps -ef | grep mpd
Note: I am running on my own machine! Single Node, Quad core (intel i7 core)
Any helps would be appreciated.
James_T_Intel
Hi Mostafa,
What version of the Intel® MPI Library are you using?  If you are using at least version 4.0, I would recommend avoiding using MPDs and instead use Hydra.  As of Version 4.0 Update 2, using mpirun will default to Hydra.  With Hydra, you can simply launch your job, without needing additional daemons running beforehand.
Sincerely,
James Tullos
