Intel® MPI Library
2286 Discussions
mpi FORTRAN program hanging at mpi_recv
galli_m
I am just starting in MPI.
Here is part of a FORTRAN PROGRAM I have.
CCCCCCCCCCCCCCCCCCCCCCCCCCCC
c Laplace calculation - tasks divided on all processors
1 nt=1
if (my_rank.eq.0) then
np=mp
else
np=my_rank
endif
nts=ntasks(np,nt)
nte=ntaske(np,nt)
do 55 m=nts,nte
nod14=nod14t(m,nt)
i=nim(nod14)
j=njm(nod14)
nbcv=nbc(i,j)
if (nbcv.eq.0) then
te=t(i+1,j)
tw=t(i-1,j)
tn=t(i,j+1)
ts=t(i,j-1)
t(i,j)=0.25d0*(te+tw+tn+ts)
go to 50
endif
if (nbcv.eq.2) then
t(i,j)=t(i-1,j)
endif
50 if (my_rank.eq.0) go to 55
call mpi_send(t(i,j),1,MPI_DOUBLE_PRECISION,0,1, ! send to master
* MPI_COMM_WORLD,ierr)
55 continue
write(*,*) 'my_rank=',my_rank
IF (my_rank.eq.0) THEN
do 62 nproc=1,nsize-1
nts=ntasks(nproc,nt)
nte=ntaske(nproc,nt)
do 60 m=nts,nte
nod14=nod14t(m,nt)
i=nim(nod14)
j=njm(nod14)
write(*,*) nproc,m,i,j
call mpi_recv(t(i,j),1,MPI_DOUBLE_PRECISION,nproc,1, ! master receive
* MPI_COMM_WORLD,status,ierr)
60 continue
write(*,*) 'nproc=',nproc
62 continue
endif
The output is as follows...
OOOOOOOOOOOOOOOOOOOOOOOOOOOO
>mpiexec -np 12 laplace
my_rank= 3
my_rank= 2
my_rank= 7
my_rank= 1
my_rank= 10
my_rank= 11
my_rank= 5
my_rank= 9
my_rank= 0
1 1 1 1
1 1 1 1
1 2 3 1
my_rank= 4
my_rank= 8
my_rank= 6
It goes through all the calculations and mpi_send's
but hangs after the second call to mpi_recv. I have
been trying to figure this out through a long search
but I am still missing something fundamental here.
Your help would be appreciated.
galli_m
I believe I resolved this issue...
I Broadcast all required user inputs prior to the calculation section.
Now, I sweep through all 'tasks' (nt=1-4).
After it completes the first iteration (and executes "go to 1")
the program idles again.
I cannot figure out why...
The latest code is attached.
Thanks again.
ShivaniK_Intel
If possible could you please provide the complete reproducer code so that we can investigate more on your issue?
Also, please share the below details:
OS version
MPI version
Thanks & Regards
Shivani
galli_m
The full code is attached. This simple code is a
development step to eventually converting a 3D CFD
code from serial to parallel.
I'm running this on Windows 10 Pro with
Intel Core I5-10600K 6-Core, 12-Thread desktop.
I am using Intel Visual Studio, Intel oneAPI Base
and HPC...
Thank you for your help.
For the problem at hand....
I know that if I were transferring text between
processors I would first write to
write(greeting,*) ...
and then send and receive 'greeting' back and forth
call mpi_recv(greeting,...
call mpi_send(greeting,...
This makes the master wait to receive messages
from other processors. How do I do this in the
current code?
galli_m
Thanks again.
ShivaniK_Intel
We are glad that your issue has been resolved.
Could you please let us know if there is anything else that we can help you with? If no, could you please confirm whether we can close this thread?
Thanks & Regards
Shivani
galli_m
Please close this thread.
Thank you.
ShivaniK_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Thanks & Regards
Shivani
