Intel® MPI Library
2300 Discussions
mpi calling external mpi program failed
balabi_b_
I tried to use MPI to parallel running external command line program.
So I write `run.f90`
    program run
          use mpi
          implicit none
          integer::num_process,rank,ierr;
          call MPI_Init(ierr);
          call MPI_Comm_rank(MPI_COMM_WORLD, rank,ierr);
          call MPI_Comm_size(MPI_COMM_WORLD, num_process,ierr);
          call execute_command_line('./a.out')
          call MPI_Finalize(ierr);
    end program
I compile it using intel compiler like
 mpiifort run.f90 -o run.out
Now if `./a.out` is normal non-MPI program like
program test
    implicit none
    print*,'hello'
    end
then
    mpiexec.hydra -n 4 ./run.out
works fine.
However, if `./a.out` is also a MPI program like
    program mpi_test
              use mpi
              implicit none
              print*,rank
        end program
Then, I got error after running "mpiexec.hydra -n 4 ./run.out"
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 19519 RUNNING AT i02n18
=   EXIT CODE: 13
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
=   PID 19522 RUNNING AT i02n18
=   EXIT CODE: 13
   Intel(R) MPI Library troubleshooting guide:
What is wrong?
