Intel® MPI Library
mpi shared memory problem
Dmitrii_rus
I have some problems with Intel mpi , so  I wrote the dumbest program:
#include "mpi.h"
#include <iostream>
int main(int argc, char** argv)
std::cout << "prog_start \n";
MPI_Init(&argc, &argv);
std::cout << "prog_body \n";
MPI_Finalize();
std::cout << "prog_end \n";
return 0;
and configured with VS2019.
If I run it through VS2019, then everything is in order and works as it should. But if i run through the console
(c:\ ...\mpiexec.exe -n 2 -print-all-exicodes c:\<path_to_file>\file.exe )
then i get this:
VarshaS_Intel
We tried to reproduce your issue, but we were able to get the expected results. Below are the configurations and screenshots of the results.
Operating System: Windows 10
OneAPI version - 2021.4
Microsoft Visual Studio - 16.10.3
Could you please let us know the OS details, Intel MPI version, and Microsoft Visual Studio version you are using?
Thanks & Regards
Varsha
Dmitrii_rus
I figured out that VS automatically launches the file "C: \ Program Files (x86) \ Intel \ oneAPI \ setvars.bat". If in one cmd session (with admin privileges !!!) you first run this file, then the program, then everything works. however, if you do this in cmd without admin privileges, then nothing is displayed.
OneAPI  Version 2021.4 Build 20210831
Microsoft Visual Studio - Version 16.11.5
VarshaS_Intel
Yes we need to initialize the Intel oneAPI environment using the script file(setvars.sh). Glad to know that your issue is resolved. Could please let us know if we can close this thread?
Thanks & Regards
Varsha
VarshaS_Intel
We have not heard back from you. From the screenshot provided by you, we can see you are able to get the expected results. So, we are going ahead and closing this thread. If you need further assistance, please post a new question.
Thanks & Regards
Varsha
