Intel® MPI Library
2302 Discussions
mpirun not recognizing all processors
Joao_Pascon
Hello everyone!
I am trying to run a simple fortran code with MPI. I am using Windows 11, Visual Studio 2022 and I have already installed the Intel oneAPI Base Toolkit and the Intel oneAPI HPC Toolkit.
The code is below:
program MPI_test_2
implicit none
include 'mpif.h'
INTEGER :: MY_RANK, NPR, LOCAL_N, SOURCE, DEST, TAG,
# STATUS(MPI_STATUS_SIZE), IERR
CALL MPI_INIT(IERR)
CALL MPI_COMM_RANK(MPI_COMM_WORLD, MY_RANK, IERR)
CALL MPI_COMM_SIZE(MPI_COMM_WORLD, NPR, IERR)
write (*,*) my_rank, NPR
CALL MPI_FINALIZE(IERR)
stop
end program MPI_test_2
The VS compiles correctly. However, when I try to run the program in the Command Prompt (mpirun -np 4 ./Test2, for example), the result is always the same, as if there was only one processor:
0 1
2 1
3 1
1 1
My PC has 8 cores and 16 processors. I have already checked the number of processors in Advanced Options of System Configuration, and also with CPU ID program.
Sincerely
João Paulo Pascon
University of São Paulo
HemanthCH_Intel
We can successfully run the sample fortran program(mentioned in the above post) on the windows command prompt and Visual Studio using Intel MPI 2021.6 as shown below screenshots.
Using Command prompt:
Using Visual studio:
Could you please try the below steps in the command prompt:
1) open Intel oneAPI command prompt.
2) compile the code using the below command:
mpiifort filename.f90
3) Run the binary using the below command:
mpiexec -n <no of processess> filename.exe
If your error still exists, Could you please provide the below information to investigate more on your issue:
1) Intel one API command prompt output when you run the sample code.
2) Expected output(VS output).
2) MPI Version.
3) Complete debug log in the command prompt using the below command.
I_MPI_DEBUG=10 mpiexec -n <no of processess> filename.exe
Thanks & Regards,
Hemanth
HemanthCH_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Hemanth
HemanthCH_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Hemanth
