Intel® MPI Library
mpitune
jon
For our 128 node cluster, is it necessary to run mpitune for 1 node, 2 nodes, ... , 127 nodes, 128 nodes; or is it sufficient to run it once for all 128 nodes?
Gergana_S_Intel
Hi jon,
Running once on all 128 nodes will be sufficient. The mpitune utility uses the Intel MPI Benchmarks (IMB) to determine the best cluster settings. IMB itself makes sure to run over all proc sets: 1, 2, 4, ... up to 128 procs.
For example, running the Bcast benchmarks over 8 nodes would yield:
# Benchmarking Bcast
# #processes = 2
# ( 6 additional processes waiting in MPI_Barrier)
then
# #processes = 4
# ( 4 additional processes waiting in MPI_Barrier)
then
# #processes = 8
Each one of those for varying size messages.
Hope this helps.
~Gergana
Gergana_S_Intel
Hi jon,
# #processes = 2
then
# #processes = 4
then
# #processes = 8
Hope this helps.
~Gergana
jon
Gergana,
I also had the impression that mpitune ran the benchmark suite for process counts of 1 to the number specified with -np, but it appears that the default rules.xml file runs the benchmarks only for the maximum number of processes. The relevant lines in rules.xml are all of the form
cmd_line = "IMB-MPI1 -npmin %procs% Sendrecv"
and when I run mpitune with logging enabled (with --logs), the log files indicate that the mulitnode tests are run only with the maximum number of processes.
Even so, it's not clear to me whether or not mpitune needs to be run with every possible process count, or if the values generated running with the maximum number of processes are good enough for other process counts.
Jon
