Intel® MPI Library
negative memory allocation
fjose
I am trying to run a circulation model, ADCIRC, in an intel cluster. The program was compiled fine and when it comes to pre-process the input files (grid file and control file) following message resulted
from alloc_main1:
memory currently allocated = -1070453336 bytes
memory high water mark = 17103640 bytes
The code is written in FORTRAN 90 and I couldn't understand how this -ve memory allocation run-time error can be addressed.
Any solution?
TimP
As Fortran doesn't support unsigned numbers, if a number representing more than 2GB is displayed as a 32-bit formatted integer, it could well go into apparent negative territory. One would be suspicious whether the application has been tested in that mode.
