Intel® MPI Library
nested MPI application
jinliang_w_
Hi there,
I have a MPI application, say p1.exe, compiled with command,
mpiifort p1.f90 /Od /Qopenmp /link
The program receives a parameter from command line in runtime, p1.exe SRN:n. When n=1, the MPI is initiated by
CALL MPI_INIT(I)
CALL MPI_COMM_RANK(MPI_COMM_WORLD, ThreadID, I)
CALL MPI_COMM_SIZE(MPI_COMM_WORLD, NumThreads, I)
Otherwise,  MPI is NOT initiated and NOT used.
Now I have a 2nd MPI application which always initiates and uses MPI. The line of code in p2.f90 that calls p1.exe is
call system("p1.exe SRN:0")
However, this does not work. When I run p2.exe, I got the error messages
PMI_ConnectToHost failed: unable to post a connect to ...
MPIDU_Sock_post_connect(1200): unable to connect to...
It seems to me that MPI is still invoked in P1.exe and therefore there is a clash of MPI between P1 and P2. This is weird as no MPI is initiated at runtime when n is set to 0.
When P1.f90 is compiled without MPI (e.g. ifort p1.f90), then it works.
Any help?
Michael_Intel
I am not sure if this scenario is covered by the MPI standard, therefore I will check this and get back to you.
In the meantime you might want to try linking the p1 application statically and see if you observe any different behaviour.
Michael
jinliang_w_
Thank you for the looking into this, Michael!
I have tried linking the P1 application statically, it still does not work (with the same error message).
Michael_Intel
It seems that the launch of another application via system commands are not supported, since the child- program won't see the MPI environment of the parent application. If you need to implement such functionality, please look into the dynamic process support of the MPI standard.
Michael
jinliang_w_
Thank you, Michael! That means I have to rewrite the code.
Michael_Intel
Unfortunately - yes
