Intel® MPI Library
nested mpirun commands
okkebas
   I have an mpi program that calls another mpi program (written by someone else) using a fortran system call
driver.f90
call MPI_INIT(..)
system('mpirun -np 2 ./mpi_prog.x')
call MPI_FINALIZE(...)
When I run it (e.g. mpirun -np 4 ./driver.x) it crashes inside mpi_prog.x (at a barrier). When I build it using mpich it works fine though. Any hints on what might be wrong (I realize nested mpirun's are completely beyond the mpi standard and highly dependent on implementation)
NOTE: when I do something like:
mpirun -hosts hostA,hostB -perhost 1 -np 2 mpirun -np 4 hostname
it works perfectly fine and returns the correct output.
John_D_6
good that you realize that this violates the MPI standard in so many ways.
Luckily, there is a solution in MPI-2 and it's called MPI_COMM_SPAWN:
integer ierr,intercomm
integer errcodes(2)
call MPI_COMM_SPAWN("./mpi_prog.x","",2,MPI_INFO_NULL,0,MPI_COMM_WORLD,intercomm,errcodes,ierr)
if (.not.all(errcodes.eq.MPI_SUCCESS)) then
  print*,'Error!'
  call MPI_Abort(MPI_COMM_WORLD,1,ierr)
endif
Quite some magic happens in the MPI_Init routine, so I expect your NOTE seems to work fine because you're not running an actual MPI-program.
