Recently I use oneapi 2021.4 to build petsc on MAC OS and fail with this error ld: file not found: @rpath/for_mac_ftn_alloc.dylib for architecture x86_64, can anybody fix this problem. By the way, I also found in the Google somebody has the same problem with oneapi 2021.3 and succeeds with oneapi 2021.2, where can I find the download link of oneapi 2021.2?
Could you please provide the MacOS version and which MPI you are using?
And also, could you please provide complete steps to reproduce the issue at our end?
Thanks & Regards
Varsha
Hi, after adding the variable C_INCLUDE_PATH and CPP_INCLUDE_PATH, I solved the last head files include problems. But when I re-build petsc with Mac OS 10.15.7 and oneapi 2021.4, I encounter the same configure problem, see below
Executing: /opt/openmpi/bin/mpif90 -o /var/folders/p6/25h5ftyd03zcsk5r59hcq2z00000gn/T/petsc-q27o440r/config.setCompilers/conftest -Wl,-bind_at_load -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -fPIC -g -O0 /var/folders/p6/25h5ftyd03zcsk5r59hcq2z00000gn/T/petsc-q27o440r/config.setCompilers/conftest.o -ldl -Wl,-rpath,/opt/openmpi/lib -L/opt/openmpi/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/mac/compiler/lib -Wl,-rpath,/opt/intel/oneapi/tbb/2021.4.0/lib -L/opt/intel/oneapi/tbb/2021.4.0/lib -Wl,-rpath,/opt/intel/oneapi/mkl/2021.4.0/lib -L/opt/intel/oneapi/mkl/2021.4.0/lib -Wl,-rpath,/opt/intel/oneapi/ippcp/2021.4.0/lib -L/opt/intel/oneapi/ippcp/2021.4.0/lib -Wl,-rpath,/opt/intel/oneapi/ipp/2021.4.0/lib -L/opt/intel/oneapi/ipp/2021.4.0/lib -Wl,-rpath,/opt/intel/oneapi/dnnl/2021.4.0/cpu_iomp/lib -L/opt/intel/oneapi/dnnl/2021.4.0/cpu_iomp/lib -Wl,-rpath,/opt/intel/oneapi/dal/2021.4.0/lib -L/opt/intel/oneapi/dal/2021.4.0/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/mac/compiler/lib -L/opt/intel/oneapi/compiler/2021.4.0/mac/compiler/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -lifport -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -lifcoremt -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -limf -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -lsvml -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -lipgo -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2021.4.0/mac/bin/intel64/../../compiler/lib -lirc -lpthread -Wl,-rpath,/Library/Developer/CommandLineTools/usr/lib/clang/12.0.0/lib/darwin -L/Library/Developer/CommandLineTools/usr/lib/clang/12.0.0/lib/darwin -lclang_rt.osx -ldl
Possible ERROR while running linker: exit code 1
stderr:
Linker output before filtering:
Also, my configure option and complete configure files are the same as before. In short, with the compatible Mac OS version of oneapi 2021.4, I still cannot solve my initial problem...
Dear Varsha,
Thanks for your responding.
My Mac OS version is 11.6, and I succeeded in installing openmpi 4.0.2 with configuration ../configure --prefix=/opt/openmpi CC=icc CXX=icpc F77=ifort FC=ifort. I attach my shell screenshot and configure.log below when building petsc.
Xiangyi
To access older releases you need a version that includes Intel Priority Support, the free versions do not include this.
Here is a link to the online store where you can get a commercially supported version https://softwarestore.intel.com/
Sorry for the inconvenience MacOS 11.6 is not supported as of now with the latest Intel oneAPI toolkit try using the supported versions and let us know if you are still facing any issues. Could you please refer to the below link for the supported versions of the Intel oneAPI toolkit.
Thanks & Regards
Varsha
thanks for your answers. Actually, I choose to degrade my Mac OS to 10.15.7 and my Xcode version is 12.4 now. After installing oneapi 2021.4 and compiling the c++ source file, I got this error
In file included from /Library/Developer/CommandLineTools/usr/bin/../../usr/include/c++/v1/iosfwd(95),
from /Library/Developer/CommandLineTools/usr/bin/../../usr/include/c++/v1/ios(214),
from /Library/Developer/CommandLineTools/usr/bin/../../usr/include/c++/v1/iostream(37),
from main.cpp(1):
/Library/Developer/CommandLineTools/usr/bin/../../usr/include/c++/v1/wchar.h(118): catastrophic error: cannot open source file "wchar.h"
#include_next <wchar.h>
compilation aborted for main.cpp (code 4)
I seems that compiler cannot find the head files but they are just there, do you know how to solve this new problem, thanks in advance.
progress for my issue....
I have found the specific issue of my problem, That is when I use ifort to compile .f90 file and link the dynamic libraries libifport.dylib and libifcoremt.dylib, then the link errror will generate
so how can we solve this?
sorry, it is mpifort instead of ifort. I can successfully building petsc directly using icc, icpc and ifort, but failed with openmpi which was build by oneapi and with above errors.
Thanks for providing all the information.
I hope your issue is resolved. These forums are intended to support the queries related to Intel Products. We do not support OpenMPI. Please let us know if you have any issues with the Intel compilers, if not can we go ahead and close this thread.
Thanks & Regards
Varsha
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards
Varsha
