Intel® MPI Library
pmi_proxy: Command not found
Mohab_Mahfouz
Hello I am very new to this, I installed the MPI fortran and it was working properly but all of a sudden, i am now getting the following errors. can anyone please help
thank you
: mpirun -np 30 ./a.out
/product/Fortran_MPI/intel64/bin/pmi_proxy: Command not found.
Ctrl-C caught... cleaning up processes
[press Ctrl-C again to force abort]
[[email protected]] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:101): one of the processes terminated badly; aborting
[[email protected]] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:18): bootstrap device returned error waiting for completion
[[email protected]] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:521): bootstrap server returned error waiting for completion
[[email protected]] main (./ui/mpich/mpiexec.c:548): process manager error waiting for completion
I moved your thread to the clustering technology forum as it is not an Intel Fortran issue - this error comes from MPICH.
James_T_Intel
Hi Mohab,
What is the value of the environment variable I_MPI_ROOT? Did you source the appropriate mpivars script (usually in /opt/intel/impi//intel64/bin/mpivars.sh)?
Sincerely,
James Tullos
Technical Consulting Engineer
Intel Cluster Tools
Mohab_Mahfouz
This is the values of the I_MPI_ROOT in my /product/Fortran_MPI/intel64/bin/mpivars.csh
setenv I_MPI_ROOT /product/Fortran_MPI
setenv PATH $I_MPI_ROOT/intel64/bin
setenv PATH $I_MPI_ROOT/intel64/bin:$PATH
setenv LD_LIBRARY_PATH $I_MPI_ROOT/intel64/lib
setenv LD_LIBRARY_PATH $I_MPI_ROOT/intel64/lib:$LD_LIBRARY_PATH
setenv MANPATH $I_MPI_ROOT/man:`manpath`
setenv MANPATH $I_MPI_ROOT/man:$MANPATH
[44] /product/Fortran_MPI :
James_T_Intel
Hi Mohab,
What do you get from running the command:
[bash]mpirun -n 30 hostname[/bash]
Sincerely,
James Tullos
Intel Cluster Tools
Mohab_Mahfouz
When i execute mpirun -n 30 hostname i responds the output below and does not return me a prompt.
l1aebshpc2.bank-banque-canada.ca
and just hangs there i do not get a prompt back
I have also attached the Verbose output if that might help
James_T_Intel
Hi Mohab,
It appears that l1aebshpc3 is not finding the MPI bin folder. What is the output from
[bash]ls /product/Fortran_MPI/intel64/bin[/bash]
On that node?
Sincerely,
James Tullos
Intel Cluster Tools
Mohab_Mahfouz
Wow now i feel silly the mount was not present, I mounted the /product and when executing the mpirun -n 30 hostname it is working. When i run my test a.out seems to be working too.
thank you very much.
James_T_Intel
Hi Mohab,
Good to hear everything is working now. Feel free to let us know if you have any further concerns.
Sincerely,
James Tullos
Intel Cluster Tools
Feedback on my support? https://premier.intel.com/premier/feedback.aspx
Online assistance: http://support.intel.com/support/performancetools/
User forums: http://softwareforums.intel.com/
Product support info: http://www.intel.com/software/products/support
Giuseppe_P_
Hello! I have built open mpi 1.6 with Intel compilers (2013 versions). Compilation was smooth, however even when I try to execute the simple program hello.c: mpirun -np 4 ./hello_c.x [[email protected]] HYDU_create_process (./utils/launch/launch.c:102): execvp error on file /opt/intel/composer_xe_2013.0.079/mpirt/bin/intel64/pmi_proxy (No such file or directory) [[email protected]] HYD_pmcd_pmiserv_proxy_init_cb (./pm/pmiserv/pmiserv_cb.c:1177): assert (!closed) failed [[email protected]] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [[email protected]] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:358): error waiting for event [[email protected]] main (./ui/mpich/mpiexec.c:689): process manager error waiting for completion Before that, there was an additional error, since even the file mpivars.sh was not present in /opt/intel/composer_xe_2013.0.079/mpirt/bin/intel64/. Even though I managed to create one and it worked, I do not have any clue about how to generate the file pmi_proxy. Thank you in advance for your help!
Gergana_S_Intel
Hey Guiseppe, The Intel compilers use the Intel MPI runtimes for their Co-Array Fortran implementation. Because of that, they bundle the Intel MPI runtimes with each installation. This what you're seeing here. Because you've only sourced the compilervars.{csh, sh} file, the only MPI library you're picking up is the Intel MPI runtimes (which requires the use the pmi_proxy script). If you'd like to use Open MPI instead, you need to set your PATH and LD_LIBRARY_PATH env variables so those scripts are picked up by default. We provide the compilervars and mpivars scripts for our Intel Compiler and Intel MPI Library respectively but I don't believe Open MPI has anything similar. You simply have to make sure you add the path to the Open MPI 'mpirun' command to PATH, as follows:
$ export PATH=:$PATH
Let us know how that works. Regards, ~Gergana
Gergana_S_Intel
Sorry, I think my command got broken when I posted. Here it is:
$ export PATH=path_to_OpenMPI_mpirun:$PATH ~Gergana
Giuseppe_P_
Hi Gergana, thank you for your help. Unfortunately, adding to the PATH shell variable the location of mpirun did not help. And anyway, it was already in the PATH, since mpirun was installed in /usr/local/bin. It seems as open mpi compiled with Intel compiler is still looking for the file pmi_proxy. As I mentioned before, it was also looking for mpivars.sh but then I added the following mpivars.sh to /opt/intel/composer_xe_2013.0.079/mpirt/bin/intel64/: #!/bin/bash if [ -z "`echo $PATH | grep /usr/local/bin`" ]; then export PATH=/usr/local/bin:$PATH fi if [ -z "`echo $LD_LIBRARY_PATH | grep /usr/local/lib`" ]; then if [ -n "$LD_LIBRARY_PATH" ]; then export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH else export LD_LIBRARY_PATH=/usr/local/lib fi fi I am also attaching the file config.log that was generated before compiling open mpi.
