Intel® MPI Library
2287 Discussions
"dapl fabric is not available and fallback fabric is not enabled"
Huang__Jeffrey
HI Support team,
I try to use  Intel MPI  "with DAPL fabric " to run a molding simulation software on Infiniband/RDMA Fabric.
But get error - "dapl fabric is not available and fallback fabric is not enabled"
Detail info:
Cluster  nodes:
CPU: Intel Xeon E5-1620
RAM: 32 GB
NIC: Mellanox ConnectX-5 VPI adapter
Driver: WinOF-2 v2.10.50010
OS: Windows Server 2016 Standard
Test Case1:
Using Microsoft MPI - Microsoft HPC Pack 2016 Update 2 + fixes , the Results is works well on infiniband fabric.
Test Case2:
Replace MS_MPI with Intel MPI(IMPI) - Intel MPI 2018 , the Results - Get error - "dapl fabric is not available and fallback fabric is not enabled" when execute Intel MPI command. My command is as below:
Command: c:\Users\Administrator>"C:\Program Files\Intel MPI 2018\x64\impiexec.exe -genv I_MPI_DEBUG 5 -DAPL -host2 192.168.191.21 192.168.181.22 1 \\IBCN3\Moldex3D_R17]Bin\IMB-MPI1.exe
Please advise,
BRs,
Jeffrey
Dmitry_D_Intel
Hi Jeffrey,
Most likely that you don't have DAPL ND installed on your machine.
https://www.openfabrics.org/downloads/Windows/DAPL-ND/v1.4.5/
Here is an old example (unfortunately link to DAPL in the article isn't valid so I provided you the latest one above):
https://software.intel.com/en-us/articles/using-microsoft-network-direct-spi-with-intelr-mpi-library
BR,
Dmitry
