Intel® MPI Library
system call intrinsics not working when using ILP64 version of Intel MPI
John_Y_
I am using Intel MPI 5.1.2 and ifort version 16.0.1 under linux.  I have a code that uses the 'system' intrinsic to perform some file/directory manipulations that no longer works properly when using the latest version of parallel studio (it works with earlier versions). Attached is a very simple test case that illustrates the problem by attempting to create a directory either using the 'system' function of the 'execute_command_line" function.  Basically, when using the standard 4-byte mpi interface there are no issues.  However, when using the 8-byte ILP64 mpi interface, the system call fails silently and the execute_command_line function crashes the program.  Also attached is a screen shot of the test case command line run on my system.
Another issue I notice with the mpi included in the latest parallel studio is that I keep getting an 'undefined symbol: MPI_F_STATUSES_IGNORE' warning when running the test case with the ILP64 interface.  The ldd output is also shown in the screen shot.  If I perform an
                         nm /PATH/TO/libmpi_ilp64.so.4 | grep STATUSES_IGNORE
                         132:                 U MPI_F_STATUSES_IGNORE
I see that the symbol exists in the library but that it is undefined.
Steven_L_Intel1
I'm going to move this to the Clustering (MPI) forum. I don't see that it's a Fortran issue. I'll note that on Linux, EXECUTE_COMMAND_LINE just calls system.
John_Y_
I was just wondering if anybody had a chance to look at the issue described above.
John
Owen_W_
It seems like this is still an issue. I have been encountering this condition this week under the use of Intel MPI 5.1.3 and ifort 16.0.3 under Linux.
Robert_Adams
Has this issue been addressed?
I'm seeing the same issue in Intel MPI 5.1.3.
Rob
Mark_L_Intel
  I used the older versions (MPI and compiler versions ) pretty close to the ones you used but I could reproduce the issue. Can you provide the exact commands that you used to compile and run the attached a.f90? Sorry, the screenshot has rather small font
Mark
Mark_L_Intel
correction to the previous post: I meant "could NOT reproduce"
Mark_L_Intel
After little bit more tweaking, I think I was able to reproduce the issue with these commands:
-bash-4.2$ mpiifort -i8 -o test-ilp64.x test-ilp64.f90
-bash-4.2$ mpirun -ilp64 -n 1 ./test-ilp64.x
Is that how you were running your example?
Mark
John_Young
Hi Mark,
Yes, that is how I was compiling and running the program.
John
Mark_L_Intel
John,
   I talked to engineering - they asked my to submit an internal ticket (I intend to do it). I do not have the time estimate for the resolution although at this point.
If you have Intel Premier Support (IPS) account - you could submit this too through IPS - this way you can track the issue directly.
Mark
William_D_2
This still seems to be an open issue. Any ideas on when it will be fixed?
Mark_L_Intel
Let me check. What version (of Intel MPI) do you use now? Can you use the latest 2017 Update 2?
kostas_s_1
still unresolved with 2017.2 and 2017.3
Sachin_m_
Still unresolved with 2018.0.2
Sergey_Y_Intel
Please check the latest Intel MPI. Issue is fixed since 2018 Update 3.
