A error when compile Quantum Espresso 5.4
zhijian_f_
Hi all,
When I compile QUANTUM ESPRESSO 5.4 by intel mpi (2016.1.150).
There is a error:
catastrophic error: **Internal compiler error: abort signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
How I can resolve it?
Thanks!
Janko__Bayncore_
how are you compiling Quantum Espresso, what are your environment settings and flags and when does the error occur?
Did the configure pick up all the settings correctly, including MKL?
Cheers
