About lockfree_mpmc ...
aminer10
I think i have forgot something with lockfree_mpmc...
Please follow with me...
The Intel x86 memory model, detailed in Intel 64 Architecture Memory Ordering White Paper
and the AMD spec, AMD64 Architecture Programmers Manual, list a lot of memory ordering
guarantees, among them:
Loads are not reordered with other loads.
Stores are not reordered with other stores.
Stores are not reordered with older loads.
In a multiprocessor system, memory ordering obeys causality (memory ordering respects transitive visibility).
In a multiprocessor system, stores to the same location have a total order.
In a multiprocessor system, locked instructions have a total order.
Loads and stores are not reordered with locked instructions.
But since on x86 Loads may be reordered with older stores to different locations
So please take a look at the following lockfree_mpmc code:
function TLockfree_MPMC.push(tm : tNodeQueue):boolean;
var lasttail,newtemp:long;
i,j:integer;
begin
if getlength >= fsize
then
begin
result:=false;
exit;
end;
result:=true;
[1]newTemp:=LockedIncLong(temp);
[2] lastTail:=newTemp-1;
setObject(lastTail,tm);
[3]
repeat
[4] if CAS(tail,lasttail,newtemp)
then
begin
exit;
end;
sleep(0);
until false;
end;
So the the loads of lasttail and newtemp in [4] line can be reordered
with older stores of lastail and newtemp in [1] [2], so in this case must
i insert an mfence in line [3] to respect the logic of the program?...
Thank you,
Amine Moulay Ramdane.
aminer10
Hello again,
Sorry, as you have noticied there is loads on
setObject(lastTail,tm)between line [2] and line [4].
And loads are not reordered with older loads on x86
So i think there is no problemwith lockfree_mpmc.
Thank you.
Amine Moulay Ramdne
aminer10
Hello again,
setObject(lastTail,tm) between line [2] and line [4].
So i think there is no problem with lockfree_mpmc.
Thank you.
Amine Moulay Ramdne
