Any detailed reference on block vectorization?
fatalme
It seems there is little stuff on this topic when I search it on google.
Neither not much stuff in the help documentation.
Is there any way to perform explicit block vectorization using intel compiler directive or macros?
TimP
If you mean block vectorization as defined by the Intel compilers, I doubt you'll find better references than those given by the search tool on this forum. "explicit block vectorization" seems like a contradiction. If you are writing source code to improve optimization, there are better ways.
Christopher_K_
A good Intel Press book on AVX vector intrinsics in the 2nd Generation Core Processors...not sure where it's listed but you might start here: http://software.intel.com/en-us/articles/technical-books-for-multi-core-software-developers/?wapkw=(books)
- CCK
