Calling gemv BLAS level 2 routine
zokagoa
I'm interested in using the intel fortran mkl library namely in parallel coding but I have some difficulties to use the BLAS level 2 routine (for instance gemv)
I used the following project properties configuration :
1- Properties > Fortran > General > Additional Include Directories:
"mkl_directory>\\include"
2- Properties > Linker > General > Additional Library Directories
"\\em64t\\lib" (I have only ia32 and em64t folders in the mkl
directory on my computer after the intel fortran installation).
3- Properties > Linker > Input > Additional Dependencies:
mkl_intel_lp64.lib mkl_intel_thread_lp64.lib mkl_core.lib libiomp5md.lib
I also verified that the file 'mkl_intel_lp64.lib' is in the em64t folder in the mkl_directory.
But I have this error message while generating the solution:
Erreur 1: fatal error LNK1181: impossible d'ouvrir le fichier en entre 'mkl_intel_lp64.lib' (translation: impossible to open file 'mkl_intel_lp64.lib')
I think, I may have missed something with my intel fortran configuration in order to use the BLAS level2 routines.
Has someone an idea about how I could handle this ?
Thank you.
Jean-Marie Zokagoa
Ph.D student, Engineering Mechanical
Ecole de Technologie Superieure Montreal
(QC), Canada
TimP
This question might be dealt with more quickly on the Windows Fortran or MKL forums. I take it that you are using a version of Visual Studio which is supported by your ifort installer and that you have replaced by the actual installed path. I don't recognize the spelling you give for the thread library, as the choice of 32-bit integers is handled entirely by mkl_intel_lp64.lib.
I thought that the choice of OpenMP library would be handled in the specific Fortran compiler/linker options under VS, but I use the command line link more often, so I could be wrong, and anyway this doesn't appear to bear on your question.
