Can i use Peterson Lock as SMP lock??
rkmanikanta
Can i use Peterson Lock as SMP Lock, if the processor doesn't support Get-and-Set instruction?
Mani
Dmitry_Vyukov
Valued Contributor I
Yes, of course. However, then hardware has to support either sequentially-consistent memory model or #StoreLoad style memory fences.
anthony_williams
Peterson's lock was designed for precisely this scenario. However, you need to ensure that the operations become visible to the other processors in the right order. The algorithm assumes a sequentially-consistent memory model, and on some platforms this will require memory fence operations before and/or after some of the stores and loads.
You also need to bear in mind that Peterson's lock is not a replacement for a general-purpose mutex --- each thread that tries to access the critical section must have a specific ID. The basic algorithm only works with 2 specific threads, though it is possible to extend it to more.
rkmanikanta
thanks for the reply.
But how can we extend Peterson lock for N-processes?
Mani
Chris_M__Thomasson
