Chipset Identification
mavlik
ClayB
Mavlik -
Does this have a GUI interface or can you get text output from the utility? If the latter, could you not launch the utility as an external system process (from within the C++ code), dump the data to a file, and have the C++ program parse the file to determine the information that you're looking for?
Or are you trying to rewrite the utility on your own with C++?
--clay
