Coarray image output to common Quickwin
Whit_D_
I have a Fortran Quickwin project that uses coarrays to run a Monte Carlo simulation.  Currently, each image updates its progress and sends messages to its own Quickwin window (default Quickwin behavior with coarrays).  Is there a way to connect all the images to a single Quickwin?  A console application connects all the images to the same standard output, and this is the behavior I'd like to emulate while still having access to the convenient screen updating/formatting in a Quickwin project.
TimP
This is more likely to get expert replies on the Intel Fortran Windows forum.
Whit_D_
Thank you.  You're probably right.  Is there a way to move the post?  The 'Forums' selection box is grayed out when I try to edit the post...
TimP
I don't think anyone but moderators can move posts or modify the original post of a thread.  This forum doesn't appear to have active moderation.
Whit_D_
Reposted as recommended: https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/624030 Got a prompt response too. Thank you!
