Execution time varies with OpenMP and Q6600
svetlana_m
I am trying to apply parallelism for an algoritm which sorts an array of 1,5 M records. I have divided the array into 4 parts and assigned each part to a core:
#pragma
omp parallel private(i,tid)
#pragma omp sections
#pragma omp section
BucketSort(A1); }
#pragma omp section
BucketSort(A2); }
#pragma omp section
BucketSort(A3); }
#pragma omp section
BucketSort(A4); }
I am running the program on Intel Quad Q6600. I found that for the sequential program the execution time is 7 milisec. For the parallel program, the execution time varies significantly from 4ms to 22ms. I wonder what is the reason for this variation because it prevents me from measuring the real speedup. I tried to set the affinity for each thread to a different core, and there was no result. Can you please help me find the reason why performance is so unstable?
Thank you,
Svetlana
jimdempseyatthecove
Svetlana,
Consider setting block time to something other than 0ms and adding a dummy parallel section to get all threads running. Then fall into parallel section you wish to time
Jim Dempsey
 long count = 0;
// dummy parallel section to get all threads running
#pragma omp parallel private(i,tid)
_InterlockedIncrement(&count);
// get start time for compute section
double startTime = omp_get_wtime( );
{ #pragma omp section
{ BucketSort(A1); }
#pragma omp section
{ BucketSort(A2); }
#pragma omp section
{ BucketSort(A3); }
#pragma omp section
{ BucketSort(A4); }
// get end time for compute section
double endTime = omp_get_wtime( );
// compute elapse time
double elapsTime = endTime - startTime;
svetlana_m
Thank you Jim,
That solved the problem. The execution time is stable now.
Svetlana
