Execution with 4 cores is slower than with 2 cores
svetlana_m
I am writing a C program, where each parallel thread executes the following code:
for(i=nStart; i
k=A.key-1;
next = new(stack_elem);
next->number=A.number;
next->prev=bstacks;
bstacks=next;
on a part of the input array A.
#pragma
omp parallel private(i,tid)
#pragma omp sections nowait
#pragma omp section
DWORD_PTR mask=(1<<0);
DWORD_PTR prevmask;
prevmask= SetThreadAffinityMask(GetCurrentThread(),mask);
BucketSort( A,0,NMAX/2,bstacks1);
#pragma omp section
DWORD_PTR mask=(1<<2);
DWORD_PTR prevmask;
prevmask=SetThreadAffinityMask(GetCurrentThread(),mask);
BucketSort( A,NMAX/2,NMAX,bstacks2);
When I measure theexecution time, it turns out that with 4 cores/4 threads, the program is slower than with 2 cores/2 threads. Thebest performance is obtained when I run the code with 2 cores that share a L2 cache.Is there a way to optimize the program when it is run with 4 cores?
Thank you,
Svetlana Marinova
jimdempseyatthecove
If each thread is performing
for each element then you should be aware that new has a critical section.
Consider the following code (I will let you work out the details for delete)
stack_elem* p_stack_elem = new(stack_elem[nEnd-nStart+1]);
if(!p_stack_elem) FixThis();
for(i=nStart; i{
k=A.key-1;
next = &p_stack_elem[i-nStart];
next->prev=bstacks;
bstacks=next;
Jim Dempsey
Dmitry_Vyukov
Valued Contributor I
svetlana_m:
for(i=nStart; i
k=A.key-1;
next->prev=bstacks;
bstacks=next;
Also watch out for false-sharing.
In this example false-sharing can occur on variables bstacks1, bstacks2.
If you have something like this:
stack_elem* bstacks1;
stack_elem* bstacks2;
Than separate variables this way:
size_t const arch_cache_line_size = 64;
char pad [arch_cache_line_size];
Or better, allocate bstacks1/bstacks2 variables directly on stacks of the threads.
This can have great impact on performance/scalability!
kasut_jepun
i'm a new beginner..
i did'nt know how to start open mp programming..
i need to do final project about serial algorithm using open mp programming..
can anyone give me any note that i can learn & practise ...
4thumore, i need to know how to write code to determined num of core in my pc..
regards...
TimP
Quoting - kasut_jepun
regards...
http://openmp.org/wp/
Better, the textbook by Chapman, Jost, van der Pas "Using OpenMP"
Did you look at my examples http://sites.google.com/site/tprincesite/levine-callahan-dongarra-vectors
There are examples in Fortran, C, and C++ (not Intel C++) of use of omp_get_num_procs(), in case you want that method to find number of cores. It's a very simple task, but it exposes bugs in gfortran and icpc. Also shown is how a program can read data from cpuinfo, on OS which present such information.
kasut_jepun
Quoting - tim18
thankz 4 the info..
i used vstudio 2005 but doesn't have intel compiler..coz just intel compiler support open mp..Am i right??
did i need to install intel compiler to running that progm?
TimP
My examples which use Microsoft C++ also require Fortran. You could use a 30 day trial version. VS2005 does support OpenMP, and it worked for me with my examples, although the documented compatibility is between VS2008 and Intel OpenMP. I set up the Windows build to compare performance of Microsoft and Intel C++, using the same Fortran driver code. Perhaps you can look at the C++ code if you are not interested in installing any compiler beyond MSVC. The C99 code won't work with Microsoft compiler unless you modify it to C89 or C++.
