Failure during collective
Sanjiv_T_
Hi ,
I have compiled espresso with intel mpi and MKL library but  getting error Failure during collective error when ever it is working fine with openmpi.
is there problem with intel mpi
Fatal error in PMPI_Bcast: Other MPI error, error stack:
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x516f460, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
MPIR_Bcast_impl(1670)...:
I_MPIR_Bcast_intra(1887): Failure during collective
MPIR_Bcast_intra(1524)..: Failure during collective
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x5300310, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x6b295c0, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x67183d0, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x4f794c0, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
[0:n125] unexpected disconnect completion event from [22:n122]
Assertion failed in file ../../dapl_conn_rc.c at line 1128: 0
internal ABORT - process 0
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x56bfe30, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
/var/spool/PBS/mom_priv/epilogue: line 30: kill: (5089) - No such process
Kindly help us for resolving this
sanjiv
TimP
You may get better answers if you post an actual example to the hpc cluster forum.  Do you consider the incompatible encoding of data types between openmpi and the mpich family a problem of intel mpi? This causes any mixing of headers or objects between mpi families to break.
Sanjiv_T_
HI Tim,
could to share to me link hpc cluster forum.
We are using only Intel mpi and MKL Library in our cluster , we are not using open mpi or mpich..
only testing purpose it compiled with openmpi.
Sanjiv
