Help
eliloji
I have a laptop with intel core 2 duo processor t6400 (intel centrino inside) i need to now how performance the 3D device i just use Autocad 2008 and i need to do renders. the programs give me this message
so what can i do
Performance Tuner Results Log
Version: 17.1.0.1
Date of Last Tune: 19/07/2009
Machine Configuration
Processor Speed : 2.0 GHz
RAM : 2939 MB
3D Device
Name : Mobile Intel 4 Series Express Chipset Family
Manufacturer : Mobile
Chip set : Intel 4 Series Express Chipset Family
Memory : 1341 MB
Driver : 7.15.0010.1502
Your machine contains a 3D Device that is not certified.
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver: Software
Current Effect Status:
Geometry acceleration: Not recommended and off
Smooth line display: Not available
Gooch shader: using software emulation
Full-shadow display: Not available
Texture compression: Not available
Available application drivers and effect support:
Software driver
Effect support:
Geometry acceleration: Not available
Gooch shader: Software emulation only
Direct3D driver: Not Certified
Effect support:
Geometry acceleration: Available
Smooth line display: Available
Gooch shader: Available
Full-shadow display: Available
Texture compression: Available
Tudor
Well there's not much you can do. I have checked the Autocad site myself and your model is indeed not fully supported. Here is an extensive faq you could read: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=6711774&linkID=9240618#section2. You might try to manually enable hardware acceleration if you're confident your card can handle it.
Btw, I don't think this is the right forum to ask your question.
