1701 Discussions
How to build serial communication with Intel Galileo ?
PENGSHEN_Y_
char number;
void setup()
Serial.begin(9600);
pinMode(13,OUTPUT);
void loop()
if(Serial.available())
number = Serial.read();
Serial.println(number);
if(number=='A')
{digitalWrite(13,HIGH);}
if(number=='B')
{digitalWrite(13,LOW);}
I want to use bluetooth (control by mobile phone) to control the pin13 LED.
I use HC-06 bluetooth model to do that , the RX of HC-06 is connect to TX of Galileo and TX of HC-06 is connect to RX of Galileo.
However it fail   , I dont know the reason but it sucessful on ARDUINO , I want to find some help
PENGSHEN_Y_
It is successful on laptop to control the LED13 , but i could not use HC-06 to control it  :(
Amr_E_1
I d have the same problem. It works with Arduino but not with Galileo. Moreover, with Galileo, I see the potentiometer reading on the serial monitor, but BT HC 06 is unable to send to my android tab
Derp_K_
Check this link
Link
