How to get number of logical cores on Windows
bharatipingale
Hi all,
Does anybody know how to get number of logical processors on windows?
I tried command GetSystemInfo(), but it gives number of physical processors.
and GetLogicalProcessorInfo() is supported 2003 SP3 onwards.
Thanks in advance,
BharatiPingale
TimP
http://stackoverflow.com/questions/188503/detecting-the-number-of-processors
Should work on all versions of Windows with threading support, including some which didn't have adequate support for HyperThreading.
Dmitry_Vyukov
Valued Contributor I
Quoting - bharatipingale
Hi all,
Thanks in advance,
I believe that GetSystemInfo() must return number of LOGICAL processors (i.e. HT processor -> 2 processors).
Unfortunately I am unable to check this right now. Are you sure that it returns number of physical procesors (i.e. HT processor -> 1 processor)?
Emmanuel_W_
Quoting - Dmitriy Vyukov
If this helps GetSystemInfo does return the number of logical processors on all my systems.
Eric_P_Intel
Quoting - tim18
If you just want the number of logical processors (currently booted/in-use by Windows), using GetSystemInfo will work. If you need to know more about the topology (packages, cores, HyperThreading), the "official" method can be found here:
http://software.intel.com/en-us/articles/intel-64-architecture-processor-topology-enumeration
Be wary of other implementations that use cpuid directly. (Using OS-provided info
i should
be ok).
- Eric
Dmitry_Vyukov
i should
be ok).
One must understand that this way is not "how to do in on Windows", it's "how to do it on x86". This won't work for Itanium. So, if one's system is otherwise portable to all Windows hardware, after employing such thick it will become x86 specific.
For Linux it is a much more serious problem, because Linux also supports SPARC, PPC, ARM, etc.
However the good news about CPUID is that it will work both on Windows and Linux (while you are on x86, and figure out how to transform asm/intrinsic syntax).
gaston-hillar
Hi bharatipingale,
I don't know which programming language you are using. However, here are some tips for three programming languages:
Java:
Runtime.getRuntime().availableProcessors();
C#:
Environment.ProcessorCount;
Visual Basic:
These return the number of logical cores on Windows and in other operating systems.
For example, if you run these lines on a computer with a quad-core Core i7 supporting Hyper-Threading, it will return 8.
Cheers,
Gastn Hillar
pvonkaenel
New Contributor III
I agree: I think GetSystemInfo() does return the number of logical processors. I wrote some code a few years ago to return various pieces of processor information which may help. As has already been mentioned, this code is x86 specific:
[cpp]//****************************************************************************
// FUNCTION: ProcCtrl::IsIntel()
// ACTION: Returns true if this is an Intel processor, otherwise false.
// EXPORT: Public
// HISTORY:
//  Date       Author              Description
// 10/25/2004   Peter von Kaenel    created
bool ProcCtrl::IsIntel()
	unsigned int reg[5];
	char *stamp;
	// Make sure this is an Intel Processor
	__asm {
		mov eax, 00h
		cpuid
		mov reg[0], eax
		mov reg[4], ebx
		mov reg[8], edx
		mov reg[12], ecx
	stamp = (char*)[1];
	stamp[12] = '�';
	if (strcmp("GenuineIntel", stamp) == 0)
		return true;
	return false;
// FUNCTION: ProcCtrl::NumProcs()
// ACTION: Return the total number of processors recognized by the OS.  If
//         hyper-threading is enabled, then a single physical processor will
//         be identified as multiple processors.
// EXPORT: Public
// HISTORY:
I32 ProcCtrl::NumProcs()
	// Get the total number of processoes in the computer
	SYSTEM_INFO sysInfo;
	GetSystemInfo(&sysInfo);
	return sysInfo.dwNumberOfProcessors;
// FUNCTION: ProcCtrl::NumPhysicalProcs()
// ACTION: Returns the number of physical processors in the computer.
// EXPORT: Public
// HISTORY:
I32 ProcCtrl::NumPhysicalProcs()
	// Get the number of logical processors per physical processor: this is
	// >1 if hyper-threading is enabled.
	I32 numLogicalProcs = NumLogicalProcs();
	// Get the total number of processoes on the system and devide it by
	// the number of logical processors per physical processor.
	return (NumProcs() / numLogicalProcs);
// FUNCTION: ProcCtrl::NumLogicalProcs()
// ACTION: Return the number of logical processors per physical processor.
//         This will be >1 if hyper-threading is enabled.  Note that this does
//         not return the total number of processors, just the number of logical
//         processors per physical processor.  Call NumProcs() to get the
//         total number of processors.
// EXPORT: Public
// HISTORY:
I32 ProcCtrl::NumLogicalProcs()
	// If this is not an Intel processor, there is no need to check further
	if (IsIntel() == false)
		return 1;
	// Determine if hyper-threading is available and enabled.  If it is, then
	// probe the number of logical processors.
	U32 regEdx, regEbx;
 	__asm {
		mov eax, 01h
		cpuid
		mov regEdx, edx
		mov regEbx, ebx
	if (regEdx & BIT(28))
		return (regEbx & 0xff0000) >> 16;
	return 1;
[/cpp]
TimP
Intel C++ is supposed to support standard C++ OpenMP syntax at the next major release, allowing use of omp_get_num_procs in a num_threads specification:
#ifdef _OPENMP
#include
#endif
#pragma omp parallel for num_threads(min(4,omp_get_num_procs()))
For now, you can write it out, C style. The Fortran equivalent to the above works, even in (linux) gfortran now.
I'm not very excited about the recommendations to use non-standard C++ syntax with processor and compiler dependent asm.
Dmitry_Vyukov
Quoting - tim18
Non-standard C++ syntax or non-standard C++ functions and extensions, what's the difference? Results is exactly the same - non-portable code. Is it possible to get standard way to get number of processors from the language which does not support multi-threading? All bets are on C++09, when ICC will support C++09 threading extensions? So that we will be able to use std::thread::hardware_concurrency().
gaston-hillar
can also help you. It uses C++ and a library to detect logical and physical cores.
I think you have a lot of options to work with!
Cheers,
Gastn
anandakumaryg
Quoting - pvonkaenel
// EXPORT: Public
// HISTORY:
	char *stamp;
	__asm {
		mov eax, 00h
		cpuid
		mov reg[0], eax
		mov reg[4], ebx
		mov reg[8], edx
		mov reg[12], ecx
	stamp = (char*)[1];
	stamp[12] = '�';
		return true;
	return false;
// EXPORT: Public
// HISTORY:
// EXPORT: Public
// HISTORY:
// EXPORT: Public
// HISTORY:
		return 1;
	U32 regEdx, regEbx;
 	__asm {
		mov eax, 01h
		cpuid
		mov regEdx, edx
		mov regEbx, ebx
	return 1;
[/cpp]
anandakumaryg
Quoting - anandakumaryg
I have tried the above sample to get the number of processor available in my PC. Now I have two processor with 8 cores per processor. My problem is m_dwNumberofprocessor and logical processor are same, so when i divide the numberofprocessor/logicalprocessor, I am getting 1. But I should get 2.
I followedd the logic given above.
Please help me out to solve this issue.
pvonkaenel
New Contributor III
I'm afraid I no longer have a multi-die computer to test this out on, but let's see what we can figure out. What exactly is being returned in sysInfo.dwNumberOfProcessors? Also, what is ProcCtrl::NumLogicalProcs() returning? I'm wondering if ProcCtrl::IsIntel() is not identifying your machine as an Intel based machine.
Peter
anandakumaryg
Peter
Hi pvonkaenel,
Thanks for the reply.
sysInfo.dwNumberOfProcessors returns number of logical processor not physical processor count. ProcCtrl::IsIntel() is identifying the processor as Intel.
Could you suggest a simple way to get the physical processor count.
pvonkaenel
New Contributor III
Hi pvonkaenel,
I'm afraid that if ProcCtrl::NumLogicalProcs() is not returning the number of cores per die, then I'm not sure. Although, if you have the IPP library available, you could replace the call to ProcCtrl::NumLogicalProcs() with ippGetNumCoresOnDie().
Peter
