In OpenMP, Reduction Clause
zhangzhe65
Why?
#pragma omp parallel for
for (i=0; i{
sum+ = a * b;
and
#pragma omp parallel for reduction(+:sum)
for (i=0; i{
sum+ = a * b;
Please tell me why the two running results are identical?
Thank you.
jimdempseyatthecove
a) You got lucky
b) You compiled with OpenMP off
c) You compiled with OpenMP on, Nested levels off, and loop is in nested level.
d) You compiled with OpenMP on, but only 1 thread is used
e) N <= 1
f) all of a or all of b or both are 0
g) N is sufficiently small such that each thread finishes before the other starts (assuming multiple threads run the loop)
Jim Dempsey
zhangzhe65
a) You got lucky
e) N <= 1
Jim Dempsey
zhangzhe65
Thank you very much indeed for your reply.
