1701 Discussions
J2EE Apps use only two cores of the quad-core CPU of Xeon?
rajendrapote
We need to install our J2EE application on a Xeon server machines, built by IBM, but need to install it only for two cores due
to licensing issues. Any idea on how to make a JVM use only two cores of the quad-core CPU of Xeon?
Dmitry_Vyukov
Valued Contributor I
Quoting - rajendrapote
On Windows you can create script which will execute SetProcessAffinityMask() call for JVM process.
This is general method, although maybe JVM executable has corresponding command line parameters.
Dmitry_Vyukov
On linux you can use numactl(8):
http://linux.die.net/man/8/numactl
(see --physcpubind parameter)
Dmitry_Vyukov
