New test
gfelder
I ran the program you sent and the output was:
Hello from thread 0
0 0
1 0
2 0
3 0
4 0
5 0
6 0
7 0
At this point it hung, so once again the second thread simply never got started. When I set OMP_NUM_THREADS to 1 the program ran fine with one thread outputting all the numbers correctly. When I set it to 2 the program hung at the point I indicated.
Even more strangely, it worked once. I tried it and it hung. Then I tried it again (this time redirecting the output to a file) and it worked, correctly printing hello from both threads and printing all 16 outputs. I then tried it several times more, sometimes outputting to the console and sometimes redirecting the output to a file, and I could never get it to work again.
You asked if it works with hyperthreading disabled. How do I disable hyperthreading under Linux?
If you'd like I'd be happy to give you access to a user account on the machine I'm doing this on. We would just have to figure out a secure way for me to send you the username and password. (Phone?)
Thanks again for your help,
Gary
P.S. - My Internet connectivity will be spotty over the holidays, but I'll be checking the board at least once a week and I'll be back in more regular contact shortly after New Year's.
Henry_G_Intel
Thanks for running the test program. It's pretty clear that the second thread either isn't created or the program somehow exits before the second thread starts. I'm at a loss as to how either of these possibilities could occur. I can't reproduce the problem on any of my lab systems.
We need to involve the compiler team at this point. I can think of a few more things for you to try but they won't getyou any closer to a solution. Please submit this issue to Premier Support. Their support engineers are better suited to working this issue with the compiler developers.
Henry
PS You can usually enable or disable Hyper-Threading in the BIOS.
