1707 Discussions
Parallelization question about 4 quad core systems vs eight dual core systems
postaquestion
Is it possible that each and every application can be parallelizedto utilize the power of all the cores available in the socket?
Does a single application running on four CPU - quad core (4 cpu X 4 cores) and Eight CPU - Dual cores (8 X 2) servers give the same performance? If not, which is better if the same application is fully parallelized based on the multi-processor i.e SMP aytem (not on multicore)?
Your answermay help me in choosing the best option for my company.
TimP
There certainly is no blanket answer for this question. It would depend on specific applications and computer models under consideration. Among the comparisons we are called upon to make, 2 nodes of Harpertown 1600FSB dual socket quad core will not give the performance of 4 nodes Wolfdale dual socket dual core, but the more competitively priced examples of that Harpertown will give better performance per dollar and per watt on a majority of applications. It is very possible that a similar comparison would hold between 4 socket quad core and 8 socket dual core, if you have an application for which both are suited (more performance on the 8 socket machine, at a bigger increase in cost). Applications which make even moderate demands on memory bandwidth aren't likely to give competitive performance per dollar or watt on current 4 or 8 socket servers, if they are suitable for running on a cluster of multiple single or dual socket servers. You may have noticed that the Intel EP "efficient performance" models are dual socket. A year from now, 4 and 8 socket models should show a very big increase in performance, even more than 1 and 2 socket models. 8 socket models will still be somewhat specialized, with differing configurations for various purposes, and the 4 and 8 socket machines will continue to support lower bus and CPU clock frequencies than 2 sockets.
