Power Builder
Sam_Steins
Hi All.
Are there any Intel SDK which help when using Power builder? Thank you
AaronTersteeg
Quoting - Sam Steins
Hi All.
Are there any Inte SDK which help when using Power builder? Thank you
Sam,
I'm not aware of any Intel SDK that helps when using PowerBuilder.
You might want to try the Sybase site:
Aaron
mahmoudgalal1985
Sam,
Aaron
Thank you
mahmoudgalal1985
Hi All.
Thanks..
gaston-hillar
Valued Contributor I
Hi All.
Sam,
There are many useful Intel SDKs and libraries that can be called from Power Builder as an external language. For example, you can take advantage of Intel Math Kernel Library.
You just have to create your own wrappers. It's not an easy task. However, you can achieve great performance benefits with some libraries.
Hope it helps.
Cheers,
Gaston Hillar
