Problems with Q9300
319184742
Hello Intel!
Recently, around4 months ago I bought a new computer with a Q9300 cpu.
Its worked fine for about 2-3 months and than the gliches started.
For some reason, my CPU core temps are:
Core 1: 45C degree on idle.
Core 2: 47C degree on idle.
Core 3: 55C degree on idle.
Core 4: 35C degree on idle.
I dont think a quad core should act like this. These temps are wierd and mustnt be like that.
After all, I guess the temp differnces between the core doesnt soppose to be that big.
I am using a fine cooler (AC7) and it placed fine.
And, the second problem is with CPU Usage.
Every time I load(open) or trying to load(open)My Computer and/or one of the volumes,
the usage of core 4 is climbing to maximum, core 3 is climbing a little, and cores 1 & 2 are idle.
Its defenetly a problem.
Can you confirm this?
Dmitry_Vyukov
Valued Contributor I
Quoting - 319184742
Possibly you have some antivirus (or virus, which is mostly the same) or something like it (firewall), which detects that it runs on quad-core machine and sets own affinity to cores 3 and 4.
Quoting - Dmitriy V'jukov
Impossible, the C volume contains nothing but Windows XP and the official drivers (which came with the CD).
In addition I installed CoreTemp & PC Wizard 2008to detect core temps.
There is nothing else installed exept the above.
Dmitry_Vyukov
Quoting - 319184742
If you see in the task manager that only some cores are loaded, try to determine what processes produce that load (task manager -> processes tab). Is it Explorer.exe or something else? Probably this information will give some hook.
