Run time Error
ZACKYS_ZAKARI_C_
I am in the process of running a exe file, and shortly after the start of the running the exe stops running and displays a WIndows box headed 'Visual Fortran run-time error' with the following message:
forrtl: severe (38): Program Error durieng write, unit 0, file CONOUTS
Image PC Routine Line Source
DFORRT. dll 001B4A7A9 Unknown  Unknown
The message only appears when I try to add extensions. Other .exe files are ok and run very well.
Anyone know how to deal with this problem?
TimP
You'd be more likely to get an answer on the Windows Fortran forum.
Are you intentionally running an application built with Compaq or Digital Fortran?  Which Windows version?
Bernard
Valued Contributor I
