SpeedStep in DP45SG
hankswang
My build
DP45SG
[email protected]
In the bios under the power tab, there is a Enhanced Speed Step option. I disabled it and raised my cpu voltage to 1.32v, however when i log into windows it still says 1.26v. I assume that speed step is actually not disabled. How can I fix this problem?
gaston-hillar
Valued Contributor I
Hi hankswang,
You have to change your windows energy saving configuration in Control Panel. No matter your BIOS configuration, if the Windows energy configuration is set to optimize energy, it will manage the CPU voltages.
Cheers,
Gastn
