Store Buffer Forwarding Restriction on Size
duarten
In reading section3.6.5.1 of the most recentIntel 64 and IA-32ArchitecturesOptimization Reference Manual, it seems that for theIntel Core microarchitecture a large load after a small store never stalls (for example, a word aligned 32 bit load after an 8 bit store). Am I interpreting it correctly?
Thank you,
Duarte Nunes
jose-jesus-ambriz-me
duarten
But that pertains to theIntel NetBurst microarchitecture. I know the document says "Fixing store-forwarding problems for Intel NetBurst microarchitecture generally also avoids problems on Pentium M, Intel Core Duo and Intel Core 2 Duo processors", but I want to induce the "problem" (to avoid using a memory barrier), so I'm asking about the Intel Core microarchitecture (specifically, about the contents ofTable 3-2).
