1707 Discussions
The best method for inter-processor data communication
zhengda1936
I measure the performance of memory copy in a NUMA machine with 4 Xeon(R) CPU E5-4620 processors. When I copy data in the local memory, I can get up to almost 10GB/s. However, when I copy data from remote memory, I get much worse performance, only around 1GB/s. I use memcpy() to copy data and each copy is a page size (4KB).
I wonder if Intel processors provides special instructions for inter-processor data movement. I know Intel use QPI for inter-processor communication. Does it expose some interface for programmers? Is the performance above the best I can get?
Da
SergeyKostrov
Valued Contributor II
>>...It seems one data copy triggers moving 64 bytes to the remote node, so only the first data copy consumes most CPU time. I thought >>one data copy would trigger moving 128 bytes to a remote node (since the cache line is 128 bytes)... But your actual performance degradation is ~10 times and that is significant. Note: I see a call to: ... valloc( sizeof( *offset ) * nentries ); ... Is it similar to 'calloc'? Is it a NUMA specific function?
Bernard
>>>It seems one data copy triggers moving 64 bytes to the remote node, so only the first data copy consumes most CPU time>>> Yes most time consuming instructions are transferring 64-bytes data.What is the content of rdi register?Is it address of remote memory destination? >>2. In order to clear any uncertanties with the 'memcpy' function I recommend to replace it with an external pure C function ( a couple >>of minutes to implement, right? ) Interesting if your memcpy function is inlined or not and if some non - temporal cache hints are used inside the function. Can you post the full disassembly of memcpy function?
Bernard
>>>What do you mean by earlier memory speed degradation?>>> Have you earlier maybe during your other tests experienced memory write/read speed degradation when the remote memory was accessed? >>>The local memory copy speed is expected.>>> Yes I agree with you completely. In the case of remote memory access some memory transfer speed penalty is also expected, the question is why do you have 10 times higher speed degradation it is more than expected. Have you tested remote accesses from all of your nodes?What are the NUMA distances between your nodes?Have you tried to access furthest and the nearest possible node?
Bernard
>>>1. After a very quick code review of the test-case I noticed that a priority of the executing process is changed: ... setpriority( PRIO_PROCESS, getpid(), -20 ); ... Why do you change the priority of the process?>>> Good observation Sergey. He should not try to change the process priority because of possibility of process beign scheduled to run on the other node and thus all memory accesses will be remote from the NUMA perspective. >>> A Virtual Memory Manager ( VMM ) on any OS should have 'Above Normal' or 'High' priority. >>> Windows memory manager runs its code at DISPATCH_LEVEL and normal thread activities occur at PASSIVE_LEVEL only when the thread is scheduled to run so called kernel APC then it will run at APC_LEVEL.
SergeyKostrov
Hi Da, I see that #include directives are not shown completely in your test case. Could you attach the source codes as external c or cpp file? Thanks in advance.
zhengda1936
OK, I guess it's my mistake to give you the impression that remote memory copy is 10 time slower. In my program, I allocate the source array and the destination array in node 0, and run the memory copy code in node 0, 1, 2, 3. If I run memory copy in node 0, it takes 0.85s. If I run the code in node 1 or 3, it takes 5.74s. If in node 2, it takes 7s. So the performance degradation is 6.75 and 8.24. Note, here both source array and destination array is in the remote memory. If I only place the source array in the remote memory (in node 0), it takes 2.69s to run in the code in node 1. If I only place the destination array in the remote memory, it takes 3.27s. That is, writing to remote memory is slower than reading. I get the same performance with or without setting priority. I thought I could get more stable result by setting the process with a higher priority. As I showed before, gcc inlines memcpy and intel compiler invokes __intel_fast_memcpy and eventually end up in __intel_ssse3_rep_memcpy. __intel_ssse3_rep_memcpy is a super large function. I don't think posting its assembly code can help. What do you expect to see from there?
zhengda1936
#include stdio.h #include unistd.h #include sys/types.h #include sys/stat.h #include fcntl.h #include sys/time.h #include stdlib.h #include sys/resource.h #include string.h #include numa.h #include numaif.h
Bernard
>>>don't think posting its assembly code can help. What do you expect to see from there?>>> I would like to check for existance of cache hints instructions. >>>I get the same performance with or without setting priority. I thought I could get more stable result by setting the process with a higher priority.>>> Can you set affinity to the specific node? It seems that execution of your process is beign distributed between various nodes.
zhengda1936
My program first runs on node 0, and then it runs on a node specified by the user. So I do set affinity and it is controlled by the user.
zhengda1936
0000000000405410 <__intel_ssse3_rep_memcpy>: 405410: 48 89 f8 mov %rdi,%rax 405413: 48 81 fa 90 00 00 00 cmp $0x90,%rdx 40541a: 73 34 jae 405450 <__intel_ssse3_rep_memcpy+0x40> 40541c: 40 38 fe cmp %dil,%sil 40541f: 76 19 jbe 40543a <__intel_ssse3_rep_memcpy+0x2a> 405421: 48 01 d6 add %rdx,%rsi 405424: 48 01 d7 add %rdx,%rdi 405427: 4c 8d 1d 4a 3c 00 00 lea 0x3c4a(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 40542e: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405432: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405436: ff e2 jmpq *%rdx 405438: 0f 0b ud2 40543a: 4c 8d 1d f7 39 00 00 lea 0x39f7(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 405441: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405445: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405449: ff e2 jmpq *%rdx 40544b: 0f 0b ud2 40544d: 0f 1f 00 nopl (%rax) 405450: 40 38 fe cmp %dil,%sil 405453: 7e 5b jle 4054b0 <__intel_ssse3_rep_memcpy+0xa0> 405455: f3 0f 6f 06 movdqu (%rsi),%xmm0 405459: 49 89 f8 mov %rdi,%r8 40545c: 48 83 e7 f0 and $0xfffffffffffffff0,%rdi 405460: 48 83 c7 10 add $0x10,%rdi 405464: 49 89 f9 mov %rdi,%r9 405467: 4d 29 c1 sub %r8,%r9 40546a: 4c 29 ca sub %r9,%rdx 40546d: 4c 01 ce add %r9,%rsi 405470: 49 89 f1 mov %rsi,%r9 405473: 49 83 e1 0f and $0xf,%r9 405477: 0f 84 93 00 00 00 je 405510 <__intel_ssse3_rep_memcpy+0x100> 40547d: 8b 0d 85 56 20 00 mov 0x205685(%rip),%ecx # 60ab08 <__libirc_data_cache_size> 405483: 48 39 ca cmp %rcx,%rdx 405486: 0f 83 24 18 00 00 jae 406cb0 <__intel_ssse3_rep_memcpy+0x18a0> 40548c: 4c 8d 1d 25 3e 00 00 lea 0x3e25(%rip),%r11 # 4092b8 <.L_2il0floatpacket.29+0x64c> 405493: 48 81 ea 80 00 00 00 sub $0x80,%rdx 40549a: 4f 63 0c 8b movslq (%r11,%r9,4),%r9 40549e: 4d 01 d9 add %r11,%r9 4054a1: 41 ff e1 jmpq *%r9 4054a4: 0f 0b ud2 4054a6: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 4054ad: 00 00 00 4054b0: 8b 0d 52 56 20 00 mov 0x205652(%rip),%ecx # 60ab08 <__libirc_data_cache_size> 4054b6: 48 d1 e1 shl %rcx 4054b9: 48 39 ca cmp %rcx,%rdx 4054bc: 0f 87 7e 19 00 00 ja 406e40 <__intel_ssse3_rep_memcpy+0x1a30> 4054c2: 48 01 d7 add %rdx,%rdi 4054c5: 48 01 d6 add %rdx,%rsi 4054c8: f3 0f 6f 46 f0 movdqu -0x10(%rsi),%xmm0 4054cd: 4c 8d 47 f0 lea -0x10(%rdi),%r8 4054d1: 49 89 f9 mov %rdi,%r9 4054d4: 49 83 e1 0f and $0xf,%r9 4054d8: 4c 31 cf xor %r9,%rdi 4054db: 4c 29 ce sub %r9,%rsi 4054de: 4c 29 ca sub %r9,%rdx 4054e1: 49 89 f1 mov %rsi,%r9 4054e4: 49 83 e1 0f and $0xf,%r9 4054e8: 0f 84 c2 00 00 00 je 4055b0 <__intel_ssse3_rep_memcpy+0x1a0> 4054ee: 4c 8d 1d 03 3e 00 00 lea 0x3e03(%rip),%r11 # 4092f8 <.L_2il0floatpacket.29+0x68c> 4054f5: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4054fc: 4f 63 0c 8b movslq (%r11,%r9,4),%r9 405500: 4d 01 d9 add %r11,%r9 405503: 41 ff e1 jmpq *%r9 405506: 0f 0b ud2 405508: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40550f: 00 405510: 49 89 d1 mov %rdx,%r9 405513: 49 c1 e9 08 shr $0x8,%r9 405517: 49 01 d1 add %rdx,%r9 40551a: 8b 0d ec 55 20 00 mov 0x2055ec(%rip),%ecx # 60ab0c <__libirc_data_cache_size_half> 405520: 49 39 c9 cmp %rcx,%r9 405523: 0f 83 87 17 00 00 jae 406cb0 <__intel_ssse3_rep_memcpy+0x18a0> 405529: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405530: 66 0f 6f 0e movdqa (%rsi),%xmm1 405534: 66 0f 7f 0f movdqa %xmm1,(%rdi) 405538: 0f 28 56 10 movaps 0x10(%rsi),%xmm2 40553c: 0f 29 57 10 movaps %xmm2,0x10(%rdi) 405540: 0f 28 5e 20 movaps 0x20(%rsi),%xmm3 405544: 0f 29 5f 20 movaps %xmm3,0x20(%rdi) 405548: 0f 28 66 30 movaps 0x30(%rsi),%xmm4 40554c: 0f 29 67 30 movaps %xmm4,0x30(%rdi) 405550: 0f 28 4e 40 movaps 0x40(%rsi),%xmm1 405554: 0f 29 4f 40 movaps %xmm1,0x40(%rdi) 405558: 0f 28 56 50 movaps 0x50(%rsi),%xmm2 40555c: 0f 29 57 50 movaps %xmm2,0x50(%rdi) 405560: 0f 28 5e 60 movaps 0x60(%rsi),%xmm3 405564: 0f 29 5f 60 movaps %xmm3,0x60(%rdi) 405568: 0f 28 66 70 movaps 0x70(%rsi),%xmm4 40556c: 0f 29 67 70 movaps %xmm4,0x70(%rdi) 405570: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405577: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 40557e: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 405585: 73 a9 jae 405530 <__intel_ssse3_rep_memcpy+0x120> 405587: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 40558c: 48 81 c2 80 00 00 00 add $0x80,%rdx 405593: 48 01 d6 add %rdx,%rsi 405596: 48 01 d7 add %rdx,%rdi 405599: 4c 8d 1d d8 3a 00 00 lea 0x3ad8(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 4055a0: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 4055a4: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4055a8: ff e2 jmpq *%rdx 4055aa: 0f 0b ud2 4055ac: 0f 1f 40 00 nopl 0x0(%rax) 4055b0: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4055b7: 0f 28 4e f0 movaps -0x10(%rsi),%xmm1 4055bb: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 4055bf: 0f 28 56 e0 movaps -0x20(%rsi),%xmm2 4055c3: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 4055c7: 0f 28 5e d0 movaps -0x30(%rsi),%xmm3 4055cb: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 4055cf: 0f 28 66 c0 movaps -0x40(%rsi),%xmm4 4055d3: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 4055d7: 0f 28 6e b0 movaps -0x50(%rsi),%xmm5 4055db: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 4055df: 0f 28 6e a0 movaps -0x60(%rsi),%xmm5 4055e3: 0f 29 6f a0 movaps %xmm5,-0x60(%rdi) 4055e7: 0f 28 6e 90 movaps -0x70(%rsi),%xmm5 4055eb: 0f 29 6f 90 movaps %xmm5,-0x70(%rdi) 4055ef: 0f 28 6e 80 movaps -0x80(%rsi),%xmm5 4055f3: 0f 29 6f 80 movaps %xmm5,-0x80(%rdi) 4055f7: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4055fe: 48 8d 7f 80 lea -0x80(%rdi),%rdi 405602: 48 8d 76 80 lea -0x80(%rsi),%rsi 405606: 73 af jae 4055b7 <__intel_ssse3_rep_memcpy+0x1a7> 405608: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 40560d: 48 81 c2 80 00 00 00 add $0x80,%rdx 405614: 48 29 d7 sub %rdx,%rdi 405617: 48 29 d6 sub %rdx,%rsi 40561a: 4c 8d 1d 17 38 00 00 lea 0x3817(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 405621: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405625: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405629: ff e2 jmpq *%rdx 40562b: 0f 0b ud2 40562d: 0f 1f 00 nopl (%rax) 405630: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405637: 0f 28 4e ff movaps -0x1(%rsi),%xmm1 40563b: 0f 28 56 0f movaps 0xf(%rsi),%xmm2 40563f: 0f 28 5e 1f movaps 0x1f(%rsi),%xmm3 405643: 0f 28 66 2f movaps 0x2f(%rsi),%xmm4 405647: 0f 28 6e 3f movaps 0x3f(%rsi),%xmm5 40564b: 0f 28 76 4f movaps 0x4f(%rsi),%xmm6 40564f: 0f 28 7e 5f movaps 0x5f(%rsi),%xmm7 405653: 44 0f 28 46 6f movaps 0x6f(%rsi),%xmm8 405658: 44 0f 28 4e 7f movaps 0x7f(%rsi),%xmm9 40565d: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 405664: 66 45 0f 3a 0f c8 01 palignr $0x1,%xmm8,%xmm9 40566b: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 405670: 66 44 0f 3a 0f c7 01 palignr $0x1,%xmm7,%xmm8 405677: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 40567c: 66 0f 3a 0f fe 01 palignr $0x1,%xmm6,%xmm7 405682: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 405686: 66 0f 3a 0f f5 01 palignr $0x1,%xmm5,%xmm6 40568c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 405690: 66 0f 3a 0f ec 01 palignr $0x1,%xmm4,%xmm5 405696: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 40569a: 66 0f 3a 0f e3 01 palignr $0x1,%xmm3,%xmm4 4056a0: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 4056a4: 66 0f 3a 0f da 01 palignr $0x1,%xmm2,%xmm3 4056aa: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 4056ae: 66 0f 3a 0f d1 01 palignr $0x1,%xmm1,%xmm2 4056b4: 0f 29 17 movaps %xmm2,(%rdi) 4056b7: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 4056be: 0f 83 6c ff ff ff jae 405630 <__intel_ssse3_rep_memcpy+0x220> 4056c4: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 4056c9: 48 81 c2 80 00 00 00 add $0x80,%rdx 4056d0: 48 01 d7 add %rdx,%rdi 4056d3: 48 01 d6 add %rdx,%rsi 4056d6: 4c 8d 1d 9b 39 00 00 lea 0x399b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 4056dd: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 4056e1: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4056e5: ff e2 jmpq *%rdx 4056e7: 0f 0b ud2 4056e9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4056f0: 0f 28 4e ff movaps -0x1(%rsi),%xmm1 4056f4: 0f 28 56 ef movaps -0x11(%rsi),%xmm2 4056f8: 66 0f 3a 0f ca 01 palignr $0x1,%xmm2,%xmm1 4056fe: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 405702: 0f 28 5e df movaps -0x21(%rsi),%xmm3 405706: 66 0f 3a 0f d3 01 palignr $0x1,%xmm3,%xmm2 40570c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 405710: 0f 28 66 cf movaps -0x31(%rsi),%xmm4 405714: 66 0f 3a 0f dc 01 palignr $0x1,%xmm4,%xmm3 40571a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 40571e: 0f 28 6e bf movaps -0x41(%rsi),%xmm5 405722: 66 0f 3a 0f e5 01 palignr $0x1,%xmm5,%xmm4 405728: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 40572c: 0f 28 76 af movaps -0x51(%rsi),%xmm6 405730: 66 0f 3a 0f ee 01 palignr $0x1,%xmm6,%xmm5 405736: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 40573a: 0f 28 7e 9f movaps -0x61(%rsi),%xmm7 40573e: 66 0f 3a 0f f7 01 palignr $0x1,%xmm7,%xmm6 405744: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 405748: 44 0f 28 46 8f movaps -0x71(%rsi),%xmm8 40574d: 66 41 0f 3a 0f f8 01 palignr $0x1,%xmm8,%xmm7 405754: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 405758: 44 0f 28 8e 7f ff ff movaps -0x81(%rsi),%xmm9 40575f: ff 405760: 66 45 0f 3a 0f c1 01 palignr $0x1,%xmm9,%xmm8 405767: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 40576c: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405773: 48 8d 7f 80 lea -0x80(%rdi),%rdi 405777: 48 8d 76 80 lea -0x80(%rsi),%rsi 40577b: 0f 83 6f ff ff ff jae 4056f0 <__intel_ssse3_rep_memcpy+0x2e0> 405781: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405786: 48 81 c2 80 00 00 00 add $0x80,%rdx 40578d: 48 29 d7 sub %rdx,%rdi 405790: 48 29 d6 sub %rdx,%rsi 405793: 4c 8d 1d 9e 36 00 00 lea 0x369e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 40579a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 40579e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4057a2: ff e2 jmpq *%rdx 4057a4: 0f 0b ud2 4057a6: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 4057ad: 00 00 00 4057b0: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4057b7: 0f 28 4e fe movaps -0x2(%rsi),%xmm1 4057bb: 0f 28 56 0e movaps 0xe(%rsi),%xmm2 4057bf: 0f 28 5e 1e movaps 0x1e(%rsi),%xmm3 4057c3: 0f 28 66 2e movaps 0x2e(%rsi),%xmm4 4057c7: 0f 28 6e 3e movaps 0x3e(%rsi),%xmm5 4057cb: 0f 28 76 4e movaps 0x4e(%rsi),%xmm6 4057cf: 0f 28 7e 5e movaps 0x5e(%rsi),%xmm7 4057d3: 44 0f 28 46 6e movaps 0x6e(%rsi),%xmm8 4057d8: 44 0f 28 4e 7e movaps 0x7e(%rsi),%xmm9 4057dd: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 4057e4: 66 45 0f 3a 0f c8 02 palignr $0x2,%xmm8,%xmm9 4057eb: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 4057f0: 66 44 0f 3a 0f c7 02 palignr $0x2,%xmm7,%xmm8 4057f7: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 4057fc: 66 0f 3a 0f fe 02 palignr $0x2,%xmm6,%xmm7 405802: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 405806: 66 0f 3a 0f f5 02 palignr $0x2,%xmm5,%xmm6 40580c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 405810: 66 0f 3a 0f ec 02 palignr $0x2,%xmm4,%xmm5 405816: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 40581a: 66 0f 3a 0f e3 02 palignr $0x2,%xmm3,%xmm4 405820: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 405824: 66 0f 3a 0f da 02 palignr $0x2,%xmm2,%xmm3 40582a: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 40582e: 66 0f 3a 0f d1 02 palignr $0x2,%xmm1,%xmm2 405834: 0f 29 17 movaps %xmm2,(%rdi) 405837: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 40583e: 0f 83 6c ff ff ff jae 4057b0 <__intel_ssse3_rep_memcpy+0x3a0> 405844: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405849: 48 81 c2 80 00 00 00 add $0x80,%rdx 405850: 48 01 d7 add %rdx,%rdi 405853: 48 01 d6 add %rdx,%rsi 405856: 4c 8d 1d 1b 38 00 00 lea 0x381b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 40585d: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405861: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405865: ff e2 jmpq *%rdx 405867: 0f 0b ud2 405869: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 405870: 0f 28 4e fe movaps -0x2(%rsi),%xmm1 405874: 0f 28 56 ee movaps -0x12(%rsi),%xmm2 405878: 66 0f 3a 0f ca 02 palignr $0x2,%xmm2,%xmm1 40587e: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 405882: 0f 28 5e de movaps -0x22(%rsi),%xmm3 405886: 66 0f 3a 0f d3 02 palignr $0x2,%xmm3,%xmm2 40588c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 405890: 0f 28 66 ce movaps -0x32(%rsi),%xmm4 405894: 66 0f 3a 0f dc 02 palignr $0x2,%xmm4,%xmm3 40589a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 40589e: 0f 28 6e be movaps -0x42(%rsi),%xmm5 4058a2: 66 0f 3a 0f e5 02 palignr $0x2,%xmm5,%xmm4 4058a8: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 4058ac: 0f 28 76 ae movaps -0x52(%rsi),%xmm6 4058b0: 66 0f 3a 0f ee 02 palignr $0x2,%xmm6,%xmm5 4058b6: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 4058ba: 0f 28 7e 9e movaps -0x62(%rsi),%xmm7 4058be: 66 0f 3a 0f f7 02 palignr $0x2,%xmm7,%xmm6 4058c4: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 4058c8: 44 0f 28 46 8e movaps -0x72(%rsi),%xmm8 4058cd: 66 41 0f 3a 0f f8 02 palignr $0x2,%xmm8,%xmm7 4058d4: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 4058d8: 44 0f 28 8e 7e ff ff movaps -0x82(%rsi),%xmm9 4058df: ff 4058e0: 66 45 0f 3a 0f c1 02 palignr $0x2,%xmm9,%xmm8 4058e7: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 4058ec: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4058f3: 48 8d 7f 80 lea -0x80(%rdi),%rdi 4058f7: 48 8d 76 80 lea -0x80(%rsi),%rsi 4058fb: 0f 83 6f ff ff ff jae 405870 <__intel_ssse3_rep_memcpy+0x460> 405901: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405906: 48 81 c2 80 00 00 00 add $0x80,%rdx 40590d: 48 29 d7 sub %rdx,%rdi 405910: 48 29 d6 sub %rdx,%rsi 405913: 4c 8d 1d 1e 35 00 00 lea 0x351e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 40591a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 40591e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405922: ff e2 jmpq *%rdx 405924: 0f 0b ud2 405926: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 40592d: 00 00 00 405930: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405937: 0f 28 4e fd movaps -0x3(%rsi),%xmm1 40593b: 0f 28 56 0d movaps 0xd(%rsi),%xmm2 40593f: 0f 28 5e 1d movaps 0x1d(%rsi),%xmm3 405943: 0f 28 66 2d movaps 0x2d(%rsi),%xmm4 405947: 0f 28 6e 3d movaps 0x3d(%rsi),%xmm5 40594b: 0f 28 76 4d movaps 0x4d(%rsi),%xmm6 40594f: 0f 28 7e 5d movaps 0x5d(%rsi),%xmm7 405953: 44 0f 28 46 6d movaps 0x6d(%rsi),%xmm8 405958: 44 0f 28 4e 7d movaps 0x7d(%rsi),%xmm9 40595d: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 405964: 66 45 0f 3a 0f c8 03 palignr $0x3,%xmm8,%xmm9 40596b: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 405970: 66 44 0f 3a 0f c7 03 palignr $0x3,%xmm7,%xmm8 405977: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 40597c: 66 0f 3a 0f fe 03 palignr $0x3,%xmm6,%xmm7 405982: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 405986: 66 0f 3a 0f f5 03 palignr $0x3,%xmm5,%xmm6 40598c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 405990: 66 0f 3a 0f ec 03 palignr $0x3,%xmm4,%xmm5 405996: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 40599a: 66 0f 3a 0f e3 03 palignr $0x3,%xmm3,%xmm4 4059a0: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 4059a4: 66 0f 3a 0f da 03 palignr $0x3,%xmm2,%xmm3 4059aa: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 4059ae: 66 0f 3a 0f d1 03 palignr $0x3,%xmm1,%xmm2 4059b4: 0f 29 17 movaps %xmm2,(%rdi) 4059b7: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 4059be: 0f 83 6c ff ff ff jae 405930 <__intel_ssse3_rep_memcpy+0x520> 4059c4: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 4059c9: 48 81 c2 80 00 00 00 add $0x80,%rdx 4059d0: 48 01 d7 add %rdx,%rdi 4059d3: 48 01 d6 add %rdx,%rsi 4059d6: 4c 8d 1d 9b 36 00 00 lea 0x369b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 4059dd: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 4059e1: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4059e5: ff e2 jmpq *%rdx 4059e7: 0f 0b ud2 4059e9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4059f0: 0f 28 4e fd movaps -0x3(%rsi),%xmm1 4059f4: 0f 28 56 ed movaps -0x13(%rsi),%xmm2 4059f8: 66 0f 3a 0f ca 03 palignr $0x3,%xmm2,%xmm1 4059fe: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 405a02: 0f 28 5e dd movaps -0x23(%rsi),%xmm3 405a06: 66 0f 3a 0f d3 03 palignr $0x3,%xmm3,%xmm2 405a0c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 405a10: 0f 28 66 cd movaps -0x33(%rsi),%xmm4 405a14: 66 0f 3a 0f dc 03 palignr $0x3,%xmm4,%xmm3 405a1a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 405a1e: 0f 28 6e bd movaps -0x43(%rsi),%xmm5 405a22: 66 0f 3a 0f e5 03 palignr $0x3,%xmm5,%xmm4 405a28: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 405a2c: 0f 28 76 ad movaps -0x53(%rsi),%xmm6 405a30: 66 0f 3a 0f ee 03 palignr $0x3,%xmm6,%xmm5 405a36: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 405a3a: 0f 28 7e 9d movaps -0x63(%rsi),%xmm7 405a3e: 66 0f 3a 0f f7 03 palignr $0x3,%xmm7,%xmm6 405a44: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 405a48: 44 0f 28 46 8d movaps -0x73(%rsi),%xmm8 405a4d: 66 41 0f 3a 0f f8 03 palignr $0x3,%xmm8,%xmm7 405a54: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 405a58: 44 0f 28 8e 7d ff ff movaps -0x83(%rsi),%xmm9 405a5f: ff 405a60: 66 45 0f 3a 0f c1 03 palignr $0x3,%xmm9,%xmm8 405a67: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 405a6c: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405a73: 48 8d 7f 80 lea -0x80(%rdi),%rdi 405a77: 48 8d 76 80 lea -0x80(%rsi),%rsi 405a7b: 0f 83 6f ff ff ff jae 4059f0 <__intel_ssse3_rep_memcpy+0x5e0> 405a81: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405a86: 48 81 c2 80 00 00 00 add $0x80,%rdx 405a8d: 48 29 d7 sub %rdx,%rdi 405a90: 48 29 d6 sub %rdx,%rsi 405a93: 4c 8d 1d 9e 33 00 00 lea 0x339e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 405a9a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405a9e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405aa2: ff e2 jmpq *%rdx 405aa4: 0f 0b ud2 405aa6: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 405aad: 00 00 00 405ab0: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405ab7: 0f 28 4e fc movaps -0x4(%rsi),%xmm1 405abb: 0f 28 56 0c movaps 0xc(%rsi),%xmm2 405abf: 0f 28 5e 1c movaps 0x1c(%rsi),%xmm3 405ac3: 0f 28 66 2c movaps 0x2c(%rsi),%xmm4 405ac7: 0f 28 6e 3c movaps 0x3c(%rsi),%xmm5 405acb: 0f 28 76 4c movaps 0x4c(%rsi),%xmm6 405acf: 0f 28 7e 5c movaps 0x5c(%rsi),%xmm7 405ad3: 44 0f 28 46 6c movaps 0x6c(%rsi),%xmm8 405ad8: 44 0f 28 4e 7c movaps 0x7c(%rsi),%xmm9 405add: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 405ae4: 66 45 0f 3a 0f c8 04 palignr $0x4,%xmm8,%xmm9 405aeb: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 405af0: 66 44 0f 3a 0f c7 04 palignr $0x4,%xmm7,%xmm8 405af7: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 405afc: 66 0f 3a 0f fe 04 palignr $0x4,%xmm6,%xmm7 405b02: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 405b06: 66 0f 3a 0f f5 04 palignr $0x4,%xmm5,%xmm6 405b0c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 405b10: 66 0f 3a 0f ec 04 palignr $0x4,%xmm4,%xmm5 405b16: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 405b1a: 66 0f 3a 0f e3 04 palignr $0x4,%xmm3,%xmm4 405b20: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 405b24: 66 0f 3a 0f da 04 palignr $0x4,%xmm2,%xmm3 405b2a: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 405b2e: 66 0f 3a 0f d1 04 palignr $0x4,%xmm1,%xmm2 405b34: 0f 29 17 movaps %xmm2,(%rdi) 405b37: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 405b3e: 0f 83 6c ff ff ff jae 405ab0 <__intel_ssse3_rep_memcpy+0x6a0> 405b44: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405b49: 48 81 c2 80 00 00 00 add $0x80,%rdx 405b50: 48 01 d7 add %rdx,%rdi 405b53: 48 01 d6 add %rdx,%rsi 405b56: 4c 8d 1d 1b 35 00 00 lea 0x351b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 405b5d: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405b61: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405b65: ff e2 jmpq *%rdx 405b67: 0f 0b ud2 405b69: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 405b70: 0f 28 4e fc movaps -0x4(%rsi),%xmm1 405b74: 0f 28 56 ec movaps -0x14(%rsi),%xmm2 405b78: 66 0f 3a 0f ca 04 palignr $0x4,%xmm2,%xmm1 405b7e: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 405b82: 0f 28 5e dc movaps -0x24(%rsi),%xmm3 405b86: 66 0f 3a 0f d3 04 palignr $0x4,%xmm3,%xmm2 405b8c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 405b90: 0f 28 66 cc movaps -0x34(%rsi),%xmm4 405b94: 66 0f 3a 0f dc 04 palignr $0x4,%xmm4,%xmm3 405b9a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 405b9e: 0f 28 6e bc movaps -0x44(%rsi),%xmm5 405ba2: 66 0f 3a 0f e5 04 palignr $0x4,%xmm5,%xmm4 405ba8: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 405bac: 0f 28 76 ac movaps -0x54(%rsi),%xmm6 405bb0: 66 0f 3a 0f ee 04 palignr $0x4,%xmm6,%xmm5 405bb6: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 405bba: 0f 28 7e 9c movaps -0x64(%rsi),%xmm7 405bbe: 66 0f 3a 0f f7 04 palignr $0x4,%xmm7,%xmm6 405bc4: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 405bc8: 44 0f 28 46 8c movaps -0x74(%rsi),%xmm8 405bcd: 66 41 0f 3a 0f f8 04 palignr $0x4,%xmm8,%xmm7 405bd4: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 405bd8: 44 0f 28 8e 7c ff ff movaps -0x84(%rsi),%xmm9 405bdf: ff 405be0: 66 45 0f 3a 0f c1 04 palignr $0x4,%xmm9,%xmm8 405be7: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 405bec: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405bf3: 48 8d 7f 80 lea -0x80(%rdi),%rdi 405bf7: 48 8d 76 80 lea -0x80(%rsi),%rsi 405bfb: 0f 83 6f ff ff ff jae 405b70 <__intel_ssse3_rep_memcpy+0x760> 405c01: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405c06: 48 81 c2 80 00 00 00 add $0x80,%rdx 405c0d: 48 29 d7 sub %rdx,%rdi 405c10: 48 29 d6 sub %rdx,%rsi 405c13: 4c 8d 1d 1e 32 00 00 lea 0x321e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 405c1a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405c1e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405c22: ff e2 jmpq *%rdx 405c24: 0f 0b ud2 405c26: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 405c2d: 00 00 00 405c30: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405c37: 0f 28 4e fb movaps -0x5(%rsi),%xmm1 405c3b: 0f 28 56 0b movaps 0xb(%rsi),%xmm2 405c3f: 0f 28 5e 1b movaps 0x1b(%rsi),%xmm3 405c43: 0f 28 66 2b movaps 0x2b(%rsi),%xmm4 405c47: 0f 28 6e 3b movaps 0x3b(%rsi),%xmm5 405c4b: 0f 28 76 4b movaps 0x4b(%rsi),%xmm6 405c4f: 0f 28 7e 5b movaps 0x5b(%rsi),%xmm7 405c53: 44 0f 28 46 6b movaps 0x6b(%rsi),%xmm8 405c58: 44 0f 28 4e 7b movaps 0x7b(%rsi),%xmm9 405c5d: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 405c64: 66 45 0f 3a 0f c8 05 palignr $0x5,%xmm8,%xmm9 405c6b: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 405c70: 66 44 0f 3a 0f c7 05 palignr $0x5,%xmm7,%xmm8 405c77: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 405c7c: 66 0f 3a 0f fe 05 palignr $0x5,%xmm6,%xmm7 405c82: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 405c86: 66 0f 3a 0f f5 05 palignr $0x5,%xmm5,%xmm6 405c8c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 405c90: 66 0f 3a 0f ec 05 palignr $0x5,%xmm4,%xmm5 405c96: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 405c9a: 66 0f 3a 0f e3 05 palignr $0x5,%xmm3,%xmm4 405ca0: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 405ca4: 66 0f 3a 0f da 05 palignr $0x5,%xmm2,%xmm3 405caa: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 405cae: 66 0f 3a 0f d1 05 palignr $0x5,%xmm1,%xmm2 405cb4: 0f 29 17 movaps %xmm2,(%rdi) 405cb7: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 405cbe: 0f 83 6c ff ff ff jae 405c30 <__intel_ssse3_rep_memcpy+0x820> 405cc4: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405cc9: 48 81 c2 80 00 00 00 add $0x80,%rdx 405cd0: 48 01 d7 add %rdx,%rdi 405cd3: 48 01 d6 add %rdx,%rsi 405cd6: 4c 8d 1d 9b 33 00 00 lea 0x339b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 405cdd: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405ce1: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405ce5: ff e2 jmpq *%rdx 405ce7: 0f 0b ud2 405ce9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 405cf0: 0f 28 4e fb movaps -0x5(%rsi),%xmm1 405cf4: 0f 28 56 eb movaps -0x15(%rsi),%xmm2 405cf8: 66 0f 3a 0f ca 05 palignr $0x5,%xmm2,%xmm1 405cfe: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 405d02: 0f 28 5e db movaps -0x25(%rsi),%xmm3 405d06: 66 0f 3a 0f d3 05 palignr $0x5,%xmm3,%xmm2 405d0c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 405d10: 0f 28 66 cb movaps -0x35(%rsi),%xmm4 405d14: 66 0f 3a 0f dc 05 palignr $0x5,%xmm4,%xmm3 405d1a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 405d1e: 0f 28 6e bb movaps -0x45(%rsi),%xmm5 405d22: 66 0f 3a 0f e5 05 palignr $0x5,%xmm5,%xmm4 405d28: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 405d2c: 0f 28 76 ab movaps -0x55(%rsi),%xmm6 405d30: 66 0f 3a 0f ee 05 palignr $0x5,%xmm6,%xmm5 405d36: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 405d3a: 0f 28 7e 9b movaps -0x65(%rsi),%xmm7 405d3e: 66 0f 3a 0f f7 05 palignr $0x5,%xmm7,%xmm6 405d44: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 405d48: 44 0f 28 46 8b movaps -0x75(%rsi),%xmm8 405d4d: 66 41 0f 3a 0f f8 05 palignr $0x5,%xmm8,%xmm7 405d54: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 405d58: 44 0f 28 8e 7b ff ff movaps -0x85(%rsi),%xmm9 405d5f: ff 405d60: 66 45 0f 3a 0f c1 05 palignr $0x5,%xmm9,%xmm8 405d67: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 405d6c: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405d73: 48 8d 7f 80 lea -0x80(%rdi),%rdi 405d77: 48 8d 76 80 lea -0x80(%rsi),%rsi 405d7b: 0f 83 6f ff ff ff jae 405cf0 <__intel_ssse3_rep_memcpy+0x8e0> 405d81: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405d86: 48 81 c2 80 00 00 00 add $0x80,%rdx 405d8d: 48 29 d7 sub %rdx,%rdi 405d90: 48 29 d6 sub %rdx,%rsi 405d93: 4c 8d 1d 9e 30 00 00 lea 0x309e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 405d9a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405d9e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405da2: ff e2 jmpq *%rdx 405da4: 0f 0b ud2 405da6: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 405dad: 00 00 00 405db0: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405db7: 0f 28 4e fa movaps -0x6(%rsi),%xmm1 405dbb: 0f 28 56 0a movaps 0xa(%rsi),%xmm2 405dbf: 0f 28 5e 1a movaps 0x1a(%rsi),%xmm3 405dc3: 0f 28 66 2a movaps 0x2a(%rsi),%xmm4 405dc7: 0f 28 6e 3a movaps 0x3a(%rsi),%xmm5 405dcb: 0f 28 76 4a movaps 0x4a(%rsi),%xmm6 405dcf: 0f 28 7e 5a movaps 0x5a(%rsi),%xmm7 405dd3: 44 0f 28 46 6a movaps 0x6a(%rsi),%xmm8 405dd8: 44 0f 28 4e 7a movaps 0x7a(%rsi),%xmm9 405ddd: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 405de4: 66 45 0f 3a 0f c8 06 palignr $0x6,%xmm8,%xmm9 405deb: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 405df0: 66 44 0f 3a 0f c7 06 palignr $0x6,%xmm7,%xmm8 405df7: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 405dfc: 66 0f 3a 0f fe 06 palignr $0x6,%xmm6,%xmm7 405e02: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 405e06: 66 0f 3a 0f f5 06 palignr $0x6,%xmm5,%xmm6 405e0c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 405e10: 66 0f 3a 0f ec 06 palignr $0x6,%xmm4,%xmm5 405e16: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 405e1a: 66 0f 3a 0f e3 06 palignr $0x6,%xmm3,%xmm4 405e20: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 405e24: 66 0f 3a 0f da 06 palignr $0x6,%xmm2,%xmm3 405e2a: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 405e2e: 66 0f 3a 0f d1 06 palignr $0x6,%xmm1,%xmm2 405e34: 0f 29 17 movaps %xmm2,(%rdi) 405e37: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 405e3e: 0f 83 6c ff ff ff jae 405db0 <__intel_ssse3_rep_memcpy+0x9a0> 405e44: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405e49: 48 81 c2 80 00 00 00 add $0x80,%rdx 405e50: 48 01 d7 add %rdx,%rdi 405e53: 48 01 d6 add %rdx,%rsi 405e56: 4c 8d 1d 1b 32 00 00 lea 0x321b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 405e5d: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405e61: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405e65: ff e2 jmpq *%rdx 405e67: 0f 0b ud2 405e69: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 405e70: 0f 28 4e fa movaps -0x6(%rsi),%xmm1 405e74: 0f 28 56 ea movaps -0x16(%rsi),%xmm2 405e78: 66 0f 3a 0f ca 06 palignr $0x6,%xmm2,%xmm1 405e7e: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 405e82: 0f 28 5e da movaps -0x26(%rsi),%xmm3 405e86: 66 0f 3a 0f d3 06 palignr $0x6,%xmm3,%xmm2 405e8c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 405e90: 0f 28 66 ca movaps -0x36(%rsi),%xmm4 405e94: 66 0f 3a 0f dc 06 palignr $0x6,%xmm4,%xmm3 405e9a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 405e9e: 0f 28 6e ba movaps -0x46(%rsi),%xmm5 405ea2: 66 0f 3a 0f e5 06 palignr $0x6,%xmm5,%xmm4 405ea8: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 405eac: 0f 28 76 aa movaps -0x56(%rsi),%xmm6 405eb0: 66 0f 3a 0f ee 06 palignr $0x6,%xmm6,%xmm5 405eb6: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 405eba: 0f 28 7e 9a movaps -0x66(%rsi),%xmm7 405ebe: 66 0f 3a 0f f7 06 palignr $0x6,%xmm7,%xmm6 405ec4: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 405ec8: 44 0f 28 46 8a movaps -0x76(%rsi),%xmm8 405ecd: 66 41 0f 3a 0f f8 06 palignr $0x6,%xmm8,%xmm7 405ed4: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 405ed8: 44 0f 28 8e 7a ff ff movaps -0x86(%rsi),%xmm9 405edf: ff 405ee0: 66 45 0f 3a 0f c1 06 palignr $0x6,%xmm9,%xmm8 405ee7: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 405eec: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405ef3: 48 8d 7f 80 lea -0x80(%rdi),%rdi 405ef7: 48 8d 76 80 lea -0x80(%rsi),%rsi 405efb: 0f 83 6f ff ff ff jae 405e70 <__intel_ssse3_rep_memcpy+0xa60> 405f01: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405f06: 48 81 c2 80 00 00 00 add $0x80,%rdx 405f0d: 48 29 d7 sub %rdx,%rdi 405f10: 48 29 d6 sub %rdx,%rsi 405f13: 4c 8d 1d 1e 2f 00 00 lea 0x2f1e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 405f1a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405f1e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405f22: ff e2 jmpq *%rdx 405f24: 0f 0b ud2 405f26: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 405f2d: 00 00 00 405f30: 48 81 ea 80 00 00 00 sub $0x80,%rdx 405f37: 0f 28 4e f9 movaps -0x7(%rsi),%xmm1 405f3b: 0f 28 56 09 movaps 0x9(%rsi),%xmm2 405f3f: 0f 28 5e 19 movaps 0x19(%rsi),%xmm3 405f43: 0f 28 66 29 movaps 0x29(%rsi),%xmm4 405f47: 0f 28 6e 39 movaps 0x39(%rsi),%xmm5 405f4b: 0f 28 76 49 movaps 0x49(%rsi),%xmm6 405f4f: 0f 28 7e 59 movaps 0x59(%rsi),%xmm7 405f53: 44 0f 28 46 69 movaps 0x69(%rsi),%xmm8 405f58: 44 0f 28 4e 79 movaps 0x79(%rsi),%xmm9 405f5d: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 405f64: 66 45 0f 3a 0f c8 07 palignr $0x7,%xmm8,%xmm9 405f6b: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 405f70: 66 44 0f 3a 0f c7 07 palignr $0x7,%xmm7,%xmm8 405f77: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 405f7c: 66 0f 3a 0f fe 07 palignr $0x7,%xmm6,%xmm7 405f82: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 405f86: 66 0f 3a 0f f5 07 palignr $0x7,%xmm5,%xmm6 405f8c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 405f90: 66 0f 3a 0f ec 07 palignr $0x7,%xmm4,%xmm5 405f96: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 405f9a: 66 0f 3a 0f e3 07 palignr $0x7,%xmm3,%xmm4 405fa0: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 405fa4: 66 0f 3a 0f da 07 palignr $0x7,%xmm2,%xmm3 405faa: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 405fae: 66 0f 3a 0f d1 07 palignr $0x7,%xmm1,%xmm2 405fb4: 0f 29 17 movaps %xmm2,(%rdi) 405fb7: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 405fbe: 0f 83 6c ff ff ff jae 405f30 <__intel_ssse3_rep_memcpy+0xb20> 405fc4: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 405fc9: 48 81 c2 80 00 00 00 add $0x80,%rdx 405fd0: 48 01 d7 add %rdx,%rdi 405fd3: 48 01 d6 add %rdx,%rsi 405fd6: 4c 8d 1d 9b 30 00 00 lea 0x309b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 405fdd: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 405fe1: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 405fe5: ff e2 jmpq *%rdx 405fe7: 0f 0b ud2 405fe9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 405ff0: 0f 28 4e f9 movaps -0x7(%rsi),%xmm1 405ff4: 0f 28 56 e9 movaps -0x17(%rsi),%xmm2 405ff8: 66 0f 3a 0f ca 07 palignr $0x7,%xmm2,%xmm1 405ffe: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 406002: 0f 28 5e d9 movaps -0x27(%rsi),%xmm3 406006: 66 0f 3a 0f d3 07 palignr $0x7,%xmm3,%xmm2 40600c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 406010: 0f 28 66 c9 movaps -0x37(%rsi),%xmm4 406014: 66 0f 3a 0f dc 07 palignr $0x7,%xmm4,%xmm3 40601a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 40601e: 0f 28 6e b9 movaps -0x47(%rsi),%xmm5 406022: 66 0f 3a 0f e5 07 palignr $0x7,%xmm5,%xmm4 406028: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 40602c: 0f 28 76 a9 movaps -0x57(%rsi),%xmm6 406030: 66 0f 3a 0f ee 07 palignr $0x7,%xmm6,%xmm5 406036: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 40603a: 0f 28 7e 99 movaps -0x67(%rsi),%xmm7 40603e: 66 0f 3a 0f f7 07 palignr $0x7,%xmm7,%xmm6 406044: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 406048: 44 0f 28 46 89 movaps -0x77(%rsi),%xmm8 40604d: 66 41 0f 3a 0f f8 07 palignr $0x7,%xmm8,%xmm7 406054: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 406058: 44 0f 28 8e 79 ff ff movaps -0x87(%rsi),%xmm9 40605f: ff 406060: 66 45 0f 3a 0f c1 07 palignr $0x7,%xmm9,%xmm8 406067: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 40606c: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406073: 48 8d 7f 80 lea -0x80(%rdi),%rdi 406077: 48 8d 76 80 lea -0x80(%rsi),%rsi 40607b: 0f 83 6f ff ff ff jae 405ff0 <__intel_ssse3_rep_memcpy+0xbe0> 406081: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406086: 48 81 c2 80 00 00 00 add $0x80,%rdx 40608d: 48 29 d7 sub %rdx,%rdi 406090: 48 29 d6 sub %rdx,%rsi 406093: 4c 8d 1d 9e 2d 00 00 lea 0x2d9e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 40609a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 40609e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4060a2: ff e2 jmpq *%rdx 4060a4: 0f 0b ud2 4060a6: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 4060ad: 00 00 00 4060b0: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4060b7: 0f 28 4e f8 movaps -0x8(%rsi),%xmm1 4060bb: 0f 28 56 08 movaps 0x8(%rsi),%xmm2 4060bf: 0f 28 5e 18 movaps 0x18(%rsi),%xmm3 4060c3: 0f 28 66 28 movaps 0x28(%rsi),%xmm4 4060c7: 0f 28 6e 38 movaps 0x38(%rsi),%xmm5 4060cb: 0f 28 76 48 movaps 0x48(%rsi),%xmm6 4060cf: 0f 28 7e 58 movaps 0x58(%rsi),%xmm7 4060d3: 44 0f 28 46 68 movaps 0x68(%rsi),%xmm8 4060d8: 44 0f 28 4e 78 movaps 0x78(%rsi),%xmm9 4060dd: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 4060e4: 66 45 0f 3a 0f c8 08 palignr $0x8,%xmm8,%xmm9 4060eb: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 4060f0: 66 44 0f 3a 0f c7 08 palignr $0x8,%xmm7,%xmm8 4060f7: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 4060fc: 66 0f 3a 0f fe 08 palignr $0x8,%xmm6,%xmm7 406102: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 406106: 66 0f 3a 0f f5 08 palignr $0x8,%xmm5,%xmm6 40610c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 406110: 66 0f 3a 0f ec 08 palignr $0x8,%xmm4,%xmm5 406116: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 40611a: 66 0f 3a 0f e3 08 palignr $0x8,%xmm3,%xmm4 406120: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 406124: 66 0f 3a 0f da 08 palignr $0x8,%xmm2,%xmm3 40612a: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 40612e: 66 0f 3a 0f d1 08 palignr $0x8,%xmm1,%xmm2 406134: 0f 29 17 movaps %xmm2,(%rdi) 406137: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 40613e: 0f 83 6c ff ff ff jae 4060b0 <__intel_ssse3_rep_memcpy+0xca0> 406144: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406149: 48 81 c2 80 00 00 00 add $0x80,%rdx 406150: 48 01 d7 add %rdx,%rdi 406153: 48 01 d6 add %rdx,%rsi 406156: 4c 8d 1d 1b 2f 00 00 lea 0x2f1b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 40615d: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 406161: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406165: ff e2 jmpq *%rdx 406167: 0f 0b ud2 406169: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 406170: 0f 28 4e f8 movaps -0x8(%rsi),%xmm1 406174: 0f 28 56 e8 movaps -0x18(%rsi),%xmm2 406178: 66 0f 3a 0f ca 08 palignr $0x8,%xmm2,%xmm1 40617e: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 406182: 0f 28 5e d8 movaps -0x28(%rsi),%xmm3 406186: 66 0f 3a 0f d3 08 palignr $0x8,%xmm3,%xmm2 40618c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 406190: 0f 28 66 c8 movaps -0x38(%rsi),%xmm4 406194: 66 0f 3a 0f dc 08 palignr $0x8,%xmm4,%xmm3 40619a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 40619e: 0f 28 6e b8 movaps -0x48(%rsi),%xmm5 4061a2: 66 0f 3a 0f e5 08 palignr $0x8,%xmm5,%xmm4 4061a8: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 4061ac: 0f 28 76 a8 movaps -0x58(%rsi),%xmm6 4061b0: 66 0f 3a 0f ee 08 palignr $0x8,%xmm6,%xmm5 4061b6: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 4061ba: 0f 28 7e 98 movaps -0x68(%rsi),%xmm7 4061be: 66 0f 3a 0f f7 08 palignr $0x8,%xmm7,%xmm6 4061c4: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 4061c8: 44 0f 28 46 88 movaps -0x78(%rsi),%xmm8 4061cd: 66 41 0f 3a 0f f8 08 palignr $0x8,%xmm8,%xmm7 4061d4: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 4061d8: 44 0f 28 8e 78 ff ff movaps -0x88(%rsi),%xmm9 4061df: ff 4061e0: 66 45 0f 3a 0f c1 08 palignr $0x8,%xmm9,%xmm8 4061e7: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 4061ec: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4061f3: 48 8d 7f 80 lea -0x80(%rdi),%rdi 4061f7: 48 8d 76 80 lea -0x80(%rsi),%rsi 4061fb: 0f 83 6f ff ff ff jae 406170 <__intel_ssse3_rep_memcpy+0xd60> 406201: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406206: 48 81 c2 80 00 00 00 add $0x80,%rdx 40620d: 48 29 d7 sub %rdx,%rdi 406210: 48 29 d6 sub %rdx,%rsi 406213: 4c 8d 1d 1e 2c 00 00 lea 0x2c1e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 40621a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 40621e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406222: ff e2 jmpq *%rdx 406224: 0f 0b ud2 406226: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 40622d: 00 00 00 406230: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406237: 0f 28 4e f7 movaps -0x9(%rsi),%xmm1 40623b: 0f 28 56 07 movaps 0x7(%rsi),%xmm2 40623f: 0f 28 5e 17 movaps 0x17(%rsi),%xmm3 406243: 0f 28 66 27 movaps 0x27(%rsi),%xmm4 406247: 0f 28 6e 37 movaps 0x37(%rsi),%xmm5 40624b: 0f 28 76 47 movaps 0x47(%rsi),%xmm6 40624f: 0f 28 7e 57 movaps 0x57(%rsi),%xmm7 406253: 44 0f 28 46 67 movaps 0x67(%rsi),%xmm8 406258: 44 0f 28 4e 77 movaps 0x77(%rsi),%xmm9 40625d: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 406264: 66 45 0f 3a 0f c8 09 palignr $0x9,%xmm8,%xmm9 40626b: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 406270: 66 44 0f 3a 0f c7 09 palignr $0x9,%xmm7,%xmm8 406277: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 40627c: 66 0f 3a 0f fe 09 palignr $0x9,%xmm6,%xmm7 406282: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 406286: 66 0f 3a 0f f5 09 palignr $0x9,%xmm5,%xmm6 40628c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 406290: 66 0f 3a 0f ec 09 palignr $0x9,%xmm4,%xmm5 406296: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 40629a: 66 0f 3a 0f e3 09 palignr $0x9,%xmm3,%xmm4 4062a0: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 4062a4: 66 0f 3a 0f da 09 palignr $0x9,%xmm2,%xmm3 4062aa: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 4062ae: 66 0f 3a 0f d1 09 palignr $0x9,%xmm1,%xmm2 4062b4: 0f 29 17 movaps %xmm2,(%rdi) 4062b7: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 4062be: 0f 83 6c ff ff ff jae 406230 <__intel_ssse3_rep_memcpy+0xe20> 4062c4: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 4062c9: 48 81 c2 80 00 00 00 add $0x80,%rdx 4062d0: 48 01 d7 add %rdx,%rdi 4062d3: 48 01 d6 add %rdx,%rsi 4062d6: 4c 8d 1d 9b 2d 00 00 lea 0x2d9b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 4062dd: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 4062e1: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4062e5: ff e2 jmpq *%rdx 4062e7: 0f 0b ud2 4062e9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4062f0: 0f 28 4e f7 movaps -0x9(%rsi),%xmm1 4062f4: 0f 28 56 e7 movaps -0x19(%rsi),%xmm2 4062f8: 66 0f 3a 0f ca 09 palignr $0x9,%xmm2,%xmm1 4062fe: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 406302: 0f 28 5e d7 movaps -0x29(%rsi),%xmm3 406306: 66 0f 3a 0f d3 09 palignr $0x9,%xmm3,%xmm2 40630c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 406310: 0f 28 66 c7 movaps -0x39(%rsi),%xmm4 406314: 66 0f 3a 0f dc 09 palignr $0x9,%xmm4,%xmm3 40631a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 40631e: 0f 28 6e b7 movaps -0x49(%rsi),%xmm5 406322: 66 0f 3a 0f e5 09 palignr $0x9,%xmm5,%xmm4 406328: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 40632c: 0f 28 76 a7 movaps -0x59(%rsi),%xmm6 406330: 66 0f 3a 0f ee 09 palignr $0x9,%xmm6,%xmm5 406336: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 40633a: 0f 28 7e 97 movaps -0x69(%rsi),%xmm7 40633e: 66 0f 3a 0f f7 09 palignr $0x9,%xmm7,%xmm6 406344: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 406348: 44 0f 28 46 87 movaps -0x79(%rsi),%xmm8 40634d: 66 41 0f 3a 0f f8 09 palignr $0x9,%xmm8,%xmm7 406354: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 406358: 44 0f 28 8e 77 ff ff movaps -0x89(%rsi),%xmm9 40635f: ff 406360: 66 45 0f 3a 0f c1 09 palignr $0x9,%xmm9,%xmm8 406367: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 40636c: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406373: 48 8d 7f 80 lea -0x80(%rdi),%rdi 406377: 48 8d 76 80 lea -0x80(%rsi),%rsi 40637b: 0f 83 6f ff ff ff jae 4062f0 <__intel_ssse3_rep_memcpy+0xee0> 406381: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406386: 48 81 c2 80 00 00 00 add $0x80,%rdx 40638d: 48 29 d7 sub %rdx,%rdi 406390: 48 29 d6 sub %rdx,%rsi 406393: 4c 8d 1d 9e 2a 00 00 lea 0x2a9e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 40639a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 40639e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4063a2: ff e2 jmpq *%rdx 4063a4: 0f 0b ud2 4063a6: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 4063ad: 00 00 00 4063b0: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4063b7: 0f 28 4e f6 movaps -0xa(%rsi),%xmm1 4063bb: 0f 28 56 06 movaps 0x6(%rsi),%xmm2 4063bf: 0f 28 5e 16 movaps 0x16(%rsi),%xmm3 4063c3: 0f 28 66 26 movaps 0x26(%rsi),%xmm4 4063c7: 0f 28 6e 36 movaps 0x36(%rsi),%xmm5 4063cb: 0f 28 76 46 movaps 0x46(%rsi),%xmm6 4063cf: 0f 28 7e 56 movaps 0x56(%rsi),%xmm7 4063d3: 44 0f 28 46 66 movaps 0x66(%rsi),%xmm8 4063d8: 44 0f 28 4e 76 movaps 0x76(%rsi),%xmm9 4063dd: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 4063e4: 66 45 0f 3a 0f c8 0a palignr $0xa,%xmm8,%xmm9 4063eb: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 4063f0: 66 44 0f 3a 0f c7 0a palignr $0xa,%xmm7,%xmm8 4063f7: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 4063fc: 66 0f 3a 0f fe 0a palignr $0xa,%xmm6,%xmm7 406402: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 406406: 66 0f 3a 0f f5 0a palignr $0xa,%xmm5,%xmm6 40640c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 406410: 66 0f 3a 0f ec 0a palignr $0xa,%xmm4,%xmm5 406416: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 40641a: 66 0f 3a 0f e3 0a palignr $0xa,%xmm3,%xmm4 406420: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 406424: 66 0f 3a 0f da 0a palignr $0xa,%xmm2,%xmm3 40642a: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 40642e: 66 0f 3a 0f d1 0a palignr $0xa,%xmm1,%xmm2 406434: 0f 29 17 movaps %xmm2,(%rdi) 406437: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 40643e: 0f 83 6c ff ff ff jae 4063b0 <__intel_ssse3_rep_memcpy+0xfa0> 406444: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406449: 48 81 c2 80 00 00 00 add $0x80,%rdx 406450: 48 01 d7 add %rdx,%rdi 406453: 48 01 d6 add %rdx,%rsi 406456: 4c 8d 1d 1b 2c 00 00 lea 0x2c1b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 40645d: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 406461: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406465: ff e2 jmpq *%rdx 406467: 0f 0b ud2 406469: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 406470: 0f 28 4e f6 movaps -0xa(%rsi),%xmm1 406474: 0f 28 56 e6 movaps -0x1a(%rsi),%xmm2 406478: 66 0f 3a 0f ca 0a palignr $0xa,%xmm2,%xmm1 40647e: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 406482: 0f 28 5e d6 movaps -0x2a(%rsi),%xmm3 406486: 66 0f 3a 0f d3 0a palignr $0xa,%xmm3,%xmm2 40648c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 406490: 0f 28 66 c6 movaps -0x3a(%rsi),%xmm4 406494: 66 0f 3a 0f dc 0a palignr $0xa,%xmm4,%xmm3 40649a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 40649e: 0f 28 6e b6 movaps -0x4a(%rsi),%xmm5 4064a2: 66 0f 3a 0f e5 0a palignr $0xa,%xmm5,%xmm4 4064a8: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 4064ac: 0f 28 76 a6 movaps -0x5a(%rsi),%xmm6 4064b0: 66 0f 3a 0f ee 0a palignr $0xa,%xmm6,%xmm5 4064b6: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 4064ba: 0f 28 7e 96 movaps -0x6a(%rsi),%xmm7 4064be: 66 0f 3a 0f f7 0a palignr $0xa,%xmm7,%xmm6 4064c4: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 4064c8: 44 0f 28 46 86 movaps -0x7a(%rsi),%xmm8 4064cd: 66 41 0f 3a 0f f8 0a palignr $0xa,%xmm8,%xmm7 4064d4: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 4064d8: 44 0f 28 8e 76 ff ff movaps -0x8a(%rsi),%xmm9 4064df: ff 4064e0: 66 45 0f 3a 0f c1 0a palignr $0xa,%xmm9,%xmm8 4064e7: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 4064ec: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4064f3: 48 8d 7f 80 lea -0x80(%rdi),%rdi 4064f7: 48 8d 76 80 lea -0x80(%rsi),%rsi 4064fb: 0f 83 6f ff ff ff jae 406470 <__intel_ssse3_rep_memcpy+0x1060> 406501: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406506: 48 81 c2 80 00 00 00 add $0x80,%rdx 40650d: 48 29 d7 sub %rdx,%rdi 406510: 48 29 d6 sub %rdx,%rsi 406513: 4c 8d 1d 1e 29 00 00 lea 0x291e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 40651a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 40651e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406522: ff e2 jmpq *%rdx 406524: 0f 0b ud2 406526: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 40652d: 00 00 00 406530: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406537: 0f 28 4e f5 movaps -0xb(%rsi),%xmm1 40653b: 0f 28 56 05 movaps 0x5(%rsi),%xmm2 40653f: 0f 28 5e 15 movaps 0x15(%rsi),%xmm3 406543: 0f 28 66 25 movaps 0x25(%rsi),%xmm4 406547: 0f 28 6e 35 movaps 0x35(%rsi),%xmm5 40654b: 0f 28 76 45 movaps 0x45(%rsi),%xmm6 40654f: 0f 28 7e 55 movaps 0x55(%rsi),%xmm7 406553: 44 0f 28 46 65 movaps 0x65(%rsi),%xmm8 406558: 44 0f 28 4e 75 movaps 0x75(%rsi),%xmm9 40655d: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 406564: 66 45 0f 3a 0f c8 0b palignr $0xb,%xmm8,%xmm9 40656b: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 406570: 66 44 0f 3a 0f c7 0b palignr $0xb,%xmm7,%xmm8 406577: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 40657c: 66 0f 3a 0f fe 0b palignr $0xb,%xmm6,%xmm7 406582: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 406586: 66 0f 3a 0f f5 0b palignr $0xb,%xmm5,%xmm6 40658c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 406590: 66 0f 3a 0f ec 0b palignr $0xb,%xmm4,%xmm5 406596: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 40659a: 66 0f 3a 0f e3 0b palignr $0xb,%xmm3,%xmm4 4065a0: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 4065a4: 66 0f 3a 0f da 0b palignr $0xb,%xmm2,%xmm3 4065aa: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 4065ae: 66 0f 3a 0f d1 0b palignr $0xb,%xmm1,%xmm2 4065b4: 0f 29 17 movaps %xmm2,(%rdi) 4065b7: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 4065be: 0f 83 6c ff ff ff jae 406530 <__intel_ssse3_rep_memcpy+0x1120> 4065c4: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 4065c9: 48 81 c2 80 00 00 00 add $0x80,%rdx 4065d0: 48 01 d7 add %rdx,%rdi 4065d3: 48 01 d6 add %rdx,%rsi 4065d6: 4c 8d 1d 9b 2a 00 00 lea 0x2a9b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 4065dd: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 4065e1: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4065e5: ff e2 jmpq *%rdx 4065e7: 0f 0b ud2 4065e9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4065f0: 0f 28 4e f5 movaps -0xb(%rsi),%xmm1 4065f4: 0f 28 56 e5 movaps -0x1b(%rsi),%xmm2 4065f8: 66 0f 3a 0f ca 0b palignr $0xb,%xmm2,%xmm1 4065fe: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 406602: 0f 28 5e d5 movaps -0x2b(%rsi),%xmm3 406606: 66 0f 3a 0f d3 0b palignr $0xb,%xmm3,%xmm2 40660c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 406610: 0f 28 66 c5 movaps -0x3b(%rsi),%xmm4 406614: 66 0f 3a 0f dc 0b palignr $0xb,%xmm4,%xmm3 40661a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 40661e: 0f 28 6e b5 movaps -0x4b(%rsi),%xmm5 406622: 66 0f 3a 0f e5 0b palignr $0xb,%xmm5,%xmm4 406628: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 40662c: 0f 28 76 a5 movaps -0x5b(%rsi),%xmm6 406630: 66 0f 3a 0f ee 0b palignr $0xb,%xmm6,%xmm5 406636: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 40663a: 0f 28 7e 95 movaps -0x6b(%rsi),%xmm7 40663e: 66 0f 3a 0f f7 0b palignr $0xb,%xmm7,%xmm6 406644: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 406648: 44 0f 28 46 85 movaps -0x7b(%rsi),%xmm8 40664d: 66 41 0f 3a 0f f8 0b palignr $0xb,%xmm8,%xmm7 406654: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 406658: 44 0f 28 8e 75 ff ff movaps -0x8b(%rsi),%xmm9 40665f: ff 406660: 66 45 0f 3a 0f c1 0b palignr $0xb,%xmm9,%xmm8 406667: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 40666c: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406673: 48 8d 7f 80 lea -0x80(%rdi),%rdi 406677: 48 8d 76 80 lea -0x80(%rsi),%rsi 40667b: 0f 83 6f ff ff ff jae 4065f0 <__intel_ssse3_rep_memcpy+0x11e0> 406681: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406686: 48 81 c2 80 00 00 00 add $0x80,%rdx 40668d: 48 29 d7 sub %rdx,%rdi 406690: 48 29 d6 sub %rdx,%rsi 406693: 4c 8d 1d 9e 27 00 00 lea 0x279e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 40669a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 40669e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4066a2: ff e2 jmpq *%rdx 4066a4: 0f 0b ud2 4066a6: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 4066ad: 00 00 00 4066b0: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4066b7: 66 0f 6f 4e f4 movdqa -0xc(%rsi),%xmm1 4066bc: 0f 28 56 04 movaps 0x4(%rsi),%xmm2 4066c0: 0f 28 5e 14 movaps 0x14(%rsi),%xmm3 4066c4: 0f 28 66 24 movaps 0x24(%rsi),%xmm4 4066c8: 0f 28 6e 34 movaps 0x34(%rsi),%xmm5 4066cc: 0f 28 76 44 movaps 0x44(%rsi),%xmm6 4066d0: 0f 28 7e 54 movaps 0x54(%rsi),%xmm7 4066d4: 44 0f 28 46 64 movaps 0x64(%rsi),%xmm8 4066d9: 44 0f 28 4e 74 movaps 0x74(%rsi),%xmm9 4066de: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 4066e5: 66 45 0f 3a 0f c8 0c palignr $0xc,%xmm8,%xmm9 4066ec: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 4066f1: 66 44 0f 3a 0f c7 0c palignr $0xc,%xmm7,%xmm8 4066f8: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 4066fd: 66 0f 3a 0f fe 0c palignr $0xc,%xmm6,%xmm7 406703: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 406707: 66 0f 3a 0f f5 0c palignr $0xc,%xmm5,%xmm6 40670d: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 406711: 66 0f 3a 0f ec 0c palignr $0xc,%xmm4,%xmm5 406717: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 40671b: 66 0f 3a 0f e3 0c palignr $0xc,%xmm3,%xmm4 406721: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 406725: 66 0f 3a 0f da 0c palignr $0xc,%xmm2,%xmm3 40672b: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 40672f: 66 0f 3a 0f d1 0c palignr $0xc,%xmm1,%xmm2 406735: 0f 29 17 movaps %xmm2,(%rdi) 406738: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 40673f: 0f 83 6b ff ff ff jae 4066b0 <__intel_ssse3_rep_memcpy+0x12a0> 406745: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 40674a: 48 81 c2 80 00 00 00 add $0x80,%rdx 406751: 48 01 d7 add %rdx,%rdi 406754: 48 01 d6 add %rdx,%rsi 406757: 4c 8d 1d 1a 29 00 00 lea 0x291a(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 40675e: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 406762: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406766: ff e2 jmpq *%rdx 406768: 0f 0b ud2 40676a: 66 0f 1f 44 00 00 nopw 0x0(%rax,%rax,1) 406770: 0f 28 4e f4 movaps -0xc(%rsi),%xmm1 406774: 0f 28 56 e4 movaps -0x1c(%rsi),%xmm2 406778: 66 0f 3a 0f ca 0c palignr $0xc,%xmm2,%xmm1 40677e: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 406782: 0f 28 5e d4 movaps -0x2c(%rsi),%xmm3 406786: 66 0f 3a 0f d3 0c palignr $0xc,%xmm3,%xmm2 40678c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 406790: 0f 28 66 c4 movaps -0x3c(%rsi),%xmm4 406794: 66 0f 3a 0f dc 0c palignr $0xc,%xmm4,%xmm3 40679a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 40679e: 0f 28 6e b4 movaps -0x4c(%rsi),%xmm5 4067a2: 66 0f 3a 0f e5 0c palignr $0xc,%xmm5,%xmm4 4067a8: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 4067ac: 0f 28 76 a4 movaps -0x5c(%rsi),%xmm6 4067b0: 66 0f 3a 0f ee 0c palignr $0xc,%xmm6,%xmm5 4067b6: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 4067ba: 0f 28 7e 94 movaps -0x6c(%rsi),%xmm7 4067be: 66 0f 3a 0f f7 0c palignr $0xc,%xmm7,%xmm6 4067c4: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 4067c8: 44 0f 28 46 84 movaps -0x7c(%rsi),%xmm8 4067cd: 66 41 0f 3a 0f f8 0c palignr $0xc,%xmm8,%xmm7 4067d4: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 4067d8: 44 0f 28 8e 74 ff ff movaps -0x8c(%rsi),%xmm9 4067df: ff 4067e0: 66 45 0f 3a 0f c1 0c palignr $0xc,%xmm9,%xmm8 4067e7: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 4067ec: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4067f3: 48 8d 7f 80 lea -0x80(%rdi),%rdi 4067f7: 48 8d 76 80 lea -0x80(%rsi),%rsi 4067fb: 0f 83 6f ff ff ff jae 406770 <__intel_ssse3_rep_memcpy+0x1360> 406801: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406806: 48 81 c2 80 00 00 00 add $0x80,%rdx 40680d: 48 29 d7 sub %rdx,%rdi 406810: 48 29 d6 sub %rdx,%rsi 406813: 4c 8d 1d 1e 26 00 00 lea 0x261e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 40681a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 40681e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406822: ff e2 jmpq *%rdx 406824: 0f 0b ud2 406826: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 40682d: 00 00 00 406830: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406837: 0f 28 4e f3 movaps -0xd(%rsi),%xmm1 40683b: 0f 28 56 03 movaps 0x3(%rsi),%xmm2 40683f: 0f 28 5e 13 movaps 0x13(%rsi),%xmm3 406843: 0f 28 66 23 movaps 0x23(%rsi),%xmm4 406847: 0f 28 6e 33 movaps 0x33(%rsi),%xmm5 40684b: 0f 28 76 43 movaps 0x43(%rsi),%xmm6 40684f: 0f 28 7e 53 movaps 0x53(%rsi),%xmm7 406853: 44 0f 28 46 63 movaps 0x63(%rsi),%xmm8 406858: 44 0f 28 4e 73 movaps 0x73(%rsi),%xmm9 40685d: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 406864: 66 45 0f 3a 0f c8 0d palignr $0xd,%xmm8,%xmm9 40686b: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 406870: 66 44 0f 3a 0f c7 0d palignr $0xd,%xmm7,%xmm8 406877: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 40687c: 66 0f 3a 0f fe 0d palignr $0xd,%xmm6,%xmm7 406882: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 406886: 66 0f 3a 0f f5 0d palignr $0xd,%xmm5,%xmm6 40688c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 406890: 66 0f 3a 0f ec 0d palignr $0xd,%xmm4,%xmm5 406896: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 40689a: 66 0f 3a 0f e3 0d palignr $0xd,%xmm3,%xmm4 4068a0: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 4068a4: 66 0f 3a 0f da 0d palignr $0xd,%xmm2,%xmm3 4068aa: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 4068ae: 66 0f 3a 0f d1 0d palignr $0xd,%xmm1,%xmm2 4068b4: 0f 29 17 movaps %xmm2,(%rdi) 4068b7: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 4068be: 0f 83 6c ff ff ff jae 406830 <__intel_ssse3_rep_memcpy+0x1420> 4068c4: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 4068c9: 48 81 c2 80 00 00 00 add $0x80,%rdx 4068d0: 48 01 d7 add %rdx,%rdi 4068d3: 48 01 d6 add %rdx,%rsi 4068d6: 4c 8d 1d 9b 27 00 00 lea 0x279b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 4068dd: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 4068e1: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4068e5: ff e2 jmpq *%rdx 4068e7: 0f 0b ud2 4068e9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4068f0: 0f 28 4e f3 movaps -0xd(%rsi),%xmm1 4068f4: 0f 28 56 e3 movaps -0x1d(%rsi),%xmm2 4068f8: 66 0f 3a 0f ca 0d palignr $0xd,%xmm2,%xmm1 4068fe: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 406902: 0f 28 5e d3 movaps -0x2d(%rsi),%xmm3 406906: 66 0f 3a 0f d3 0d palignr $0xd,%xmm3,%xmm2 40690c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 406910: 0f 28 66 c3 movaps -0x3d(%rsi),%xmm4 406914: 66 0f 3a 0f dc 0d palignr $0xd,%xmm4,%xmm3 40691a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 40691e: 0f 28 6e b3 movaps -0x4d(%rsi),%xmm5 406922: 66 0f 3a 0f e5 0d palignr $0xd,%xmm5,%xmm4 406928: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 40692c: 0f 28 76 a3 movaps -0x5d(%rsi),%xmm6 406930: 66 0f 3a 0f ee 0d palignr $0xd,%xmm6,%xmm5 406936: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 40693a: 0f 28 7e 93 movaps -0x6d(%rsi),%xmm7 40693e: 66 0f 3a 0f f7 0d palignr $0xd,%xmm7,%xmm6 406944: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 406948: 44 0f 28 46 83 movaps -0x7d(%rsi),%xmm8 40694d: 66 41 0f 3a 0f f8 0d palignr $0xd,%xmm8,%xmm7 406954: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 406958: 44 0f 28 8e 73 ff ff movaps -0x8d(%rsi),%xmm9 40695f: ff 406960: 66 45 0f 3a 0f c1 0d palignr $0xd,%xmm9,%xmm8 406967: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 40696c: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406973: 48 8d 7f 80 lea -0x80(%rdi),%rdi 406977: 48 8d 76 80 lea -0x80(%rsi),%rsi 40697b: 0f 83 6f ff ff ff jae 4068f0 <__intel_ssse3_rep_memcpy+0x14e0> 406981: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406986: 48 81 c2 80 00 00 00 add $0x80,%rdx 40698d: 48 29 d7 sub %rdx,%rdi 406990: 48 29 d6 sub %rdx,%rsi 406993: 4c 8d 1d 9e 24 00 00 lea 0x249e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 40699a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 40699e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 4069a2: ff e2 jmpq *%rdx 4069a4: 0f 0b ud2 4069a6: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 4069ad: 00 00 00 4069b0: 48 81 ea 80 00 00 00 sub $0x80,%rdx 4069b7: 0f 28 4e f2 movaps -0xe(%rsi),%xmm1 4069bb: 0f 28 56 02 movaps 0x2(%rsi),%xmm2 4069bf: 0f 28 5e 12 movaps 0x12(%rsi),%xmm3 4069c3: 0f 28 66 22 movaps 0x22(%rsi),%xmm4 4069c7: 0f 28 6e 32 movaps 0x32(%rsi),%xmm5 4069cb: 0f 28 76 42 movaps 0x42(%rsi),%xmm6 4069cf: 0f 28 7e 52 movaps 0x52(%rsi),%xmm7 4069d3: 44 0f 28 46 62 movaps 0x62(%rsi),%xmm8 4069d8: 44 0f 28 4e 72 movaps 0x72(%rsi),%xmm9 4069dd: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 4069e4: 66 45 0f 3a 0f c8 0e palignr $0xe,%xmm8,%xmm9 4069eb: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 4069f0: 66 44 0f 3a 0f c7 0e palignr $0xe,%xmm7,%xmm8 4069f7: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 4069fc: 66 0f 3a 0f fe 0e palignr $0xe,%xmm6,%xmm7 406a02: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 406a06: 66 0f 3a 0f f5 0e palignr $0xe,%xmm5,%xmm6 406a0c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 406a10: 66 0f 3a 0f ec 0e palignr $0xe,%xmm4,%xmm5 406a16: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 406a1a: 66 0f 3a 0f e3 0e palignr $0xe,%xmm3,%xmm4 406a20: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 406a24: 66 0f 3a 0f da 0e palignr $0xe,%xmm2,%xmm3 406a2a: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 406a2e: 66 0f 3a 0f d1 0e palignr $0xe,%xmm1,%xmm2 406a34: 0f 29 17 movaps %xmm2,(%rdi) 406a37: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 406a3e: 0f 83 6c ff ff ff jae 4069b0 <__intel_ssse3_rep_memcpy+0x15a0> 406a44: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406a49: 48 81 c2 80 00 00 00 add $0x80,%rdx 406a50: 48 01 d7 add %rdx,%rdi 406a53: 48 01 d6 add %rdx,%rsi 406a56: 4c 8d 1d 1b 26 00 00 lea 0x261b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 406a5d: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 406a61: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406a65: ff e2 jmpq *%rdx 406a67: 0f 0b ud2 406a69: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 406a70: 0f 28 4e f2 movaps -0xe(%rsi),%xmm1 406a74: 0f 28 56 e2 movaps -0x1e(%rsi),%xmm2 406a78: 66 0f 3a 0f ca 0e palignr $0xe,%xmm2,%xmm1 406a7e: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 406a82: 0f 28 5e d2 movaps -0x2e(%rsi),%xmm3 406a86: 66 0f 3a 0f d3 0e palignr $0xe,%xmm3,%xmm2 406a8c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 406a90: 0f 28 66 c2 movaps -0x3e(%rsi),%xmm4 406a94: 66 0f 3a 0f dc 0e palignr $0xe,%xmm4,%xmm3 406a9a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 406a9e: 0f 28 6e b2 movaps -0x4e(%rsi),%xmm5 406aa2: 66 0f 3a 0f e5 0e palignr $0xe,%xmm5,%xmm4 406aa8: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 406aac: 0f 28 76 a2 movaps -0x5e(%rsi),%xmm6 406ab0: 66 0f 3a 0f ee 0e palignr $0xe,%xmm6,%xmm5 406ab6: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 406aba: 0f 28 7e 92 movaps -0x6e(%rsi),%xmm7 406abe: 66 0f 3a 0f f7 0e palignr $0xe,%xmm7,%xmm6 406ac4: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 406ac8: 44 0f 28 46 82 movaps -0x7e(%rsi),%xmm8 406acd: 66 41 0f 3a 0f f8 0e palignr $0xe,%xmm8,%xmm7 406ad4: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 406ad8: 44 0f 28 8e 72 ff ff movaps -0x8e(%rsi),%xmm9 406adf: ff 406ae0: 66 45 0f 3a 0f c1 0e palignr $0xe,%xmm9,%xmm8 406ae7: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 406aec: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406af3: 48 8d 7f 80 lea -0x80(%rdi),%rdi 406af7: 48 8d 76 80 lea -0x80(%rsi),%rsi 406afb: 0f 83 6f ff ff ff jae 406a70 <__intel_ssse3_rep_memcpy+0x1660> 406b01: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406b06: 48 81 c2 80 00 00 00 add $0x80,%rdx 406b0d: 48 29 d7 sub %rdx,%rdi 406b10: 48 29 d6 sub %rdx,%rsi 406b13: 4c 8d 1d 1e 23 00 00 lea 0x231e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 406b1a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 406b1e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406b22: ff e2 jmpq *%rdx 406b24: 0f 0b ud2 406b26: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 406b2d: 00 00 00 406b30: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406b37: 0f 28 4e f1 movaps -0xf(%rsi),%xmm1 406b3b: 0f 28 56 01 movaps 0x1(%rsi),%xmm2 406b3f: 0f 28 5e 11 movaps 0x11(%rsi),%xmm3 406b43: 0f 28 66 21 movaps 0x21(%rsi),%xmm4 406b47: 0f 28 6e 31 movaps 0x31(%rsi),%xmm5 406b4b: 0f 28 76 41 movaps 0x41(%rsi),%xmm6 406b4f: 0f 28 7e 51 movaps 0x51(%rsi),%xmm7 406b53: 44 0f 28 46 61 movaps 0x61(%rsi),%xmm8 406b58: 44 0f 28 4e 71 movaps 0x71(%rsi),%xmm9 406b5d: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 406b64: 66 45 0f 3a 0f c8 0f palignr $0xf,%xmm8,%xmm9 406b6b: 44 0f 29 4f 70 movaps %xmm9,0x70(%rdi) 406b70: 66 44 0f 3a 0f c7 0f palignr $0xf,%xmm7,%xmm8 406b77: 44 0f 29 47 60 movaps %xmm8,0x60(%rdi) 406b7c: 66 0f 3a 0f fe 0f palignr $0xf,%xmm6,%xmm7 406b82: 0f 29 7f 50 movaps %xmm7,0x50(%rdi) 406b86: 66 0f 3a 0f f5 0f palignr $0xf,%xmm5,%xmm6 406b8c: 0f 29 77 40 movaps %xmm6,0x40(%rdi) 406b90: 66 0f 3a 0f ec 0f palignr $0xf,%xmm4,%xmm5 406b96: 0f 29 6f 30 movaps %xmm5,0x30(%rdi) 406b9a: 66 0f 3a 0f e3 0f palignr $0xf,%xmm3,%xmm4 406ba0: 0f 29 67 20 movaps %xmm4,0x20(%rdi) 406ba4: 66 0f 3a 0f da 0f palignr $0xf,%xmm2,%xmm3 406baa: 0f 29 5f 10 movaps %xmm3,0x10(%rdi) 406bae: 66 0f 3a 0f d1 0f palignr $0xf,%xmm1,%xmm2 406bb4: 0f 29 17 movaps %xmm2,(%rdi) 406bb7: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 406bbe: 0f 83 6c ff ff ff jae 406b30 <__intel_ssse3_rep_memcpy+0x1720> 406bc4: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406bc9: 48 81 c2 80 00 00 00 add $0x80,%rdx 406bd0: 48 01 d7 add %rdx,%rdi 406bd3: 48 01 d6 add %rdx,%rsi 406bd6: 4c 8d 1d 9b 24 00 00 lea 0x249b(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 406bdd: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 406be1: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406be5: ff e2 jmpq *%rdx 406be7: 0f 0b ud2 406be9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 406bf0: 0f 28 4e f1 movaps -0xf(%rsi),%xmm1 406bf4: 0f 28 56 e1 movaps -0x1f(%rsi),%xmm2 406bf8: 66 0f 3a 0f ca 0f palignr $0xf,%xmm2,%xmm1 406bfe: 0f 29 4f f0 movaps %xmm1,-0x10(%rdi) 406c02: 0f 28 5e d1 movaps -0x2f(%rsi),%xmm3 406c06: 66 0f 3a 0f d3 0f palignr $0xf,%xmm3,%xmm2 406c0c: 0f 29 57 e0 movaps %xmm2,-0x20(%rdi) 406c10: 0f 28 66 c1 movaps -0x3f(%rsi),%xmm4 406c14: 66 0f 3a 0f dc 0f palignr $0xf,%xmm4,%xmm3 406c1a: 0f 29 5f d0 movaps %xmm3,-0x30(%rdi) 406c1e: 0f 28 6e b1 movaps -0x4f(%rsi),%xmm5 406c22: 66 0f 3a 0f e5 0f palignr $0xf,%xmm5,%xmm4 406c28: 0f 29 67 c0 movaps %xmm4,-0x40(%rdi) 406c2c: 0f 28 76 a1 movaps -0x5f(%rsi),%xmm6 406c30: 66 0f 3a 0f ee 0f palignr $0xf,%xmm6,%xmm5 406c36: 0f 29 6f b0 movaps %xmm5,-0x50(%rdi) 406c3a: 0f 28 7e 91 movaps -0x6f(%rsi),%xmm7 406c3e: 66 0f 3a 0f f7 0f palignr $0xf,%xmm7,%xmm6 406c44: 0f 29 77 a0 movaps %xmm6,-0x60(%rdi) 406c48: 44 0f 28 46 81 movaps -0x7f(%rsi),%xmm8 406c4d: 66 41 0f 3a 0f f8 0f palignr $0xf,%xmm8,%xmm7 406c54: 0f 29 7f 90 movaps %xmm7,-0x70(%rdi) 406c58: 44 0f 28 8e 71 ff ff movaps -0x8f(%rsi),%xmm9 406c5f: ff 406c60: 66 45 0f 3a 0f c1 0f palignr $0xf,%xmm9,%xmm8 406c67: 44 0f 29 47 80 movaps %xmm8,-0x80(%rdi) 406c6c: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406c73: 48 8d 7f 80 lea -0x80(%rdi),%rdi 406c77: 48 8d 76 80 lea -0x80(%rsi),%rsi 406c7b: 0f 83 6f ff ff ff jae 406bf0 <__intel_ssse3_rep_memcpy+0x17e0> 406c81: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406c86: 48 81 c2 80 00 00 00 add $0x80,%rdx 406c8d: 48 29 d7 sub %rdx,%rdi 406c90: 48 29 d6 sub %rdx,%rsi 406c93: 4c 8d 1d 9e 21 00 00 lea 0x219e(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 406c9a: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 406c9e: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406ca2: ff e2 jmpq *%rdx 406ca4: 0f 0b ud2 406ca6: 66 2e 0f 1f 84 00 00 nopw %cs:0x0(%rax,%rax,1) 406cad: 00 00 00 406cb0: f3 0f 6f 0e movdqu (%rsi),%xmm1 406cb4: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406cb9: 66 0f 7f 0f movdqa %xmm1,(%rdi) 406cbd: 48 83 ea 10 sub $0x10,%rdx 406cc1: 48 83 c6 10 add $0x10,%rsi 406cc5: 48 83 c7 10 add $0x10,%rdi 406cc9: 8b 0d 35 3e 20 00 mov 0x203e35(%rip),%ecx # 60ab04 <__libirc_largest_cache_size_half> 406ccf: 48 39 ca cmp %rcx,%rdx 406cd2: 77 03 ja 406cd7 <__intel_ssse3_rep_memcpy+0x18c7> 406cd4: 48 89 d1 mov %rdx,%rcx 406cd7: 48 29 ca sub %rcx,%rdx 406cda: 48 81 fa 00 10 00 00 cmp $0x1000,%rdx 406ce1: 0f 86 a6 00 00 00 jbe 406d8d <__intel_ssse3_rep_memcpy+0x197d> 406ce7: 49 89 c9 mov %rcx,%r9 406cea: 49 c1 e1 03 shl $0x3,%r9 406cee: 4c 39 ca cmp %r9,%rdx 406cf1: 76 06 jbe 406cf9 <__intel_ssse3_rep_memcpy+0x18e9> 406cf3: 48 01 ca add %rcx,%rdx 406cf6: 48 31 c9 xor %rcx,%rcx 406cf9: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406d00: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406d07: 0f 18 8e 00 02 00 00 prefetcht0 0x200(%rsi) 406d0e: 0f 18 8e 00 03 00 00 prefetcht0 0x300(%rsi) 406d15: f3 0f 6f 06 movdqu (%rsi),%xmm0 406d19: f3 0f 6f 4e 10 movdqu 0x10(%rsi),%xmm1 406d1e: f3 0f 6f 56 20 movdqu 0x20(%rsi),%xmm2 406d23: f3 0f 6f 5e 30 movdqu 0x30(%rsi),%xmm3 406d28: f3 0f 6f 66 40 movdqu 0x40(%rsi),%xmm4 406d2d: f3 0f 6f 6e 50 movdqu 0x50(%rsi),%xmm5 406d32: f3 0f 6f 76 60 movdqu 0x60(%rsi),%xmm6 406d37: f3 0f 6f 7e 70 movdqu 0x70(%rsi),%xmm7 406d3c: 0f ae e8 lfence 406d3f: 66 0f e7 07 movntdq %xmm0,(%rdi) 406d43: 66 0f e7 4f 10 movntdq %xmm1,0x10(%rdi) 406d48: 66 0f e7 57 20 movntdq %xmm2,0x20(%rdi) 406d4d: 66 0f e7 5f 30 movntdq %xmm3,0x30(%rdi) 406d52: 66 0f e7 67 40 movntdq %xmm4,0x40(%rdi) 406d57: 66 0f e7 6f 50 movntdq %xmm5,0x50(%rdi) 406d5c: 66 0f e7 77 60 movntdq %xmm6,0x60(%rdi) 406d61: 66 0f e7 7f 70 movntdq %xmm7,0x70(%rdi) 406d66: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 406d6d: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 406d74: 73 8a jae 406d00 <__intel_ssse3_rep_memcpy+0x18f0> 406d76: 0f ae f8 sfence 406d79: 48 81 f9 80 00 00 00 cmp $0x80,%rcx 406d80: 0f 82 96 00 00 00 jb 406e1c <__intel_ssse3_rep_memcpy+0x1a0c> 406d86: 48 81 c2 80 00 00 00 add $0x80,%rdx 406d8d: 48 01 ca add %rcx,%rdx 406d90: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406d97: 0f 18 86 c0 01 00 00 prefetchnta 0x1c0(%rsi) 406d9e: 0f 18 86 80 02 00 00 prefetchnta 0x280(%rsi) 406da5: 0f 18 87 c0 01 00 00 prefetchnta 0x1c0(%rdi) 406dac: 0f 18 87 80 02 00 00 prefetchnta 0x280(%rdi) 406db3: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406dba: f3 0f 6f 06 movdqu (%rsi),%xmm0 406dbe: f3 0f 6f 4e 10 movdqu 0x10(%rsi),%xmm1 406dc3: f3 0f 6f 56 20 movdqu 0x20(%rsi),%xmm2 406dc8: f3 0f 6f 5e 30 movdqu 0x30(%rsi),%xmm3 406dcd: f3 0f 6f 66 40 movdqu 0x40(%rsi),%xmm4 406dd2: f3 0f 6f 6e 50 movdqu 0x50(%rsi),%xmm5 406dd7: f3 0f 6f 76 60 movdqu 0x60(%rsi),%xmm6 406ddc: f3 0f 6f 7e 70 movdqu 0x70(%rsi),%xmm7 406de1: 66 0f 7f 07 movdqa %xmm0,(%rdi) 406de5: 66 0f 7f 4f 10 movdqa %xmm1,0x10(%rdi) 406dea: 66 0f 7f 57 20 movdqa %xmm2,0x20(%rdi) 406def: 66 0f 7f 5f 30 movdqa %xmm3,0x30(%rdi) 406df4: 66 0f 7f 67 40 movdqa %xmm4,0x40(%rdi) 406df9: 66 0f 7f 6f 50 movdqa %xmm5,0x50(%rdi) 406dfe: 66 0f 7f 77 60 movdqa %xmm6,0x60(%rdi) 406e03: 66 0f 7f 7f 70 movdqa %xmm7,0x70(%rdi) 406e08: 48 8d b6 80 00 00 00 lea 0x80(%rsi),%rsi 406e0f: 48 8d bf 80 00 00 00 lea 0x80(%rdi),%rdi 406e16: 0f 83 7b ff ff ff jae 406d97 <__intel_ssse3_rep_memcpy+0x1987> 406e1c: 48 81 c2 80 00 00 00 add $0x80,%rdx 406e23: 48 01 d6 add %rdx,%rsi 406e26: 48 01 d7 add %rdx,%rdi 406e29: 4c 8d 1d 48 22 00 00 lea 0x2248(%rip),%r11 # 409078 <.L_2il0floatpacket.29+0x40c> 406e30: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 406e34: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406e38: ff e2 jmpq *%rdx 406e3a: 0f 0b ud2 406e3c: 0f 1f 40 00 nopl 0x0(%rax) 406e40: 48 01 d6 add %rdx,%rsi 406e43: 48 01 d7 add %rdx,%rdi 406e46: f3 0f 6f 46 f0 movdqu -0x10(%rsi),%xmm0 406e4b: 4c 8d 47 f0 lea -0x10(%rdi),%r8 406e4f: 49 89 f9 mov %rdi,%r9 406e52: 48 83 e7 f0 and $0xfffffffffffffff0,%rdi 406e56: 49 29 f9 sub %rdi,%r9 406e59: 4c 29 ce sub %r9,%rsi 406e5c: 4c 29 ca sub %r9,%rdx 406e5f: 8b 0d 9f 3c 20 00 mov 0x203c9f(%rip),%ecx # 60ab04 <__libirc_largest_cache_size_half> 406e65: 48 39 ca cmp %rcx,%rdx 406e68: 77 03 ja 406e6d <__intel_ssse3_rep_memcpy+0x1a5d> 406e6a: 48 89 d1 mov %rdx,%rcx 406e6d: 48 29 ca sub %rcx,%rdx 406e70: 48 81 fa 00 10 00 00 cmp $0x1000,%rdx 406e77: 0f 86 a4 00 00 00 jbe 406f21 <__intel_ssse3_rep_memcpy+0x1b11> 406e7d: 49 89 c9 mov %rcx,%r9 406e80: 49 c1 e1 03 shl $0x3,%r9 406e84: 4c 39 ca cmp %r9,%rdx 406e87: 76 06 jbe 406e8f <__intel_ssse3_rep_memcpy+0x1a7f> 406e89: 48 01 ca add %rcx,%rdx 406e8c: 48 31 c9 xor %rcx,%rcx 406e8f: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406e96: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406e9d: 0f 18 8e 00 fe ff ff prefetcht0 -0x200(%rsi) 406ea4: 0f 18 8e 00 fd ff ff prefetcht0 -0x300(%rsi) 406eab: f3 0f 6f 4e f0 movdqu -0x10(%rsi),%xmm1 406eb0: f3 0f 6f 56 e0 movdqu -0x20(%rsi),%xmm2 406eb5: f3 0f 6f 5e d0 movdqu -0x30(%rsi),%xmm3 406eba: f3 0f 6f 66 c0 movdqu -0x40(%rsi),%xmm4 406ebf: f3 0f 6f 6e b0 movdqu -0x50(%rsi),%xmm5 406ec4: f3 0f 6f 76 a0 movdqu -0x60(%rsi),%xmm6 406ec9: f3 0f 6f 7e 90 movdqu -0x70(%rsi),%xmm7 406ece: f3 44 0f 6f 46 80 movdqu -0x80(%rsi),%xmm8 406ed4: 0f ae e8 lfence 406ed7: 66 0f e7 4f f0 movntdq %xmm1,-0x10(%rdi) 406edc: 66 0f e7 57 e0 movntdq %xmm2,-0x20(%rdi) 406ee1: 66 0f e7 5f d0 movntdq %xmm3,-0x30(%rdi) 406ee6: 66 0f e7 67 c0 movntdq %xmm4,-0x40(%rdi) 406eeb: 66 0f e7 6f b0 movntdq %xmm5,-0x50(%rdi) 406ef0: 66 0f e7 77 a0 movntdq %xmm6,-0x60(%rdi) 406ef5: 66 0f e7 7f 90 movntdq %xmm7,-0x70(%rdi) 406efa: 66 44 0f e7 47 80 movntdq %xmm8,-0x80(%rdi) 406f00: 48 8d 76 80 lea -0x80(%rsi),%rsi 406f04: 48 8d 7f 80 lea -0x80(%rdi),%rdi 406f08: 73 8c jae 406e96 <__intel_ssse3_rep_memcpy+0x1a86> 406f0a: 0f ae f8 sfence 406f0d: 48 81 f9 80 00 00 00 cmp $0x80,%rcx 406f14: 0f 82 90 00 00 00 jb 406faa <__intel_ssse3_rep_memcpy+0x1b9a> 406f1a: 48 81 c2 80 00 00 00 add $0x80,%rdx 406f21: 48 01 ca add %rcx,%rdx 406f24: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406f2b: 0f 18 86 40 fe ff ff prefetchnta -0x1c0(%rsi) 406f32: 0f 18 86 80 fd ff ff prefetchnta -0x280(%rsi) 406f39: 0f 18 87 40 fe ff ff prefetchnta -0x1c0(%rdi) 406f40: 0f 18 87 80 fd ff ff prefetchnta -0x280(%rdi) 406f47: 48 81 ea 80 00 00 00 sub $0x80,%rdx 406f4e: f3 0f 6f 4e f0 movdqu -0x10(%rsi),%xmm1 406f53: f3 0f 6f 56 e0 movdqu -0x20(%rsi),%xmm2 406f58: f3 0f 6f 5e d0 movdqu -0x30(%rsi),%xmm3 406f5d: f3 0f 6f 66 c0 movdqu -0x40(%rsi),%xmm4 406f62: f3 0f 6f 6e b0 movdqu -0x50(%rsi),%xmm5 406f67: f3 0f 6f 76 a0 movdqu -0x60(%rsi),%xmm6 406f6c: f3 0f 6f 7e 90 movdqu -0x70(%rsi),%xmm7 406f71: f3 44 0f 6f 46 80 movdqu -0x80(%rsi),%xmm8 406f77: 66 0f 7f 4f f0 movdqa %xmm1,-0x10(%rdi) 406f7c: 66 0f 7f 57 e0 movdqa %xmm2,-0x20(%rdi) 406f81: 66 0f 7f 5f d0 movdqa %xmm3,-0x30(%rdi) 406f86: 66 0f 7f 67 c0 movdqa %xmm4,-0x40(%rdi) 406f8b: 66 0f 7f 6f b0 movdqa %xmm5,-0x50(%rdi) 406f90: 66 0f 7f 77 a0 movdqa %xmm6,-0x60(%rdi) 406f95: 66 0f 7f 7f 90 movdqa %xmm7,-0x70(%rdi) 406f9a: 66 44 0f 7f 47 80 movdqa %xmm8,-0x80(%rdi) 406fa0: 48 8d 76 80 lea -0x80(%rsi),%rsi 406fa4: 48 8d 7f 80 lea -0x80(%rdi),%rdi 406fa8: 73 81 jae 406f2b <__intel_ssse3_rep_memcpy+0x1b1b> 406faa: f3 41 0f 7f 00 movdqu %xmm0,(%r8) 406faf: 48 81 c2 80 00 00 00 add $0x80,%rdx 406fb6: 48 29 d6 sub %rdx,%rsi 406fb9: 48 29 d7 sub %rdx,%rdi 406fbc: 4c 8d 1d 75 1e 00 00 lea 0x1e75(%rip),%r11 # 408e38 <.L_2il0floatpacket.29+0x1cc> 406fc3: 49 63 14 93 movslq (%r11,%rdx,4),%rdx 406fc7: 49 8d 14 13 lea (%r11,%rdx,1),%rdx 406fcb: ff e2 jmpq *%rdx 406fcd: 0f 0b ud2 406fcf: 90 nop 406fd0: f2 0f f0 46 80 lddqu -0x80(%rsi),%xmm0 406fd5: f3 0f 7f 47 80 movdqu %xmm0,-0x80(%rdi) 406fda: f2 0f f0 46 90 lddqu -0x70(%rsi),%xmm0 406fdf: f3 0f 7f 47 90 movdqu %xmm0,-0x70(%rdi) 406fe4: f2 0f f0 46 a0 lddqu -0x60(%rsi),%xmm0 406fe9: f3 0f 7f 47 a0 movdqu %xmm0,-0x60(%rdi) 406fee: f2 0f f0 46 b0 lddqu -0x50(%rsi),%xmm0 406ff3: f3 0f 7f 47 b0 movdqu %xmm0,-0x50(%rdi) 406ff8: f2 0f f0 46 c0 lddqu -0x40(%rsi),%xmm0 406ffd: f3 0f 7f 47 c0 movdqu %xmm0,-0x40(%rdi) 407002: f2 0f f0 46 d0 lddqu -0x30(%rsi),%xmm0 407007: f3 0f 7f 47 d0 movdqu %xmm0,-0x30(%rdi) 40700c: f2 0f f0 46 e0 lddqu -0x20(%rsi),%xmm0 407011: f3 0f 7f 47 e0 movdqu %xmm0,-0x20(%rdi) 407016: f2 0f f0 46 f0 lddqu -0x10(%rsi),%xmm0 40701b: f3 0f 7f 47 f0 movdqu %xmm0,-0x10(%rdi) 407020: c3 retq 407021: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407028: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40702f: 00 407030: f2 0f f0 86 71 ff ff lddqu -0x8f(%rsi),%xmm0 407037: ff 407038: f3 0f 7f 87 71 ff ff movdqu %xmm0,-0x8f(%rdi) 40703f: ff 407040: f2 0f f0 46 81 lddqu -0x7f(%rsi),%xmm0 407045: f3 0f 7f 47 81 movdqu %xmm0,-0x7f(%rdi) 40704a: f2 0f f0 46 91 lddqu -0x6f(%rsi),%xmm0 40704f: f3 0f 7f 47 91 movdqu %xmm0,-0x6f(%rdi) 407054: f2 0f f0 46 a1 lddqu -0x5f(%rsi),%xmm0 407059: f3 0f 7f 47 a1 movdqu %xmm0,-0x5f(%rdi) 40705e: f2 0f f0 46 b1 lddqu -0x4f(%rsi),%xmm0 407063: f3 0f 7f 47 b1 movdqu %xmm0,-0x4f(%rdi) 407068: f2 0f f0 46 c1 lddqu -0x3f(%rsi),%xmm0 40706d: f3 0f 7f 47 c1 movdqu %xmm0,-0x3f(%rdi) 407072: f2 0f f0 46 d1 lddqu -0x2f(%rsi),%xmm0 407077: f3 0f 7f 47 d1 movdqu %xmm0,-0x2f(%rdi) 40707c: f2 0f f0 46 e1 lddqu -0x1f(%rsi),%xmm0 407081: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 407086: f3 0f 7f 47 e1 movdqu %xmm0,-0x1f(%rdi) 40708b: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 407090: c3 retq 407091: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407098: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40709f: 00 4070a0: 48 8b 56 f1 mov -0xf(%rsi),%rdx 4070a4: 48 8b 4e f8 mov -0x8(%rsi),%rcx 4070a8: 48 89 57 f1 mov %rdx,-0xf(%rdi) 4070ac: 48 89 4f f8 mov %rcx,-0x8(%rdi) 4070b0: c3 retq 4070b1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4070b8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4070bf: 00 4070c0: f2 0f f0 86 72 ff ff lddqu -0x8e(%rsi),%xmm0 4070c7: ff 4070c8: f3 0f 7f 87 72 ff ff movdqu %xmm0,-0x8e(%rdi) 4070cf: ff 4070d0: f2 0f f0 46 82 lddqu -0x7e(%rsi),%xmm0 4070d5: f3 0f 7f 47 82 movdqu %xmm0,-0x7e(%rdi) 4070da: f2 0f f0 46 92 lddqu -0x6e(%rsi),%xmm0 4070df: f3 0f 7f 47 92 movdqu %xmm0,-0x6e(%rdi) 4070e4: f2 0f f0 46 a2 lddqu -0x5e(%rsi),%xmm0 4070e9: f3 0f 7f 47 a2 movdqu %xmm0,-0x5e(%rdi) 4070ee: f2 0f f0 46 b2 lddqu -0x4e(%rsi),%xmm0 4070f3: f3 0f 7f 47 b2 movdqu %xmm0,-0x4e(%rdi) 4070f8: f2 0f f0 46 c2 lddqu -0x3e(%rsi),%xmm0 4070fd: f3 0f 7f 47 c2 movdqu %xmm0,-0x3e(%rdi) 407102: f2 0f f0 46 d2 lddqu -0x2e(%rsi),%xmm0 407107: f3 0f 7f 47 d2 movdqu %xmm0,-0x2e(%rdi) 40710c: f2 0f f0 46 e2 lddqu -0x1e(%rsi),%xmm0 407111: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 407116: f3 0f 7f 47 e2 movdqu %xmm0,-0x1e(%rdi) 40711b: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 407120: c3 retq 407121: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407128: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40712f: 00 407130: 48 8b 56 f2 mov -0xe(%rsi),%rdx 407134: 48 8b 4e f8 mov -0x8(%rsi),%rcx 407138: 48 89 57 f2 mov %rdx,-0xe(%rdi) 40713c: 48 89 4f f8 mov %rcx,-0x8(%rdi) 407140: c3 retq 407141: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407148: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40714f: 00 407150: f2 0f f0 86 73 ff ff lddqu -0x8d(%rsi),%xmm0 407157: ff 407158: f3 0f 7f 87 73 ff ff movdqu %xmm0,-0x8d(%rdi) 40715f: ff 407160: f2 0f f0 46 83 lddqu -0x7d(%rsi),%xmm0 407165: f3 0f 7f 47 83 movdqu %xmm0,-0x7d(%rdi) 40716a: f2 0f f0 46 93 lddqu -0x6d(%rsi),%xmm0 40716f: f3 0f 7f 47 93 movdqu %xmm0,-0x6d(%rdi) 407174: f2 0f f0 46 a3 lddqu -0x5d(%rsi),%xmm0 407179: f3 0f 7f 47 a3 movdqu %xmm0,-0x5d(%rdi) 40717e: f2 0f f0 46 b3 lddqu -0x4d(%rsi),%xmm0 407183: f3 0f 7f 47 b3 movdqu %xmm0,-0x4d(%rdi) 407188: f2 0f f0 46 c3 lddqu -0x3d(%rsi),%xmm0 40718d: f3 0f 7f 47 c3 movdqu %xmm0,-0x3d(%rdi) 407192: f2 0f f0 46 d3 lddqu -0x2d(%rsi),%xmm0 407197: f3 0f 7f 47 d3 movdqu %xmm0,-0x2d(%rdi) 40719c: f2 0f f0 46 e3 lddqu -0x1d(%rsi),%xmm0 4071a1: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 4071a6: f3 0f 7f 47 e3 movdqu %xmm0,-0x1d(%rdi) 4071ab: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 4071b0: c3 retq 4071b1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4071b8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4071bf: 00 4071c0: 48 8b 56 f3 mov -0xd(%rsi),%rdx 4071c4: 48 8b 4e f8 mov -0x8(%rsi),%rcx 4071c8: 48 89 57 f3 mov %rdx,-0xd(%rdi) 4071cc: 48 89 4f f8 mov %rcx,-0x8(%rdi) 4071d0: c3 retq 4071d1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4071d8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4071df: 00 4071e0: f2 0f f0 86 74 ff ff lddqu -0x8c(%rsi),%xmm0 4071e7: ff 4071e8: f3 0f 7f 87 74 ff ff movdqu %xmm0,-0x8c(%rdi) 4071ef: ff 4071f0: f2 0f f0 46 84 lddqu -0x7c(%rsi),%xmm0 4071f5: f3 0f 7f 47 84 movdqu %xmm0,-0x7c(%rdi) 4071fa: f2 0f f0 46 94 lddqu -0x6c(%rsi),%xmm0 4071ff: f3 0f 7f 47 94 movdqu %xmm0,-0x6c(%rdi) 407204: f2 0f f0 46 a4 lddqu -0x5c(%rsi),%xmm0 407209: f3 0f 7f 47 a4 movdqu %xmm0,-0x5c(%rdi) 40720e: f2 0f f0 46 b4 lddqu -0x4c(%rsi),%xmm0 407213: f3 0f 7f 47 b4 movdqu %xmm0,-0x4c(%rdi) 407218: f2 0f f0 46 c4 lddqu -0x3c(%rsi),%xmm0 40721d: f3 0f 7f 47 c4 movdqu %xmm0,-0x3c(%rdi) 407222: f2 0f f0 46 d4 lddqu -0x2c(%rsi),%xmm0 407227: f3 0f 7f 47 d4 movdqu %xmm0,-0x2c(%rdi) 40722c: f2 0f f0 46 e4 lddqu -0x1c(%rsi),%xmm0 407231: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 407236: f3 0f 7f 47 e4 movdqu %xmm0,-0x1c(%rdi) 40723b: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 407240: c3 retq 407241: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407248: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40724f: 00 407250: 48 8b 56 f4 mov -0xc(%rsi),%rdx 407254: 8b 4e fc mov -0x4(%rsi),%ecx 407257: 48 89 57 f4 mov %rdx,-0xc(%rdi) 40725b: 89 4f fc mov %ecx,-0x4(%rdi) 40725e: c3 retq 40725f: 90 nop 407260: f2 0f f0 86 75 ff ff lddqu -0x8b(%rsi),%xmm0 407267: ff 407268: f3 0f 7f 87 75 ff ff movdqu %xmm0,-0x8b(%rdi) 40726f: ff 407270: f2 0f f0 46 85 lddqu -0x7b(%rsi),%xmm0 407275: f3 0f 7f 47 85 movdqu %xmm0,-0x7b(%rdi) 40727a: f2 0f f0 46 95 lddqu -0x6b(%rsi),%xmm0 40727f: f3 0f 7f 47 95 movdqu %xmm0,-0x6b(%rdi) 407284: f2 0f f0 46 a5 lddqu -0x5b(%rsi),%xmm0 407289: f3 0f 7f 47 a5 movdqu %xmm0,-0x5b(%rdi) 40728e: f2 0f f0 46 b5 lddqu -0x4b(%rsi),%xmm0 407293: f3 0f 7f 47 b5 movdqu %xmm0,-0x4b(%rdi) 407298: f2 0f f0 46 c5 lddqu -0x3b(%rsi),%xmm0 40729d: f3 0f 7f 47 c5 movdqu %xmm0,-0x3b(%rdi) 4072a2: f2 0f f0 46 d5 lddqu -0x2b(%rsi),%xmm0 4072a7: f3 0f 7f 47 d5 movdqu %xmm0,-0x2b(%rdi) 4072ac: f2 0f f0 46 e5 lddqu -0x1b(%rsi),%xmm0 4072b1: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 4072b6: f3 0f 7f 47 e5 movdqu %xmm0,-0x1b(%rdi) 4072bb: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 4072c0: c3 retq 4072c1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4072c8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4072cf: 00 4072d0: 48 8b 56 f5 mov -0xb(%rsi),%rdx 4072d4: 8b 4e fc mov -0x4(%rsi),%ecx 4072d7: 48 89 57 f5 mov %rdx,-0xb(%rdi) 4072db: 89 4f fc mov %ecx,-0x4(%rdi) 4072de: c3 retq 4072df: 90 nop 4072e0: f2 0f f0 86 76 ff ff lddqu -0x8a(%rsi),%xmm0 4072e7: ff 4072e8: f3 0f 7f 87 76 ff ff movdqu %xmm0,-0x8a(%rdi) 4072ef: ff 4072f0: f2 0f f0 46 86 lddqu -0x7a(%rsi),%xmm0 4072f5: f3 0f 7f 47 86 movdqu %xmm0,-0x7a(%rdi) 4072fa: f2 0f f0 46 96 lddqu -0x6a(%rsi),%xmm0 4072ff: f3 0f 7f 47 96 movdqu %xmm0,-0x6a(%rdi) 407304: f2 0f f0 46 a6 lddqu -0x5a(%rsi),%xmm0 407309: f3 0f 7f 47 a6 movdqu %xmm0,-0x5a(%rdi) 40730e: f2 0f f0 46 b6 lddqu -0x4a(%rsi),%xmm0 407313: f3 0f 7f 47 b6 movdqu %xmm0,-0x4a(%rdi) 407318: f2 0f f0 46 c6 lddqu -0x3a(%rsi),%xmm0 40731d: f3 0f 7f 47 c6 movdqu %xmm0,-0x3a(%rdi) 407322: f2 0f f0 46 d6 lddqu -0x2a(%rsi),%xmm0 407327: f3 0f 7f 47 d6 movdqu %xmm0,-0x2a(%rdi) 40732c: f2 0f f0 46 e6 lddqu -0x1a(%rsi),%xmm0 407331: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 407336: f3 0f 7f 47 e6 movdqu %xmm0,-0x1a(%rdi) 40733b: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 407340: c3 retq 407341: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407348: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40734f: 00 407350: 48 8b 56 f6 mov -0xa(%rsi),%rdx 407354: 8b 4e fc mov -0x4(%rsi),%ecx 407357: 48 89 57 f6 mov %rdx,-0xa(%rdi) 40735b: 89 4f fc mov %ecx,-0x4(%rdi) 40735e: c3 retq 40735f: 90 nop 407360: f2 0f f0 86 77 ff ff lddqu -0x89(%rsi),%xmm0 407367: ff 407368: f3 0f 7f 87 77 ff ff movdqu %xmm0,-0x89(%rdi) 40736f: ff 407370: f2 0f f0 46 87 lddqu -0x79(%rsi),%xmm0 407375: f3 0f 7f 47 87 movdqu %xmm0,-0x79(%rdi) 40737a: f2 0f f0 46 97 lddqu -0x69(%rsi),%xmm0 40737f: f3 0f 7f 47 97 movdqu %xmm0,-0x69(%rdi) 407384: f2 0f f0 46 a7 lddqu -0x59(%rsi),%xmm0 407389: f3 0f 7f 47 a7 movdqu %xmm0,-0x59(%rdi) 40738e: f2 0f f0 46 b7 lddqu -0x49(%rsi),%xmm0 407393: f3 0f 7f 47 b7 movdqu %xmm0,-0x49(%rdi) 407398: f2 0f f0 46 c7 lddqu -0x39(%rsi),%xmm0 40739d: f3 0f 7f 47 c7 movdqu %xmm0,-0x39(%rdi) 4073a2: f2 0f f0 46 d7 lddqu -0x29(%rsi),%xmm0 4073a7: f3 0f 7f 47 d7 movdqu %xmm0,-0x29(%rdi) 4073ac: f2 0f f0 46 e7 lddqu -0x19(%rsi),%xmm0 4073b1: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 4073b6: f3 0f 7f 47 e7 movdqu %xmm0,-0x19(%rdi) 4073bb: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 4073c0: c3 retq 4073c1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4073c8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4073cf: 00 4073d0: 48 8b 56 f7 mov -0x9(%rsi),%rdx 4073d4: 8b 4e fc mov -0x4(%rsi),%ecx 4073d7: 48 89 57 f7 mov %rdx,-0x9(%rdi) 4073db: 89 4f fc mov %ecx,-0x4(%rdi) 4073de: c3 retq 4073df: 90 nop 4073e0: f2 0f f0 86 78 ff ff lddqu -0x88(%rsi),%xmm0 4073e7: ff 4073e8: f3 0f 7f 87 78 ff ff movdqu %xmm0,-0x88(%rdi) 4073ef: ff 4073f0: f2 0f f0 46 88 lddqu -0x78(%rsi),%xmm0 4073f5: f3 0f 7f 47 88 movdqu %xmm0,-0x78(%rdi) 4073fa: f2 0f f0 46 98 lddqu -0x68(%rsi),%xmm0 4073ff: f3 0f 7f 47 98 movdqu %xmm0,-0x68(%rdi) 407404: f2 0f f0 46 a8 lddqu -0x58(%rsi),%xmm0 407409: f3 0f 7f 47 a8 movdqu %xmm0,-0x58(%rdi) 40740e: f2 0f f0 46 b8 lddqu -0x48(%rsi),%xmm0 407413: f3 0f 7f 47 b8 movdqu %xmm0,-0x48(%rdi) 407418: f2 0f f0 46 c8 lddqu -0x38(%rsi),%xmm0 40741d: f3 0f 7f 47 c8 movdqu %xmm0,-0x38(%rdi) 407422: f2 0f f0 46 d8 lddqu -0x28(%rsi),%xmm0 407427: f3 0f 7f 47 d8 movdqu %xmm0,-0x28(%rdi) 40742c: f2 0f f0 46 e8 lddqu -0x18(%rsi),%xmm0 407431: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 407436: f3 0f 7f 47 e8 movdqu %xmm0,-0x18(%rdi) 40743b: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 407440: c3 retq 407441: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407448: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40744f: 00 407450: 48 8b 56 f8 mov -0x8(%rsi),%rdx 407454: 48 89 57 f8 mov %rdx,-0x8(%rdi) 407458: c3 retq 407459: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407460: f2 0f f0 86 79 ff ff lddqu -0x87(%rsi),%xmm0 407467: ff 407468: f3 0f 7f 87 79 ff ff movdqu %xmm0,-0x87(%rdi) 40746f: ff 407470: f2 0f f0 46 89 lddqu -0x77(%rsi),%xmm0 407475: f3 0f 7f 47 89 movdqu %xmm0,-0x77(%rdi) 40747a: f2 0f f0 46 99 lddqu -0x67(%rsi),%xmm0 40747f: f3 0f 7f 47 99 movdqu %xmm0,-0x67(%rdi) 407484: f2 0f f0 46 a9 lddqu -0x57(%rsi),%xmm0 407489: f3 0f 7f 47 a9 movdqu %xmm0,-0x57(%rdi) 40748e: f2 0f f0 46 b9 lddqu -0x47(%rsi),%xmm0 407493: f3 0f 7f 47 b9 movdqu %xmm0,-0x47(%rdi) 407498: f2 0f f0 46 c9 lddqu -0x37(%rsi),%xmm0 40749d: f3 0f 7f 47 c9 movdqu %xmm0,-0x37(%rdi) 4074a2: f2 0f f0 46 d9 lddqu -0x27(%rsi),%xmm0 4074a7: f3 0f 7f 47 d9 movdqu %xmm0,-0x27(%rdi) 4074ac: f2 0f f0 46 e9 lddqu -0x17(%rsi),%xmm0 4074b1: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 4074b6: f3 0f 7f 47 e9 movdqu %xmm0,-0x17(%rdi) 4074bb: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 4074c0: c3 retq 4074c1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4074c8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4074cf: 00 4074d0: 8b 56 f9 mov -0x7(%rsi),%edx 4074d3: 8b 4e fc mov -0x4(%rsi),%ecx 4074d6: 89 57 f9 mov %edx,-0x7(%rdi) 4074d9: 89 4f fc mov %ecx,-0x4(%rdi) 4074dc: c3 retq 4074dd: 0f 1f 00 nopl (%rax) 4074e0: f2 0f f0 86 7a ff ff lddqu -0x86(%rsi),%xmm0 4074e7: ff 4074e8: f3 0f 7f 87 7a ff ff movdqu %xmm0,-0x86(%rdi) 4074ef: ff 4074f0: f2 0f f0 46 8a lddqu -0x76(%rsi),%xmm0 4074f5: f3 0f 7f 47 8a movdqu %xmm0,-0x76(%rdi) 4074fa: f2 0f f0 46 9a lddqu -0x66(%rsi),%xmm0 4074ff: f3 0f 7f 47 9a movdqu %xmm0,-0x66(%rdi) 407504: f2 0f f0 46 aa lddqu -0x56(%rsi),%xmm0 407509: f3 0f 7f 47 aa movdqu %xmm0,-0x56(%rdi) 40750e: f2 0f f0 46 ba lddqu -0x46(%rsi),%xmm0 407513: f3 0f 7f 47 ba movdqu %xmm0,-0x46(%rdi) 407518: f2 0f f0 46 ca lddqu -0x36(%rsi),%xmm0 40751d: f3 0f 7f 47 ca movdqu %xmm0,-0x36(%rdi) 407522: f2 0f f0 46 da lddqu -0x26(%rsi),%xmm0 407527: f3 0f 7f 47 da movdqu %xmm0,-0x26(%rdi) 40752c: f2 0f f0 46 ea lddqu -0x16(%rsi),%xmm0 407531: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 407536: f3 0f 7f 47 ea movdqu %xmm0,-0x16(%rdi) 40753b: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 407540: c3 retq 407541: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407548: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40754f: 00 407550: 8b 56 fa mov -0x6(%rsi),%edx 407553: 8b 4e fc mov -0x4(%rsi),%ecx 407556: 89 57 fa mov %edx,-0x6(%rdi) 407559: 89 4f fc mov %ecx,-0x4(%rdi) 40755c: c3 retq 40755d: 0f 1f 00 nopl (%rax) 407560: f2 0f f0 86 7b ff ff lddqu -0x85(%rsi),%xmm0 407567: ff 407568: f3 0f 7f 87 7b ff ff movdqu %xmm0,-0x85(%rdi) 40756f: ff 407570: f2 0f f0 46 8b lddqu -0x75(%rsi),%xmm0 407575: f3 0f 7f 47 8b movdqu %xmm0,-0x75(%rdi) 40757a: f2 0f f0 46 9b lddqu -0x65(%rsi),%xmm0 40757f: f3 0f 7f 47 9b movdqu %xmm0,-0x65(%rdi) 407584: f2 0f f0 46 ab lddqu -0x55(%rsi),%xmm0 407589: f3 0f 7f 47 ab movdqu %xmm0,-0x55(%rdi) 40758e: f2 0f f0 46 bb lddqu -0x45(%rsi),%xmm0 407593: f3 0f 7f 47 bb movdqu %xmm0,-0x45(%rdi) 407598: f2 0f f0 46 cb lddqu -0x35(%rsi),%xmm0 40759d: f3 0f 7f 47 cb movdqu %xmm0,-0x35(%rdi) 4075a2: f2 0f f0 46 db lddqu -0x25(%rsi),%xmm0 4075a7: f3 0f 7f 47 db movdqu %xmm0,-0x25(%rdi) 4075ac: f2 0f f0 46 eb lddqu -0x15(%rsi),%xmm0 4075b1: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 4075b6: f3 0f 7f 47 eb movdqu %xmm0,-0x15(%rdi) 4075bb: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 4075c0: c3 retq 4075c1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4075c8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4075cf: 00 4075d0: 8b 56 fb mov -0x5(%rsi),%edx 4075d3: 8b 4e fc mov -0x4(%rsi),%ecx 4075d6: 89 57 fb mov %edx,-0x5(%rdi) 4075d9: 89 4f fc mov %ecx,-0x4(%rdi) 4075dc: c3 retq 4075dd: 0f 1f 00 nopl (%rax) 4075e0: f2 0f f0 86 7c ff ff lddqu -0x84(%rsi),%xmm0 4075e7: ff 4075e8: f3 0f 7f 87 7c ff ff movdqu %xmm0,-0x84(%rdi) 4075ef: ff 4075f0: f2 0f f0 46 8c lddqu -0x74(%rsi),%xmm0 4075f5: f3 0f 7f 47 8c movdqu %xmm0,-0x74(%rdi) 4075fa: f2 0f f0 46 9c lddqu -0x64(%rsi),%xmm0 4075ff: f3 0f 7f 47 9c movdqu %xmm0,-0x64(%rdi) 407604: f2 0f f0 46 ac lddqu -0x54(%rsi),%xmm0 407609: f3 0f 7f 47 ac movdqu %xmm0,-0x54(%rdi) 40760e: f2 0f f0 46 bc lddqu -0x44(%rsi),%xmm0 407613: f3 0f 7f 47 bc movdqu %xmm0,-0x44(%rdi) 407618: f2 0f f0 46 cc lddqu -0x34(%rsi),%xmm0 40761d: f3 0f 7f 47 cc movdqu %xmm0,-0x34(%rdi) 407622: f2 0f f0 46 dc lddqu -0x24(%rsi),%xmm0 407627: f3 0f 7f 47 dc movdqu %xmm0,-0x24(%rdi) 40762c: f2 0f f0 46 ec lddqu -0x14(%rsi),%xmm0 407631: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 407636: f3 0f 7f 47 ec movdqu %xmm0,-0x14(%rdi) 40763b: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 407640: c3 retq 407641: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407648: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40764f: 00 407650: 8b 56 fc mov -0x4(%rsi),%edx 407653: 89 57 fc mov %edx,-0x4(%rdi) 407656: c3 retq 407657: 66 0f 1f 84 00 00 00 nopw 0x0(%rax,%rax,1) 40765e: 00 00 407660: f2 0f f0 86 7d ff ff lddqu -0x83(%rsi),%xmm0 407667: ff 407668: f3 0f 7f 87 7d ff ff movdqu %xmm0,-0x83(%rdi) 40766f: ff 407670: f2 0f f0 46 8d lddqu -0x73(%rsi),%xmm0 407675: f3 0f 7f 47 8d movdqu %xmm0,-0x73(%rdi) 40767a: f2 0f f0 46 9d lddqu -0x63(%rsi),%xmm0 40767f: f3 0f 7f 47 9d movdqu %xmm0,-0x63(%rdi) 407684: f2 0f f0 46 ad lddqu -0x53(%rsi),%xmm0 407689: f3 0f 7f 47 ad movdqu %xmm0,-0x53(%rdi) 40768e: f2 0f f0 46 bd lddqu -0x43(%rsi),%xmm0 407693: f3 0f 7f 47 bd movdqu %xmm0,-0x43(%rdi) 407698: f2 0f f0 46 cd lddqu -0x33(%rsi),%xmm0 40769d: f3 0f 7f 47 cd movdqu %xmm0,-0x33(%rdi) 4076a2: f2 0f f0 46 dd lddqu -0x23(%rsi),%xmm0 4076a7: f3 0f 7f 47 dd movdqu %xmm0,-0x23(%rdi) 4076ac: f2 0f f0 46 ed lddqu -0x13(%rsi),%xmm0 4076b1: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 4076b6: f3 0f 7f 47 ed movdqu %xmm0,-0x13(%rdi) 4076bb: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 4076c0: c3 retq 4076c1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4076c8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4076cf: 00 4076d0: 66 8b 56 fd mov -0x3(%rsi),%dx 4076d4: 66 8b 4e fe mov -0x2(%rsi),%cx 4076d8: 66 89 57 fd mov %dx,-0x3(%rdi) 4076dc: 66 89 4f fe mov %cx,-0x2(%rdi) 4076e0: c3 retq 4076e1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4076e8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4076ef: 00 4076f0: f2 0f f0 86 7e ff ff lddqu -0x82(%rsi),%xmm0 4076f7: ff 4076f8: f3 0f 7f 87 7e ff ff movdqu %xmm0,-0x82(%rdi) 4076ff: ff 407700: f2 0f f0 46 8e lddqu -0x72(%rsi),%xmm0 407705: f3 0f 7f 47 8e movdqu %xmm0,-0x72(%rdi) 40770a: f2 0f f0 46 9e lddqu -0x62(%rsi),%xmm0 40770f: f3 0f 7f 47 9e movdqu %xmm0,-0x62(%rdi) 407714: f2 0f f0 46 ae lddqu -0x52(%rsi),%xmm0 407719: f3 0f 7f 47 ae movdqu %xmm0,-0x52(%rdi) 40771e: f2 0f f0 46 be lddqu -0x42(%rsi),%xmm0 407723: f3 0f 7f 47 be movdqu %xmm0,-0x42(%rdi) 407728: f2 0f f0 46 ce lddqu -0x32(%rsi),%xmm0 40772d: f3 0f 7f 47 ce movdqu %xmm0,-0x32(%rdi) 407732: f2 0f f0 46 de lddqu -0x22(%rsi),%xmm0 407737: f3 0f 7f 47 de movdqu %xmm0,-0x22(%rdi) 40773c: f2 0f f0 46 ee lddqu -0x12(%rsi),%xmm0 407741: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 407746: f3 0f 7f 47 ee movdqu %xmm0,-0x12(%rdi) 40774b: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 407750: c3 retq 407751: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407758: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 40775f: 00 407760: 0f b7 56 fe movzwl -0x2(%rsi),%edx 407764: 66 89 57 fe mov %dx,-0x2(%rdi) 407768: c3 retq 407769: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407770: f2 0f f0 86 7f ff ff lddqu -0x81(%rsi),%xmm0 407777: ff 407778: f3 0f 7f 87 7f ff ff movdqu %xmm0,-0x81(%rdi) 40777f: ff 407780: f2 0f f0 46 8f lddqu -0x71(%rsi),%xmm0 407785: f3 0f 7f 47 8f movdqu %xmm0,-0x71(%rdi) 40778a: f2 0f f0 46 9f lddqu -0x61(%rsi),%xmm0 40778f: f3 0f 7f 47 9f movdqu %xmm0,-0x61(%rdi) 407794: f2 0f f0 46 af lddqu -0x51(%rsi),%xmm0 407799: f3 0f 7f 47 af movdqu %xmm0,-0x51(%rdi) 40779e: f2 0f f0 46 bf lddqu -0x41(%rsi),%xmm0 4077a3: f3 0f 7f 47 bf movdqu %xmm0,-0x41(%rdi) 4077a8: f2 0f f0 46 cf lddqu -0x31(%rsi),%xmm0 4077ad: f3 0f 7f 47 cf movdqu %xmm0,-0x31(%rdi) 4077b2: f2 0f f0 46 df lddqu -0x21(%rsi),%xmm0 4077b7: f3 0f 7f 47 df movdqu %xmm0,-0x21(%rdi) 4077bc: f2 0f f0 46 ef lddqu -0x11(%rsi),%xmm0 4077c1: f2 0f f0 4e f0 lddqu -0x10(%rsi),%xmm1 4077c6: f3 0f 7f 47 ef movdqu %xmm0,-0x11(%rdi) 4077cb: f3 0f 7f 4f f0 movdqu %xmm1,-0x10(%rdi) 4077d0: c3 retq 4077d1: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4077d8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4077df: 00 4077e0: 0f b6 56 ff movzbl -0x1(%rsi),%edx 4077e4: 88 57 ff mov %dl,-0x1(%rdi) 4077e7: c3 retq 4077e8: 0f 1f 84 00 00 00 00 nopl 0x0(%rax,%rax,1) 4077ef: 00 4077f0: f2 0f f0 46 70 lddqu 0x70(%rsi),%xmm0 4077f5: f3 0f 7f 47 70 movdqu %xmm0,0x70(%rdi) 4077fa: f2 0f f0 46 60 lddqu 0x60(%rsi),%xmm0 4077ff: f3 0f 7f 47 60 movdqu %xmm0,0x60(%rdi) 407804: f2 0f f0 46 50 lddqu 0x50(%rsi),%xmm0 407809: f3 0f 7f 47 50 movdqu %xmm0,0x50(%rdi) 40780e: f2 0f f0 46 40 lddqu 0x40(%rsi),%xmm0 407813: f3 0f 7f 47 40 movdqu %xmm0,0x40(%rdi) 407818: f2 0f f0 46 30 lddqu 0x30(%rsi),%xmm0 40781d: f3 0f 7f 47 30 movdqu %xmm0,0x30(%rdi) 407822: f2 0f f0 46 20 lddqu 0x20(%rsi),%xmm0 407827: f3 0f 7f 47 20 movdqu %xmm0,0x20(%rdi) 40782c: f2 0f f0 46 10 lddqu 0x10(%rsi),%xmm0 407831: f3 0f 7f 47 10 movdqu %xmm0,0x10(%rdi) 407836: f2 0f f0 06 lddqu (%rsi),%xmm0 40783a: f3 0f 7f 07 movdqu %xmm0,(%rdi) 40783e: c3 retq 40783f: 90 nop 407840: f2 0f f0 46 7f lddqu 0x7f(%rsi),%xmm0 407845: f3 0f 7f 47 7f movdqu %xmm0,0x7f(%rdi) 40784a: f2 0f f0 46 6f lddqu 0x6f(%rsi),%xmm0 40784f: f3 0f 7f 47 6f movdqu %xmm0,0x6f(%rdi) 407854: f2 0f f0 46 5f lddqu 0x5f(%rsi),%xmm0 407859: f3 0f 7f 47 5f movdqu %xmm0,0x5f(%rdi) 40785e: f2 0f f0 46 4f lddqu 0x4f(%rsi),%xmm0 407863: f3 0f 7f 47 4f movdqu %xmm0,0x4f(%rdi) 407868: f2 0f f0 46 3f lddqu 0x3f(%rsi),%xmm0 40786d: f3 0f 7f 47 3f movdqu %xmm0,0x3f(%rdi) 407872: f2 0f f0 46 2f lddqu 0x2f(%rsi),%xmm0 407877: f3 0f 7f 47 2f movdqu %xmm0,0x2f(%rdi) 40787c: f2 0f f0 46 1f lddqu 0x1f(%rsi),%xmm0 407881: f3 0f 7f 47 1f movdqu %xmm0,0x1f(%rdi) 407886: f2 0f f0 46 0f lddqu 0xf(%rsi),%xmm0 40788b: f2 0f f0 0e lddqu (%rsi),%xmm1 40788f: f3 0f 7f 47 0f movdqu %xmm0,0xf(%rdi) 407894: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407898: c3 retq 407899: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4078a0: 48 8b 56 07 mov 0x7(%rsi),%rdx 4078a4: 48 8b 0e mov (%rsi),%rcx 4078a7: 48 89 57 07 mov %rdx,0x7(%rdi) 4078ab: 48 89 0f mov %rcx,(%rdi) 4078ae: c3 retq 4078af: 90 nop 4078b0: f2 0f f0 46 7e lddqu 0x7e(%rsi),%xmm0 4078b5: f3 0f 7f 47 7e movdqu %xmm0,0x7e(%rdi) 4078ba: f2 0f f0 46 6e lddqu 0x6e(%rsi),%xmm0 4078bf: f3 0f 7f 47 6e movdqu %xmm0,0x6e(%rdi) 4078c4: f2 0f f0 46 5e lddqu 0x5e(%rsi),%xmm0 4078c9: f3 0f 7f 47 5e movdqu %xmm0,0x5e(%rdi) 4078ce: f2 0f f0 46 4e lddqu 0x4e(%rsi),%xmm0 4078d3: f3 0f 7f 47 4e movdqu %xmm0,0x4e(%rdi) 4078d8: f2 0f f0 46 3e lddqu 0x3e(%rsi),%xmm0 4078dd: f3 0f 7f 47 3e movdqu %xmm0,0x3e(%rdi) 4078e2: f2 0f f0 46 2e lddqu 0x2e(%rsi),%xmm0 4078e7: f3 0f 7f 47 2e movdqu %xmm0,0x2e(%rdi) 4078ec: f2 0f f0 46 1e lddqu 0x1e(%rsi),%xmm0 4078f1: f3 0f 7f 47 1e movdqu %xmm0,0x1e(%rdi) 4078f6: f2 0f f0 46 0e lddqu 0xe(%rsi),%xmm0 4078fb: f2 0f f0 0e lddqu (%rsi),%xmm1 4078ff: f3 0f 7f 47 0e movdqu %xmm0,0xe(%rdi) 407904: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407908: c3 retq 407909: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407910: 48 8b 56 06 mov 0x6(%rsi),%rdx 407914: 48 8b 0e mov (%rsi),%rcx 407917: 48 89 57 06 mov %rdx,0x6(%rdi) 40791b: 48 89 0f mov %rcx,(%rdi) 40791e: c3 retq 40791f: 90 nop 407920: f2 0f f0 46 7d lddqu 0x7d(%rsi),%xmm0 407925: f3 0f 7f 47 7d movdqu %xmm0,0x7d(%rdi) 40792a: f2 0f f0 46 6d lddqu 0x6d(%rsi),%xmm0 40792f: f3 0f 7f 47 6d movdqu %xmm0,0x6d(%rdi) 407934: f2 0f f0 46 5d lddqu 0x5d(%rsi),%xmm0 407939: f3 0f 7f 47 5d movdqu %xmm0,0x5d(%rdi) 40793e: f2 0f f0 46 4d lddqu 0x4d(%rsi),%xmm0 407943: f3 0f 7f 47 4d movdqu %xmm0,0x4d(%rdi) 407948: f2 0f f0 46 3d lddqu 0x3d(%rsi),%xmm0 40794d: f3 0f 7f 47 3d movdqu %xmm0,0x3d(%rdi) 407952: f2 0f f0 46 2d lddqu 0x2d(%rsi),%xmm0 407957: f3 0f 7f 47 2d movdqu %xmm0,0x2d(%rdi) 40795c: f2 0f f0 46 1d lddqu 0x1d(%rsi),%xmm0 407961: f3 0f 7f 47 1d movdqu %xmm0,0x1d(%rdi) 407966: f2 0f f0 46 0d lddqu 0xd(%rsi),%xmm0 40796b: f2 0f f0 0e lddqu (%rsi),%xmm1 40796f: f3 0f 7f 47 0d movdqu %xmm0,0xd(%rdi) 407974: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407978: c3 retq 407979: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407980: 48 8b 56 05 mov 0x5(%rsi),%rdx 407984: 48 8b 0e mov (%rsi),%rcx 407987: 48 89 57 05 mov %rdx,0x5(%rdi) 40798b: 48 89 0f mov %rcx,(%rdi) 40798e: c3 retq 40798f: 90 nop 407990: f2 0f f0 46 7c lddqu 0x7c(%rsi),%xmm0 407995: f3 0f 7f 47 7c movdqu %xmm0,0x7c(%rdi) 40799a: f2 0f f0 46 6c lddqu 0x6c(%rsi),%xmm0 40799f: f3 0f 7f 47 6c movdqu %xmm0,0x6c(%rdi) 4079a4: f2 0f f0 46 5c lddqu 0x5c(%rsi),%xmm0 4079a9: f3 0f 7f 47 5c movdqu %xmm0,0x5c(%rdi) 4079ae: f2 0f f0 46 4c lddqu 0x4c(%rsi),%xmm0 4079b3: f3 0f 7f 47 4c movdqu %xmm0,0x4c(%rdi) 4079b8: f2 0f f0 46 3c lddqu 0x3c(%rsi),%xmm0 4079bd: f3 0f 7f 47 3c movdqu %xmm0,0x3c(%rdi) 4079c2: f2 0f f0 46 2c lddqu 0x2c(%rsi),%xmm0 4079c7: f3 0f 7f 47 2c movdqu %xmm0,0x2c(%rdi) 4079cc: f2 0f f0 46 1c lddqu 0x1c(%rsi),%xmm0 4079d1: f3 0f 7f 47 1c movdqu %xmm0,0x1c(%rdi) 4079d6: f2 0f f0 46 0c lddqu 0xc(%rsi),%xmm0 4079db: f2 0f f0 0e lddqu (%rsi),%xmm1 4079df: f3 0f 7f 47 0c movdqu %xmm0,0xc(%rdi) 4079e4: f3 0f 7f 0f movdqu %xmm1,(%rdi) 4079e8: c3 retq 4079e9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 4079f0: 48 8b 56 04 mov 0x4(%rsi),%rdx 4079f4: 48 8b 0e mov (%rsi),%rcx 4079f7: 48 89 57 04 mov %rdx,0x4(%rdi) 4079fb: 48 89 0f mov %rcx,(%rdi) 4079fe: c3 retq 4079ff: 90 nop 407a00: f2 0f f0 46 7b lddqu 0x7b(%rsi),%xmm0 407a05: f3 0f 7f 47 7b movdqu %xmm0,0x7b(%rdi) 407a0a: f2 0f f0 46 6b lddqu 0x6b(%rsi),%xmm0 407a0f: f3 0f 7f 47 6b movdqu %xmm0,0x6b(%rdi) 407a14: f2 0f f0 46 5b lddqu 0x5b(%rsi),%xmm0 407a19: f3 0f 7f 47 5b movdqu %xmm0,0x5b(%rdi) 407a1e: f2 0f f0 46 4b lddqu 0x4b(%rsi),%xmm0 407a23: f3 0f 7f 47 4b movdqu %xmm0,0x4b(%rdi) 407a28: f2 0f f0 46 3b lddqu 0x3b(%rsi),%xmm0 407a2d: f3 0f 7f 47 3b movdqu %xmm0,0x3b(%rdi) 407a32: f2 0f f0 46 2b lddqu 0x2b(%rsi),%xmm0 407a37: f3 0f 7f 47 2b movdqu %xmm0,0x2b(%rdi) 407a3c: f2 0f f0 46 1b lddqu 0x1b(%rsi),%xmm0 407a41: f3 0f 7f 47 1b movdqu %xmm0,0x1b(%rdi) 407a46: f2 0f f0 46 0b lddqu 0xb(%rsi),%xmm0 407a4b: f2 0f f0 0e lddqu (%rsi),%xmm1 407a4f: f3 0f 7f 47 0b movdqu %xmm0,0xb(%rdi) 407a54: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407a58: c3 retq 407a59: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407a60: 48 8b 56 03 mov 0x3(%rsi),%rdx 407a64: 48 8b 0e mov (%rsi),%rcx 407a67: 48 89 57 03 mov %rdx,0x3(%rdi) 407a6b: 48 89 0f mov %rcx,(%rdi) 407a6e: c3 retq 407a6f: 90 nop 407a70: f2 0f f0 46 7a lddqu 0x7a(%rsi),%xmm0 407a75: f3 0f 7f 47 7a movdqu %xmm0,0x7a(%rdi) 407a7a: f2 0f f0 46 6a lddqu 0x6a(%rsi),%xmm0 407a7f: f3 0f 7f 47 6a movdqu %xmm0,0x6a(%rdi) 407a84: f2 0f f0 46 5a lddqu 0x5a(%rsi),%xmm0 407a89: f3 0f 7f 47 5a movdqu %xmm0,0x5a(%rdi) 407a8e: f2 0f f0 46 4a lddqu 0x4a(%rsi),%xmm0 407a93: f3 0f 7f 47 4a movdqu %xmm0,0x4a(%rdi) 407a98: f2 0f f0 46 3a lddqu 0x3a(%rsi),%xmm0 407a9d: f3 0f 7f 47 3a movdqu %xmm0,0x3a(%rdi) 407aa2: f2 0f f0 46 2a lddqu 0x2a(%rsi),%xmm0 407aa7: f3 0f 7f 47 2a movdqu %xmm0,0x2a(%rdi) 407aac: f2 0f f0 46 1a lddqu 0x1a(%rsi),%xmm0 407ab1: f3 0f 7f 47 1a movdqu %xmm0,0x1a(%rdi) 407ab6: f2 0f f0 46 0a lddqu 0xa(%rsi),%xmm0 407abb: f2 0f f0 0e lddqu (%rsi),%xmm1 407abf: f3 0f 7f 47 0a movdqu %xmm0,0xa(%rdi) 407ac4: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407ac8: c3 retq 407ac9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407ad0: 48 8b 56 02 mov 0x2(%rsi),%rdx 407ad4: 48 8b 0e mov (%rsi),%rcx 407ad7: 48 89 57 02 mov %rdx,0x2(%rdi) 407adb: 48 89 0f mov %rcx,(%rdi) 407ade: c3 retq 407adf: 90 nop 407ae0: f2 0f f0 46 79 lddqu 0x79(%rsi),%xmm0 407ae5: f3 0f 7f 47 79 movdqu %xmm0,0x79(%rdi) 407aea: f2 0f f0 46 69 lddqu 0x69(%rsi),%xmm0 407aef: f3 0f 7f 47 69 movdqu %xmm0,0x69(%rdi) 407af4: f2 0f f0 46 59 lddqu 0x59(%rsi),%xmm0 407af9: f3 0f 7f 47 59 movdqu %xmm0,0x59(%rdi) 407afe: f2 0f f0 46 49 lddqu 0x49(%rsi),%xmm0 407b03: f3 0f 7f 47 49 movdqu %xmm0,0x49(%rdi) 407b08: f2 0f f0 46 39 lddqu 0x39(%rsi),%xmm0 407b0d: f3 0f 7f 47 39 movdqu %xmm0,0x39(%rdi) 407b12: f2 0f f0 46 29 lddqu 0x29(%rsi),%xmm0 407b17: f3 0f 7f 47 29 movdqu %xmm0,0x29(%rdi) 407b1c: f2 0f f0 46 19 lddqu 0x19(%rsi),%xmm0 407b21: f3 0f 7f 47 19 movdqu %xmm0,0x19(%rdi) 407b26: f2 0f f0 46 09 lddqu 0x9(%rsi),%xmm0 407b2b: f2 0f f0 0e lddqu (%rsi),%xmm1 407b2f: f3 0f 7f 47 09 movdqu %xmm0,0x9(%rdi) 407b34: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407b38: c3 retq 407b39: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407b40: 48 8b 56 01 mov 0x1(%rsi),%rdx 407b44: 48 8b 0e mov (%rsi),%rcx 407b47: 48 89 57 01 mov %rdx,0x1(%rdi) 407b4b: 48 89 0f mov %rcx,(%rdi) 407b4e: c3 retq 407b4f: 90 nop 407b50: f2 0f f0 46 78 lddqu 0x78(%rsi),%xmm0 407b55: f3 0f 7f 47 78 movdqu %xmm0,0x78(%rdi) 407b5a: f2 0f f0 46 68 lddqu 0x68(%rsi),%xmm0 407b5f: f3 0f 7f 47 68 movdqu %xmm0,0x68(%rdi) 407b64: f2 0f f0 46 58 lddqu 0x58(%rsi),%xmm0 407b69: f3 0f 7f 47 58 movdqu %xmm0,0x58(%rdi) 407b6e: f2 0f f0 46 48 lddqu 0x48(%rsi),%xmm0 407b73: f3 0f 7f 47 48 movdqu %xmm0,0x48(%rdi) 407b78: f2 0f f0 46 38 lddqu 0x38(%rsi),%xmm0 407b7d: f3 0f 7f 47 38 movdqu %xmm0,0x38(%rdi) 407b82: f2 0f f0 46 28 lddqu 0x28(%rsi),%xmm0 407b87: f3 0f 7f 47 28 movdqu %xmm0,0x28(%rdi) 407b8c: f2 0f f0 46 18 lddqu 0x18(%rsi),%xmm0 407b91: f3 0f 7f 47 18 movdqu %xmm0,0x18(%rdi) 407b96: f2 0f f0 46 08 lddqu 0x8(%rsi),%xmm0 407b9b: f2 0f f0 0e lddqu (%rsi),%xmm1 407b9f: f3 0f 7f 47 08 movdqu %xmm0,0x8(%rdi) 407ba4: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407ba8: c3 retq 407ba9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407bb0: 48 8b 16 mov (%rsi),%rdx 407bb3: 48 89 17 mov %rdx,(%rdi) 407bb6: c3 retq 407bb7: 66 0f 1f 84 00 00 00 nopw 0x0(%rax,%rax,1) 407bbe: 00 00 407bc0: f2 0f f0 46 77 lddqu 0x77(%rsi),%xmm0 407bc5: f3 0f 7f 47 77 movdqu %xmm0,0x77(%rdi) 407bca: f2 0f f0 46 67 lddqu 0x67(%rsi),%xmm0 407bcf: f3 0f 7f 47 67 movdqu %xmm0,0x67(%rdi) 407bd4: f2 0f f0 46 57 lddqu 0x57(%rsi),%xmm0 407bd9: f3 0f 7f 47 57 movdqu %xmm0,0x57(%rdi) 407bde: f2 0f f0 46 47 lddqu 0x47(%rsi),%xmm0 407be3: f3 0f 7f 47 47 movdqu %xmm0,0x47(%rdi) 407be8: f2 0f f0 46 37 lddqu 0x37(%rsi),%xmm0 407bed: f3 0f 7f 47 37 movdqu %xmm0,0x37(%rdi) 407bf2: f2 0f f0 46 27 lddqu 0x27(%rsi),%xmm0 407bf7: f3 0f 7f 47 27 movdqu %xmm0,0x27(%rdi) 407bfc: f2 0f f0 46 17 lddqu 0x17(%rsi),%xmm0 407c01: f3 0f 7f 47 17 movdqu %xmm0,0x17(%rdi) 407c06: f2 0f f0 46 07 lddqu 0x7(%rsi),%xmm0 407c0b: f2 0f f0 0e lddqu (%rsi),%xmm1 407c0f: f3 0f 7f 47 07 movdqu %xmm0,0x7(%rdi) 407c14: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407c18: c3 retq 407c19: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407c20: 8b 56 03 mov 0x3(%rsi),%edx 407c23: 8b 0e mov (%rsi),%ecx 407c25: 89 57 03 mov %edx,0x3(%rdi) 407c28: 89 0f mov %ecx,(%rdi) 407c2a: c3 retq 407c2b: 0f 1f 44 00 00 nopl 0x0(%rax,%rax,1) 407c30: f2 0f f0 46 76 lddqu 0x76(%rsi),%xmm0 407c35: f3 0f 7f 47 76 movdqu %xmm0,0x76(%rdi) 407c3a: f2 0f f0 46 66 lddqu 0x66(%rsi),%xmm0 407c3f: f3 0f 7f 47 66 movdqu %xmm0,0x66(%rdi) 407c44: f2 0f f0 46 56 lddqu 0x56(%rsi),%xmm0 407c49: f3 0f 7f 47 56 movdqu %xmm0,0x56(%rdi) 407c4e: f2 0f f0 46 46 lddqu 0x46(%rsi),%xmm0 407c53: f3 0f 7f 47 46 movdqu %xmm0,0x46(%rdi) 407c58: f2 0f f0 46 36 lddqu 0x36(%rsi),%xmm0 407c5d: f3 0f 7f 47 36 movdqu %xmm0,0x36(%rdi) 407c62: f2 0f f0 46 26 lddqu 0x26(%rsi),%xmm0 407c67: f3 0f 7f 47 26 movdqu %xmm0,0x26(%rdi) 407c6c: f2 0f f0 46 16 lddqu 0x16(%rsi),%xmm0 407c71: f3 0f 7f 47 16 movdqu %xmm0,0x16(%rdi) 407c76: f2 0f f0 46 06 lddqu 0x6(%rsi),%xmm0 407c7b: f2 0f f0 0e lddqu (%rsi),%xmm1 407c7f: f3 0f 7f 47 06 movdqu %xmm0,0x6(%rdi) 407c84: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407c88: c3 retq 407c89: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407c90: 8b 56 02 mov 0x2(%rsi),%edx 407c93: 8b 0e mov (%rsi),%ecx 407c95: 89 57 02 mov %edx,0x2(%rdi) 407c98: 89 0f mov %ecx,(%rdi) 407c9a: c3 retq 407c9b: 0f 1f 44 00 00 nopl 0x0(%rax,%rax,1) 407ca0: f2 0f f0 46 75 lddqu 0x75(%rsi),%xmm0 407ca5: f3 0f 7f 47 75 movdqu %xmm0,0x75(%rdi) 407caa: f2 0f f0 46 65 lddqu 0x65(%rsi),%xmm0 407caf: f3 0f 7f 47 65 movdqu %xmm0,0x65(%rdi) 407cb4: f2 0f f0 46 55 lddqu 0x55(%rsi),%xmm0 407cb9: f3 0f 7f 47 55 movdqu %xmm0,0x55(%rdi) 407cbe: f2 0f f0 46 45 lddqu 0x45(%rsi),%xmm0 407cc3: f3 0f 7f 47 45 movdqu %xmm0,0x45(%rdi) 407cc8: f2 0f f0 46 35 lddqu 0x35(%rsi),%xmm0 407ccd: f3 0f 7f 47 35 movdqu %xmm0,0x35(%rdi) 407cd2: f2 0f f0 46 25 lddqu 0x25(%rsi),%xmm0 407cd7: f3 0f 7f 47 25 movdqu %xmm0,0x25(%rdi) 407cdc: f2 0f f0 46 15 lddqu 0x15(%rsi),%xmm0 407ce1: f3 0f 7f 47 15 movdqu %xmm0,0x15(%rdi) 407ce6: f2 0f f0 46 05 lddqu 0x5(%rsi),%xmm0 407ceb: f2 0f f0 0e lddqu (%rsi),%xmm1 407cef: f3 0f 7f 47 05 movdqu %xmm0,0x5(%rdi) 407cf4: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407cf8: c3 retq 407cf9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407d00: 8b 56 01 mov 0x1(%rsi),%edx 407d03: 8b 0e mov (%rsi),%ecx 407d05: 89 57 01 mov %edx,0x1(%rdi) 407d08: 89 0f mov %ecx,(%rdi) 407d0a: c3 retq 407d0b: 0f 1f 44 00 00 nopl 0x0(%rax,%rax,1) 407d10: f2 0f f0 46 74 lddqu 0x74(%rsi),%xmm0 407d15: f3 0f 7f 47 74 movdqu %xmm0,0x74(%rdi) 407d1a: f2 0f f0 46 64 lddqu 0x64(%rsi),%xmm0 407d1f: f3 0f 7f 47 64 movdqu %xmm0,0x64(%rdi) 407d24: f2 0f f0 46 54 lddqu 0x54(%rsi),%xmm0 407d29: f3 0f 7f 47 54 movdqu %xmm0,0x54(%rdi) 407d2e: f2 0f f0 46 44 lddqu 0x44(%rsi),%xmm0 407d33: f3 0f 7f 47 44 movdqu %xmm0,0x44(%rdi) 407d38: f2 0f f0 46 34 lddqu 0x34(%rsi),%xmm0 407d3d: f3 0f 7f 47 34 movdqu %xmm0,0x34(%rdi) 407d42: f2 0f f0 46 24 lddqu 0x24(%rsi),%xmm0 407d47: f3 0f 7f 47 24 movdqu %xmm0,0x24(%rdi) 407d4c: f2 0f f0 46 14 lddqu 0x14(%rsi),%xmm0 407d51: f3 0f 7f 47 14 movdqu %xmm0,0x14(%rdi) 407d56: f2 0f f0 46 04 lddqu 0x4(%rsi),%xmm0 407d5b: f2 0f f0 0e lddqu (%rsi),%xmm1 407d5f: f3 0f 7f 47 04 movdqu %xmm0,0x4(%rdi) 407d64: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407d68: c3 retq 407d69: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407d70: 8b 16 mov (%rsi),%edx 407d72: 89 17 mov %edx,(%rdi) 407d74: c3 retq 407d75: 0f 1f 44 00 00 nopl 0x0(%rax,%rax,1) 407d7a: 66 0f 1f 44 00 00 nopw 0x0(%rax,%rax,1) 407d80: f2 0f f0 46 73 lddqu 0x73(%rsi),%xmm0 407d85: f3 0f 7f 47 73 movdqu %xmm0,0x73(%rdi) 407d8a: f2 0f f0 46 63 lddqu 0x63(%rsi),%xmm0 407d8f: f3 0f 7f 47 63 movdqu %xmm0,0x63(%rdi) 407d94: f2 0f f0 46 53 lddqu 0x53(%rsi),%xmm0 407d99: f3 0f 7f 47 53 movdqu %xmm0,0x53(%rdi) 407d9e: f2 0f f0 46 43 lddqu 0x43(%rsi),%xmm0 407da3: f3 0f 7f 47 43 movdqu %xmm0,0x43(%rdi) 407da8: f2 0f f0 46 33 lddqu 0x33(%rsi),%xmm0 407dad: f3 0f 7f 47 33 movdqu %xmm0,0x33(%rdi) 407db2: f2 0f f0 46 23 lddqu 0x23(%rsi),%xmm0 407db7: f3 0f 7f 47 23 movdqu %xmm0,0x23(%rdi) 407dbc: f2 0f f0 46 13 lddqu 0x13(%rsi),%xmm0 407dc1: f3 0f 7f 47 13 movdqu %xmm0,0x13(%rdi) 407dc6: f2 0f f0 46 03 lddqu 0x3(%rsi),%xmm0 407dcb: f2 0f f0 0e lddqu (%rsi),%xmm1 407dcf: f3 0f 7f 47 03 movdqu %xmm0,0x3(%rdi) 407dd4: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407dd8: c3 retq 407dd9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407de0: 66 8b 56 01 mov 0x1(%rsi),%dx 407de4: 66 8b 0e mov (%rsi),%cx 407de7: 66 89 57 01 mov %dx,0x1(%rdi) 407deb: 66 89 0f mov %cx,(%rdi) 407dee: c3 retq 407def: 90 nop 407df0: f2 0f f0 46 72 lddqu 0x72(%rsi),%xmm0 407df5: f3 0f 7f 47 72 movdqu %xmm0,0x72(%rdi) 407dfa: f2 0f f0 46 62 lddqu 0x62(%rsi),%xmm0 407dff: f3 0f 7f 47 62 movdqu %xmm0,0x62(%rdi) 407e04: f2 0f f0 46 52 lddqu 0x52(%rsi),%xmm0 407e09: f3 0f 7f 47 52 movdqu %xmm0,0x52(%rdi) 407e0e: f2 0f f0 46 42 lddqu 0x42(%rsi),%xmm0 407e13: f3 0f 7f 47 42 movdqu %xmm0,0x42(%rdi) 407e18: f2 0f f0 46 32 lddqu 0x32(%rsi),%xmm0 407e1d: f3 0f 7f 47 32 movdqu %xmm0,0x32(%rdi) 407e22: f2 0f f0 46 22 lddqu 0x22(%rsi),%xmm0 407e27: f3 0f 7f 47 22 movdqu %xmm0,0x22(%rdi) 407e2c: f2 0f f0 46 12 lddqu 0x12(%rsi),%xmm0 407e31: f3 0f 7f 47 12 movdqu %xmm0,0x12(%rdi) 407e36: f2 0f f0 46 02 lddqu 0x2(%rsi),%xmm0 407e3b: f2 0f f0 0e lddqu (%rsi),%xmm1 407e3f: f3 0f 7f 47 02 movdqu %xmm0,0x2(%rdi) 407e44: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407e48: c3 retq 407e49: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407e50: 0f b7 16 movzwl (%rsi),%edx 407e53: 66 89 17 mov %dx,(%rdi) 407e56: c3 retq 407e57: 66 0f 1f 84 00 00 00 nopw 0x0(%rax,%rax,1) 407e5e: 00 00 407e60: f2 0f f0 46 71 lddqu 0x71(%rsi),%xmm0 407e65: f3 0f 7f 47 71 movdqu %xmm0,0x71(%rdi) 407e6a: f2 0f f0 46 61 lddqu 0x61(%rsi),%xmm0 407e6f: f3 0f 7f 47 61 movdqu %xmm0,0x61(%rdi) 407e74: f2 0f f0 46 51 lddqu 0x51(%rsi),%xmm0 407e79: f3 0f 7f 47 51 movdqu %xmm0,0x51(%rdi) 407e7e: f2 0f f0 46 41 lddqu 0x41(%rsi),%xmm0 407e83: f3 0f 7f 47 41 movdqu %xmm0,0x41(%rdi) 407e88: f2 0f f0 46 31 lddqu 0x31(%rsi),%xmm0 407e8d: f3 0f 7f 47 31 movdqu %xmm0,0x31(%rdi) 407e92: f2 0f f0 46 21 lddqu 0x21(%rsi),%xmm0 407e97: f3 0f 7f 47 21 movdqu %xmm0,0x21(%rdi) 407e9c: f2 0f f0 46 11 lddqu 0x11(%rsi),%xmm0 407ea1: f3 0f 7f 47 11 movdqu %xmm0,0x11(%rdi) 407ea6: f2 0f f0 46 01 lddqu 0x1(%rsi),%xmm0 407eab: f2 0f f0 0e lddqu (%rsi),%xmm1 407eaf: f3 0f 7f 47 01 movdqu %xmm0,0x1(%rdi) 407eb4: f3 0f 7f 0f movdqu %xmm1,(%rdi) 407eb8: c3 retq 407eb9: 0f 1f 80 00 00 00 00 nopl 0x0(%rax) 407ec0: 0f b6 16 movzbl (%rsi),%edx 407ec3: 88 17 mov %dl,(%rdi) 407ec5: c3 retq 407ec6: 90 nop 407ec7: 90 nop 407ec8: 90 nop 407ec9: 90 nop 407eca: 90 nop 407ecb: 90 nop 407ecc: 90 nop 407ecd: 90 nop 407ece: 90 nop 407ecf: 90 nop
Bernard
Valued Contributor I
I prefer to read assembly code in Intel syntax , can you translate it from AT&T syntax to Intel synatx.
Bernard
>>>OK, I guess it's my mistake to give you the impression that remote memory copy is 10 time slower. In my program, I allocate the source array and the destination array in node 0, and run the memory copy code in node 0, 1, 2, 3. If I run memory copy in node 0, it takes 0.85s. If I run the code in node 1 or 3, it takes 5.74s. If in node 2, it takes 7s. So the performance degradation is 6.75 and 8.24.>>> When your code moves further in the NUMA space than memory write/read speed degradation rises accordingly to the distance "travelled" While analyzing your case I think that some kernel component like a memory manager or its subunit (allocator type) could be responsible for large performance penalty. Can you programmaticaly access and manipulate NUMA related API?I see two numa related header files. By simple logical reasoning NUMA is managed at the chipset and built-in on-die memory controller units level so in theory it could expose to the BIOS/EFI and later to the OS kernel some kind of programming interface which in turn could be accessed by the higher level code. Maybe little bit of tweaking can be somehow helpful.
SergeyKostrov
Valued Contributor II
I need numa.h and numaif.h header files. Could you upload? I'll try to create a reproducer during next a couple of days. Da, did you try to execute your test with a lower number of threads?
Bernard
>>>I need numa.h and numaif.h header files. Could you upload? I'll try to create a reproducer during next a couple of days.>>> I suppose that numa header files could be very helpful in attempt to understand numa related management functions. I have read numa related ACPI documentation,but beside distance table i was not able to find any programming interface. Maybe exact chipset documentation could shed some light. >>> Da, did you try to execute your test with a lower number of threads?>>> Do not you suspect that some kernel memory allocator can be responsible for such a large memory access speed degradation?
