1707 Discussions
Thread Pool Engine version 1.3 - stable version - is here ...
aminer10
Hello all,
I have updated Threadpool to version 1.3 - a stable version -
Lock-free ParallelQueuerb and lock-free RingBuffer have been added
Author: Amine Moulay Ramdane
Language: FPC Pascal v2.2.0+ / Delphi 5+:
http://www.freepascal.org/
Operating Systems: Win , Linux and Mac (x86).
Description:
Lock-free Thread Pool Engine.
The following have been added:
-- Lockfree ParallelQueue for less contention and more efficiency
or it can use lockfree_mpmc - flqueue that i have modified, enhanced
and improved... - ...
- It uses a lock-free queue for each worker thread and work-stealing
- for more efficiency -
- The worker threads enters in a wait state when there no job in the
lock-free queues - for more efficiency -
- You can distribute your jobs to the worker threads and call any
method with the threadpool's execute() method.
Look into defines.inc there is many options:
ParallelQueue: it uses lock-free ParallelQueue - very efficient -
Lockfree_MPMC: it uses lockfree_MPMC
ParallelQueuerb: it uses lock-free ParallelQueuerb (New)
RingBuffer: it uses lock-free RingBuffer (New)
SINGLE_PRODUCER: for a single producer (thread)
MUTIPLE_PRODUCER: mutiple producer (threads)
CPU32: for 32 bits architecture
Required FPC switches: -O3 -Sd -dFPC -dWin32 -dFreePascal
-Sd for delphi mode....
Required Delphi switches: -DMSWINDOWS -$H+
For Delphi 5,6,7 use -DDelphi
For Delphi 2005,2006,2007,2009,2010+ use the switch -DDELPHI2005+
Please look at the examples test.pas,test_pool.pas and
test_thread.pas insode the zip...
Note: test_pool.pas does require Delphi 5+, test.pas and
test_thread.pas works with both FreePascal and Delphi
You can download the new and stable version 1.3 from:
http://pages.videotron.com/aminer/
My Threadpool is VERY easy to use, and here is a page
that i wrote about it:
http://pages.videotron.com/aminer/threadpool.htm
Sincerely,
Amine Moulay Ramdane.
aminer10
Skybuck Flying wrote:
> I would like to see performance comparisions, against
> Delphi's own TThread and/or other windows methods ?
> and why your Thread Pool Engine would be better might also help ;)
And how will you load balance the workload efficiently,
and also minimize contention...
and not start threads for each job...
with just TThread ?
Please read again:
My Threadpool is very efficient and very easy to use...
Take care..
Sincerely
aminer10
>I implemented my own "blocking queue" using semaphares and critical section
>(mutex). [...]
I don't think blocking queues are as efficient as lock-free queues
Just look at the difference between three lock-free algorithms
http://pages.videotron.com/aminer/parallelqueue/parallelqueue.htm
You can easily notice the difference between those lock-free
algorithmns just by setting the options in defines.inc and
runnning test_thread1.pas
Now, just imagine what will be the difference between a
lock and a lock-free algorithm ? i really think lock-free
algorithms are very efficient.
Also, i have used in my Thread Pool Engine not just one queue
but many lock-free queues - for each worker thread - to minimize
contention... and work-stealing to load balance the workload
efficiently...
>Also your code's layout/indentation looks very bad...
>(at least some of the test programs look bad)...
Common ! the code is not so bad..
And also, i give much more importance to 'logic' than to code..
>Also your code seems to use all kinds of external dll's/libraries...
>which is undesirable... this could also lead to security risks...
>what's inside the dll's ?!? Virus/trojans maybe ?
I have just used the TBB memory manager in Delphi
- look at cmem.pas inside the zip - you can - if
you want - download them yourself from the intel
website...
FPC doesn't need the TBB memory manager...
>Furthermore your source code uses assembler here
>and there where it might or might not be necessary...
>like "cas"... windows already have methods for
>"interlock exchange" and what not...
I have decided to put the assembler code for educational
purpose also...
>Your most interesting unit so far is the parallel hash list...
>hashes might not always be usefull though... but still it
>could be interesting.
I also love ParallelHashList...
>Might be a lot of work for you... so I understand if you
>don't want to do that...
