VTune Loop duplicates
Paulius_V_
Hello all.  Can anyone explain why my vtune profiling run shows the same loop twice?
TimP
You may have multiple versions and remainder loops. opt-report4 should clarify.
Paulius_V_
That would make sense, thank you. What I find confusing, however, is that the number of clockticks spent is significant for both of them and the CPI is nearly double for one version. In case of multiversioned and peel/remainder loops it would make more sense of the bulk of the time would be spent in a single version. What decides which version will be used?
TimP
If you look in opt-report and find different assumptions about alignments, that might shed light. You may have aligned and unligned on alternate executions. #pragma vector unaligned might give you a single version. If you have a remainder loop reporting high cpi it may not mean much unless time spent there is significant. If you run advisor it may flag any remainder taking significant time and produce suggestions regardless of whether it is already efficient.
