coarray problem
latomicien
i have, suddenly, in a console mode, under windows 7, when i make "execute without debugging" : "unknown option : -localonly" and my software (matrix multiplication for teaching) stop. There is many days it works without problem !
Why i have this error suddenly ?
Help
latomicien
SergeyKostrov
Valued Contributor II
Quoting latomicien
Could you make a screenshot, please?
latomicien
thanks you very much for your attention.
In fact i have uninstall Visual Studio 2010 and Fortran Intel XE Composer and re install together. The problem has stop !
The screenshot was (from memory) :
"unknown option : -localonly (this first line i am sur)
hit a touch to quit the program (the second had this sens).
Now i have other "problem" about memory gestion in matrix multiplication : for some dimension of allocatable array the computing is good (product of two matrix 1023 x 1023 take less 2 or 3 seconds) and for other very bad (1024 x 1024 take near 10 s !!!).
I make detail report of this problem and i will communicate it if you are interested by this.
Bests regards
Tamer_Assad
Innovator
Hi Latomicien, What is the size your processor's cash memory? what is the data type of the matrix elements? This might be a granualrity issue, if so, partioning would help. Regards, Tamer
